[mapguide-users] unable to logon Mapguide : ACE.dll failed
Jackie Ng jumpinjackie at gmail.com
Mon Feb 6 03:08:40 PST 2017
I just installed 2.6.1 on my Windows 8.1 laptop. No issues.
I can only suspect you must have some residual trace of an old MapGuide
installation lying around.
 1. Do you have old MapGuide installation directories on the PATH
environment variable?
 2. If you run Process Monitor and listen on mgserver.exe or w3wp.exe, is it
loading the correct ACE.dll?
 3. If you run Dependency Walker and load ACE.dll, are all of its
dependencies satisifed?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/unable-to-logon-Mapguide-ACE-dll-failed-tp5306170p5306458.html
