[mapguide-users] Load Test - Please try your operation later as the repository was busy
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Wed Sep 7 08:20:28 PDT 2016
Same is with Sheboygan dataset.
In 2.2 I can get with grinder over 30 TPS (Transactions Per Second). All
request return HTTP 200.
In other versions much much less. After a while MG stop responding to
requests.
Here is Grinder Script for Sheboygan dataset:
http://www.islovenija.si/osgeo.zip <http://www.islovenija.si/osgeo.zip>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Load-Test-Please-try-your-operation-later-as-the-repository-was-busy-tp5284309p5284548.html
