[mapguide-users] Ajax viewer, URL in Properties Pane
gom gord.mckenzie at canam.com
Wed Feb 8 07:55:41 PST 2017
Using the debugger on the browser here is what I am seeing.
When the line /*console.log(input);*/ is included in the HtmlDecode
function, the code path followed is through that first if statement and
return input gives the expected result.
When that same line of code is left out of the function, the code path
followed is the second if statement and /*_el.childNodes[0].nodeValue;*/ is
null for the url field.  _el.innerHTML does hold the correct string.
Does this provide any meaningful information towards what might be
happening?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Ajax-viewer-URL-in-Properties-Pane-tp5306236p5306980.html
