[mapguide-users] POOL:DWF or AJAX
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Sep 15 11:40:41 EDT 2006
right
Ivan Miličević wrote:
> Ok, thanks!!!
> And just one more thing...
> 3. Ensure that the Windows Environment Variables are set as follows:
>         SET FDO=[FDO OpenSource]\Fdo
>         SET FDOUTILITIES=[FDO OpenSource]\Utilities
>         SET FDOTHIRDPARTY=[FDO OpenSource]\ThirdParty
>         SET XALANROOT=%FDOTHIRDPARTY%\apache\xml-xalan\c
>         SET XERCESCROOT=%FDOTHIRDPARTY%\apache\xml-xerces\c
>         SET NLSDIR=%XALANROOT%\Src\xalanc\NLS
> Q: What is variable and what is value? For example? Is FDO variable
> and [FDO OpenSource]\Fdo value? Is that correct?
> *From:* Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> *Sent:* 15. rujan 2006 17:30
> *To:* users at mapguide.osgeo.org
> *Subject:* RE: [mapguide-users] POOL:DWF or AJAX
> I don't think that it's published anywhere in an easy-to-read format.
> You can either mine the Project Tracker (this is used extensively) for
> items with a target release of 1.0.2:
> https://mapguide.osgeo.org/servlets/Scarab
> or search through the Issues or Commits mailing lists depending on the
> amount of detail you want:
> https://mapguide.osgeo.org/servlets/SummarizeList?listName=issues
> https://mapguide.osgeo.org/servlets/SummarizeList?listName=commits
> Jason
> *From:* Ivan Miličević [mailto:ivan at ineo.hr]
> *Sent:* Friday, September 15, 2006 08:17
> Jason, where can i find a list of changes from 1.0.1. until today
> (talking about mapguides server)?
> *Sent:* 15. rujan 2006 17:09
> You can actually use these tools in conjunction.  I have both
> installed, and will sometimes use the Tortoise tool when I know a
> single file has changed and I don't want to go through the whole
> process.  However, I prefer the commandline tools because they allow
> me to script the update/export/build process.  My process is something
> like:
> - Update FDO (using a version of the batch file provided in the
> repository, changed from checkout to update)
> - Export FDO to a build directory
> - Build FDO third party tools
> - Build FDO
> - Update MapGuide
> - Export MapGuide to a build directory
> - Install FDO into the MapGuide OEM structure
> - Build MapGuide
> - Transfer MapGuide to my VMWare server.
> With command line tools, I've been able to script most of this, with
> the exception of building MapGuide.
> Ivan, you've probably figured this out from the path that Kenneth
> provided, but this is the command to check out MapGuide
> svn checkout https://mapguide.osgeo.org/svn/mapguide/trunk/MgDev
> "D:\OSGeo\MGDev" --username YourOSGeoID --password YourOSGeoPwd
> Jason
> *From:* Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
> *Sent:* Friday, September 15, 2006 07:26
> *Subject:* Re: [mapguide-users] POOL:DWF or AJAX
> If you feel uncomfortable using commandline tools, I would recommend
> that you try
> TortoiseSVN, which is an Explorer extension.
> http://tortoisesvn.tigris.org/
> That way, you can check out, or update simply by right clicking on the
> folder in Explorer.
> Using this approach, you only need the URL of the repository, which
> can be found on the osgeo website under "Subversion".
> FDO: https://fdo.osgeo.org/svn/fdo/trunk
> MapGuide: |https://mapguide.osgeo.org/svn/mapguide/trunk|
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
