[MapProxy-dev] PSC Voting required - Plugin infrastructure
Tobias Wendorff tobias.wendorff at tu-dortmund.de
Wed Mar 23 01:27:06 PDT 2022
I'm not a PSC, but have a question to this (I'd give a +1).
MapProxy has always lacked the ability to access GDAL raster datasets
directly, e.g. GeoTIFF/COG or PDF (GeoPDF or via VRT). This required
external services (e.g. a WMS) or custom code.
Since HIPS service seems to use GDAL, couldn't these bindings be
provided as additional input source? For some projects this would open
up completely new possibilities: you could simply add a raster dataset
in YAML and use it in MapProxy.
Best regards,
Tobias
Am 22.03.2022 um 13:45 schrieb Johannes Weskamm:
> Recently I've done an exploratory work for CNES to add new capabilities
> to MapProxy, to add the support for a new standard, called HIPS, used by
> the planetology and astronomy communities, as a MapProxy source and
> service, and bridging with the traditional OGC protocols (WMS, WMTS...):
> that is e.g. exposing a WMS source as a HIPS service, and vice-verca.
More information about the MapProxy-dev mailing list
