[mapguide-users] MGOS layers with Google Maps API?
RenoSun renolionheart at gmail.com
Wed Sep 20 15:20:07 PDT 2017
Hi open_saucer,
I think it's totally doable to use Google Map API with MGOS.
However, it won't be as easy as using OpenLayers 3 API to do that.
I would suggest that you can give  OL3 <https://openlayers.org/>   a try, or
something like  OL3-Google-Maps
<https://github.com/mapgears/ol3-google-maps>  .
You may use  mapguide-rest <https://github.com/jumpinjackie/mapguide-rest>
to load vector-tiles(geojson) from MGOS, and load them by using Google Map
API/OL3 API.
Or you may set up your own configuration by using mapguide-rest to generate
html, kml, geojson, xml, or czml response based on what you set up on MGOS
by using Maestro.
I didn't see this post, but hopefully you had some progresses already :)
Cheers!
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
