[mapguide-users] Number of Active Sessions
Benoit Begin bbegin at geomapgis.ca
Wed Apr 17 12:07:46 PDT 2019
If you use Maestro, which I am assuming you do, in the Tools menu you have a
"Server Status" tool which does show an Active Connections property. The
totals are, as you said, since the last server restart. So that can still
give you some live information about what is going on.
In your specific case, it might be worthwhile to use the map profiler in the
administrator to check if perhaps a very specific layer of yours is slow,
which tends to start queuing up operations and slowly degrading
performances.
Hope this helped!
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
