[mapguide-users] Feature Joins
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Sep 8 04:45:08 EDT 2006
The values display fine in the selection pane, if they are selected from
the client side.
It only occurs when selecting from the data source thorugh the server
side API.
Campbell, Keith A skrev:
> Thanks Kenneth.
> I will want the users to be able to select objects from the layer and
> read the joined feature values, so I do have a problem.
> Keith
> *From:* Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
> *Sent:* 08 September 2006 09:20
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Feature Joins
> The short answer is yes.
> I have no problems displaying maps/porperties when using ODBC for
> secondary sources.
> But, I have written a bit with Ronnie Louie form Autodesk, about
> selections on such featuresets.
> Ronnie can select from such a Join using my data, but I can't.
> So unless, you want to select objects from the layer and read joined
> feature values using the API, you should be fine.
> The error message I get is:
> OSGeo.MapGuide.MgFdoException: An exception occurred in FDO component.
> no string resource for id <1019> -
> MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpSelectFeatures.Execute line 115 file
> c:\build_tux_area\mgdev\server\src\services\feature\OpSelectFeatures.cpp
> - MgServerSelectFeatures.SelectFeatures line 217 file
> c:\build_tux_area\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> - MgServerSelectFeatures.JoinFeatures line 1008 file
>> All,
>> Can an ODBC Feature Source be used in a Feature Join (as the
>> secondary feature)?
>> Thanks,
>> Keith
>> *This email and any attached files are confidential and copyright
>> protected. If you are not the addressee, any dissemination of this
>> communication is strictly prohibited. Unless otherwise expressly
>> agreed in writing, nothing stated in this communication shall be
>> legally binding.*
> This message has been scanned for viruses by MailControl
> <http://bluepages.wsatkins.co.uk/?4318150>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060908/be0bd567/attachment.html
More information about the Mapguide_users mailing list
