[mapguide-users] Migration Autodesk to Esri
Jérôme DUCKERS jerome.duckers at gmail.com
Sun Apr 8 23:31:14 PDT 2018
Thank you for all your comment.
I'm part of a big company with a lot of money and an old mentality :(
thinking that if you pay, you've the best service.
But now, we are facing the wall, and we need to take decisions.
More, since 1 year, we are facing a big migration of our applications to
SAP. And for now only Esri is positioning itself as a leader in SAP :(
So, we bought some licenses to provide some map/feature services.
Unfortunately, we already see the limitations of the products.
In terms of infrastructure, we are using Oracle Database with SDO_GEOMETRY.
We refused to work with ST_GEOMETRY, we want to be as generic as possible.
Idem for the front end, everything is thought to use a different viewer
(Autodesk, esri, Google, ....).
So if i understand correctly, no one has been confronted with this forced
migration ?
Jérôme.
2018-04-04 20:38 GMT+02:00 Ricardo Pinho <ricardodepinho at gmail.com>:
> > Data is EVERYTHING.
> That's correct... you should watch the Arnulf (OSGeo) video @ Foss4g 2016!
> foss4g-2016-1060-software comes and goes mind the data [Arnulf] - hd on
> Vimeo <https://vimeo.com/187556741>And the KEEP USING OPEN FORMATS is the
> only way to have full access and control of YOUR DATA!!!
> Don't let them fool you, only TRUE FREE OPEN SOURCE SOFTWARE can guarantee
> interoperability!
> There are fantastic and enterprise REAL FREE OPEN SOURCE alternatives to
> Mapguide OS and AIMS:
> https://www.osgeo.org/choose-a-project/mapping-and-
> cartography/mapping-services/
> 2018-04-04 18:56 GMT+01:00 GordonL <gordon.luckett at arrowgeomatics.com>:
>> I really want to be a cynic and to tell management to stop using things
>> like
>> Google (open source) and basically most of the web running on Linux.
>> There would be a more of risk to management to move to a platform that is
>> not as "open" as MGOS.  However, the key to any thing is the DATA.  Data
>> is
>> EVERYTHING.
>> So, if you do go with ArcGIS Server, for example, make sure your data is a
>> format that all GISes can see.  For example, most GIS systems can see SHP
>> (not SDF).
>> But above all, the data should be stored in a database such as Oracle, SQL
>> Server or PostgreSQL & PostGIS.
>> If you do store your data in a database, especially with ArcGIS
>> Enterprise,
>> make sure you are using the databases' native Geometry format and not ESRI
>> Proprietary st geom.
>> Your life will be way easier.
>> If your data is in a neutral database, all GIS systems can view and edit
>> the
>> data (given permissions) and regardless of what comes down the pipe
>> (Autodesk/ESRI/Tesla/Amazon GIS) you are in a position to take advantage.
>> DATA is EVERYTHING.
>> gordon
>> Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.
>> html
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20180409/55cf568a/attachment.html>
