[mapguide-users] 30 seconds delay after creating +/-100 CreateRuntimeMap calls
BenSav ben.Savelkoul at geosolutions.be
Tue Feb 28 23:56:48 PST 2017
This is the function we are using to create the runtime map, it is called
from a for-loop:
private void CreateMap(string name, MgMappingService srv)
            if (!string.IsNullOrEmpty(name))
                try
                    _log.Info("Trying to create map: " + name);
                    MgResourceIdentifier resourceID = new
MgResourceIdentifier("Library://" + name + "." +
MgResourceType.MapDefinition);
                    _log.Info("MapDefinition resource: " +
resourceID.ToString());
                    srv.CreateRuntimeMap(resourceID, sessionId, 0, 100);
                    _log.Info("Map created");
                catch (MgResourceNotFoundException e)
                    _log.Error("Failed to create map: " + name);
                    _log.Error(e.GetExceptionMessage());
                catch (Exception e)
                    _log.Error(e.ToString());
This is what is being logged:
09 02 2017 11:22:41 INFO  Starting session
09 02 2017 11:22:41 INFO  Trying to create map:
DWG/Gasdetectie/Maps/OL_Gasdetectie
09 02 2017 11:22:41 INFO  MapDefinition resource:
Library://DWG/Gasdetectie/Maps/OL_Gasdetectie.MapDefinition
09 02 2017 11:22:41 INFO  Map created
DWG/Kanaal_gent_terneuzen/Maps/OL_Waterwegen_details
Library://DWG/Kanaal_gent_terneuzen/Maps/OL_Waterwegen_details.MapDefinition
Library://DWG/Kanaal_gent_terneuzen/Maps/OL_Waterwegen.MapDefinition
DWG/Info.Bloknrs/Maps/OL_Afdelingsnamen
Library://DWG/Info.Bloknrs/Maps/OL_Afdelingsnamen.MapDefinition
DWG/Info.Bloknrs/Maps/OL_Info_BlokNrs
Library://DWG/Info.Bloknrs/Maps/OL_Info_BlokNrs.MapDefinition
09 02 2017 11:22:42 INFO  Trying to create map:
DWG/Nutsleidingen_gasvorm/Kooksgas/Maps/OL_196_info
09 02 2017 11:22:42 INFO  MapDefinition resource:
Library://DWG/Nutsleidingen_gasvorm/Kooksgas/Maps/OL_196_info.MapDefinition
09 02 2017 11:22:42 INFO  Map created
DWG/Nutsleidingen_gasvorm/Kooksgas/Maps/OL_196_kooksgas
*09 02 2017 11:22:42 INFO  MapDefinition resource:
Library://DWG/Nutsleidingen_gasvorm/Kooksgas/Maps/OL_196_kooksgas.MapDefinition
09 02 2017 11:23:12 INFO  Trying to create map:
DWG/Nutsleidingen_gasvorm/Hoogovengas/Maps/OL_195_RegNr_hoogovengas*
09 02 2017 11:23:12 INFO  MapDefinition resource:
Library://DWG/Nutsleidingen_gasvorm/Hoogovengas/Maps/OL_195_RegNr_hoogovengas.MapDefinition
09 02 2017 11:23:12 INFO  Map created
DWG/Nutsleidingen_gasvorm/Hoogovengas/Maps/OL_195_info
Library://DWG/Nutsleidingen_gasvorm/Hoogovengas/Maps/OL_195_info.MapDefinition
So you can see clearly there is a pause or delay of exactly 30 seconds.
View this message in context: http://osgeo-org.1560.x6.nabble.com/30-seconds-delay-after-creating-100-CreateRuntimeMap-calls-tp5309691p5310061.html
