[mapguide-users] Slow Openstreetmap
Jackie Ng jumpinjackie at gmail.com
Wed Jul 25 02:13:17 PDT 2018
If you expect heavy traffic, OSM wants (expects) you to set up your own tile
server.
Now in terms of getting it to use your own OSM tile server, it should be
simple. OSM/Stamen are just XYZ tile layers with a well-known domain name.
So pointing to your own OSM tile server would just be a case of changing
tile.openstreetmap.org to the hostname of your custom OSM tile server.
Whether Fusion currently makes it easy for you to do this out of the box,
I'd have to investigate further.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
