[MapProxy-dev] MapProxy PSC, RFCs and GitHub PR
Oliver Tonnhofer olt at omniscale.de
Wed May 13 05:10:04 PDT 2020
Hi everyone,
sorry for the slow progress on the PSC.
I'm happy that we now have a list of seven candidates for the PSC. All of you are long time users of MapProxy and most of you also contributed in the past. So far we have:
Denis Rykov
Johannes Weskamm
Just van den Broecke
Matt Walker
Oliver Tonnhofer
Ramūnas Dronga
Tom Kralidis
Maybe you can all introduce yourself with 2-3 sentences on how you are using MapProxy, your affiliation with a company that uses MapProxy, do you have any plans within your PSC membership?
Next step is, that we all agree on the PSC guidelines. Please take a look at https://github.com/mapproxy/mapproxy/wiki/PSC-Guidelines which is more a less a copy of the guidelines from MapServer, OpenLayers and PyGeoAPI.
Make sure you all understood the responsibilities: https://github.com/mapproxy/mapproxy/wiki/PSC-Guidelines#membership-responsibilities
The only major change is that I increased the review period from two days to five business days. I think two days is quite short. (Minor changes aren't affected by the voting process anyways and a revert is just one command away.)
I'm also not sure how we should handle GitHub issues & pull requests? Do we want to keep all discussion on this list? Do we want an RFC for each PR? Would be it be OK if the PR is the RFC and we only vote on the mailing list? Should we just add a PR template [0] and mention that they should write to the mailing list if they want to bring this PR forward? (Otherwise they would need to wait till one of us is enough interested in the PR to make an RFC on their own.)
I'm quite open to all of these options.
[0] https://help.github.com/en/github/building-a-strong-community/creating-a-pull-request-template-for-your-repository
Regards,
Oliver
Oliver Tonnhofer  | Omniscale GmbH & Co KG  | https://omniscale.com
OpenStreetMap WMS and tile services         | https://maps.omniscale.com
More information about the MapProxy-dev mailing list
