[mapguide-users] unable to logon Mapguide : ACE.dll failed
Rémy Gourrat rgourrat at ag-carto.fr
Mon Feb 6 07:27:15 PST 2017
Roza : with a setup with virtual directory mapguide2 and harddisk mapguide2, Error 559 in maestro and mapadmin is failing with always ACE.dll module path failing in windows log event,
Jackie : with depends walker,
  1.  Do you have old MapGuide installation directories on the PATH environment variable?
No, it’s a new system and it was before the first installation (now, there were lot of install/uninstall…)
  1.  If you run Process Monitor and listen on mgserver.exe or w3wp.exe, is it loading the correct ACE.dll?
Yes, for the twice : mgserver.exe run with the ACE.DLL in the mgserver.exe directory, w3wp.exe run with the ACE.DLL in the mapagent directory, php-cgi.exe run with the ACE.DLL in the php directory
 3. If you run Dependency Walker and load ACE.dll, are all of its dependencies satisifed?
For 2.5.2 : API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-1.DLL, API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-1.DLL, API-MS-WIN-SERVICE-PRIVATE-L1-1-1.DLL depends tell are missing
        But it’s same for 3.0.0 and 3.1.0 that are turning good !
MapGuide 2.5.2 and newer require .net 4.0, on my windows 8.1 it’s.net 4.5, can it be the reason ?
For information, each time I start the mapguide 2.5.2 service, I have this message in error.log :
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2017-02-06T11:35:15>               5100
Success: Server started.
<2017-02-06T11:35:20>               412
Error: Problem:\nThe application encountered a problem and could not finish the operation you just requested properly.\n\nSolution:\nIf it\'s the first time you met this problem, try again or restart the application / session; otherwise, describe the steps to reproduce this problem to the server administrator for suggestions.
StackTrace:
  - MgTimedEventHandler.handle_timeout() line 130 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\core\TimedEventHandler.cpp
  - MgSessionTimeoutEventHandler.HandleEvent() line 101 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\core\SessionTimeoutEventHandler.cpp
<2017-02-06T11:35:20>               5564                                      Administrator
StackTrace:
  - MgFeatureServiceCacheTimeLimitEventHandler.HandleEvent() line 86 file c:\working\build_area\mapguide\2.5.2\x64\mgdev\server\src\core\FeatureServiceCacheTimeLimitEventHandler.cpp
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170206/5c1a8137/attachment.html>
