[mapguide-users] MapGuide Maestro 6.0M9 available
BMason masonb12 at telus.net
Fri May 11 15:49:05 PDT 2018
Thanks Jackie,  I have a few questions with regards to using
mapguide-react-layout,
1)  can it run along side mapguide open source on the same server? or is
this not advisable?
2) Is it possible to edit data in a shapefile or SQLserver database?
3) Is it possible to digitize a point, line and polygon and save as a
thanks again
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
