[mapguide-users] Google Map
RenoSun renolionheart at gmail.com
Tue Jun 19 15:51:35 PDT 2018
Step 1: Using Maestro
Step 2: Double click on your Fusion/Flexible layout (using Google Maps base
map)
Step 3: Click Edit as XML button
Step 4: Scroll to the button of the XML, and find XML tag called
"<GoogleScript>"
Step 5: It should be looks like following XML...
<Extension>
<GoogleScript>http://maps.google.com/maps/api/js?key=YOUR_GOOGLE_MAP_API_KEY&v=3.exp&use_slippy=true</GoogleScript>
<OpenStreetMapScript>http://www.openstreetmap.org/openlayers/OpenStreetMap.js</OpenStreetMapScript>
<StamenScript>http://maps.stamen.com/js/tile.stamen.js?v1.3.0</StamenScript>
<BingMapKey>YOUR_BING_MAP_API_KEY</BingMapKey>
</Extension>
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
