[mapguide-users] Create a modal dialog from the selection panel
Jamo adam.jamison at portbris.com.au
Thu Jul 27 17:51:50 PDT 2017
Jackie I'm porting over some of my selection panel customization to the new
react based programming language I've managed to set it up find when a
property of a certain value is hit and change it to a href or show an image
or interpret the data accordingly ....
I'm struggling with showing a modal dialog similar to the help / about
dialogs that appear..
Currently the modal I'm creating is bounded by the selection panel .... I
see a ModalLauncher container but I don't know how to use it.....
Ideally I'm trying to create a ImageModal or something that shows an image
in the selection panel then when the user clicks it it opens a modal in the
center of the map area showing the image in question.
I've used an existing tsx file and fiddled with it a little to get the bones
working.
image-modal.tsx
selection-panel.tsx changes
MapGuide Maestro 6.0.0.8587
MapGuide Opensource 3.0.0.8701
Fusion, PHP, Apache
Windows 7 Pro SP1
View this message in context: http://osgeo-org.1560.x6.nabble.com/Create-a-modal-dialog-from-the-selection-panel-tp5329560.html
