[mapguide-users] OSM API KEY REQUIRED for CycleMap
RenoSun renolionheart at gmail.com
Wed Feb 22 13:53:25 PST 2017
Are you using Flexible Layout? Which version of mapguide are you using?
You should have an option to use OSM CycleMap as base map with your flexible
layout.
Make sure you're using the right coordinate system too! WGS84.PseudoMercator
<http://osgeo-org.1560.x6.nabble.com/file/n5309156/FlexibleLayoutOSMCycleMap.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/OSM-API-KEY-REQUIRED-for-CycleMap-tp5309129p5309156.html
