[mapguide-users] 30 seconds delay after creating +/-100 CreateRuntimeMap calls
Jackie Ng jumpinjackie at gmail.com
Wed Mar 1 17:10:38 PST 2017
This is sadly a leaky abstraction that is unavoidable at the moment.
You have to be cognizant of the fact that although you're writing .net code,
it is .net code that ultimately wraps and interops to native C/C++ code, so
its memory management and lifecycle issues can crop up in your .net code if
you write your code in a "too .net" fashion.
So, I'd extend Benoit's advice to say that you should be capturing to a
variable *any method in the MapGuide API that returns an object reference*,
not just methods that return MgByteReaders.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/30-seconds-delay-after-creating-100-CreateRuntimeMap-calls-tp5309691p5310221.html
