[mapguide-users] Registered provider 'OSGeo.Gdal.4.0' is registered with library for provider 'OSGeo.Gdal.4.1'
Liglio liglio at pobox.com
Thu Sep 8 08:09:42 PDT 2016
I installed mapguide 3.1 beta 2. When I try to create a GDAL feature source,
I canĀ“t validate it. I got the following error. I checked the file
GRFPProvider.dll, and the version product is 4.1.0.0 different from the
providers.xml.
<FeatureProvider>
    <Name>OSGeo.Gdal.4.0</Name>
    <DisplayName>GDAL Provider</DisplayName>
    <Description>FDO Raster Provider for GDAL</Description>
    <IsManaged>False</IsManaged>
    <Version>4.0.0.0</Version>
    <FeatureDataObjectsVersion>4.0.0.0</FeatureDataObjectsVersion>
    <LibraryPath>.\GRFPProvider.dll</LibraryPath>
  </FeatureProvider>
Validating resource:
Session:6c6fb962-75d2-11e6-8000-000c297af5e8_en_MTI3LjAuMC4x0AFC0AFB0AFA//64481a97-36b6-4b0f-aeb9-18a6659a26bf.FeatureSource
Error - Error_FeatureSource_ConnectionTestFailed: Connection test failed:
	The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Error occurred in Feature Source
(Session:6c6fb962-75d2-11e6-8000-000c297af5e8_en_MTI3LjAuMC4x0AFC0AFB0AFA//64481a97-36b6-4b0f-aeb9-18a6659a26bf.FeatureSource):
Failed to de-serialize the schema mappings from the configuration. (Cause:
'OSGeo.Gdal.4.1'. , Root Cause: Registered provider 'OSGeo.Gdal.4.0' is
registered with library for provider 'OSGeo.Gdal.4.1'. )
- MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
 (Cause: , Root Cause: )
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgServerFeatureService.TestConnection() line 244 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgFdoConnectionManager.Open() line 366 file
View this message in context: http://osgeo-org.1560.x6.nabble.com/Registered-provider-OSGeo-Gdal-4-0-is-registered-with-library-for-provider-OSGeo-Gdal-4-1-tp5284754.html
