[mapguide-users] Migration Autodesk to Esri
Ricardo Pinho ricardodepinho at gmail.com
Thu Apr 12 00:20:59 PDT 2018
Hi Jerôme,
Why don't you contact directly some guys that can really help you?
GeoSolutions (Europe)
https://www.geo-solutions.it/contacts/
Boundless Geo (USA)
https://boundlessgeo.com/contact/
You will be amazed that you are not left alone on the hands of proprietary
multinational companies! ;-)
Best of luck!
2018-04-09 7:31 GMT+01:00 Jérôme DUCKERS <jerome.duckers at gmail.com>:
> Hi,
> Thank you for all your comment.
> I'm part of a big company with a lot of money and an old mentality :(
> thinking that if you pay, you've the best service.
> But now, we are facing the wall, and we need to take decisions.
> More, since 1 year, we are facing a big migration of our applications to
> SAP. And for now only Esri is positioning itself as a leader in SAP :(
> So, we bought some licenses to provide some map/feature services.
> Unfortunately, we already see the limitations of the products.
> In terms of infrastructure, we are using Oracle Database with
> SDO_GEOMETRY. We refused to work with ST_GEOMETRY, we want to be as generic
> as possible.
> Idem for the front end, everything is thought to use a different viewer
> (Autodesk, esri, Google, ....).
> So if i understand correctly, no one has been confronted with this forced
> migration ?
> Jérôme.
> 2018-04-04 20:38 GMT+02:00 Ricardo Pinho <ricardodepinho at gmail.com>:
>> > Data is EVERYTHING.
>> That's correct... you should watch the Arnulf (OSGeo) video @ Foss4g 2016!
>> foss4g-2016-1060-software comes and goes mind the data [Arnulf] - hd on
>> Vimeo <https://vimeo.com/187556741>And the KEEP USING OPEN FORMATS is
>> the only way to have full access and control of YOUR DATA!!!
>> Don't let them fool you, only TRUE FREE OPEN SOURCE SOFTWARE can
>> guarantee interoperability!
>> There are fantastic and enterprise REAL FREE OPEN SOURCE alternatives to
>> Mapguide OS and AIMS:
>> https://www.osgeo.org/choose-a-project/mapping-and-cartograp
>> hy/mapping-services/
>> 2018-04-04 18:56 GMT+01:00 GordonL <gordon.luckett at arrowgeomatics.com>:
>>> I really want to be a cynic and to tell management to stop using things
>>> like
>>> Google (open source) and basically most of the web running on Linux.
>>> There would be a more of risk to management to move to a platform that is
>>> not as "open" as MGOS.  However, the key to any thing is the DATA.  Data
>>> is
>>> EVERYTHING.
>>> So, if you do go with ArcGIS Server, for example, make sure your data is
>>> a
>>> format that all GISes can see.  For example, most GIS systems can see SHP
>>> (not SDF).
>>> But above all, the data should be stored in a database such as Oracle,
>>> SQL
>>> Server or PostgreSQL & PostGIS.
>>> If you do store your data in a database, especially with ArcGIS
>>> Enterprise,
>>> make sure you are using the databases' native Geometry format and not
>>> ESRI
>>> Proprietary st geom.
>>> Your life will be way easier.
>>> If your data is in a neutral database, all GIS systems can view and edit
>>> the
>>> data (given permissions) and regardless of what comes down the pipe
>>> (Autodesk/ESRI/Tesla/Amazon GIS) you are in a position to take advantage.
>>> DATA is EVERYTHING.
>>> gordon
>>> Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.
>>> html
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
Ricardo Pinho
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20180412/cd1c0652/attachment.html>
