[MapProxy-dev] Contributing to MapProxy
Tom Kralidis tomkralidis at gmail.com
Fri Nov 24 04:24:29 PST 2023
Johannes: thanks for this analysis, good ideas here!
If I understand correctly, this means that a MapProxy cache is already
seeded, and a pygeoapi MapProxy tile provider would translate the OGC API -
Tiles requests into the given MapProxy cache.
pygeoapi could then define such a provider with:
providers:    - type: tile      name: MapProxyCache      data:
/path/to/cache.gpkg
      options:          metadata_format: default          zoom:
      min: 0              max: 5          schemes:              -
WorldCRS84Quad
          type: geopackage
          table_name: tiles_table      format:          name: png
    mimetype: image/png
Another interesting option would be to have a pygeoapi MapProxy
lazy-caching option (where tiles are generated as needed).  Of course, this
would require more configuration on the underlying service(s) to be cached
by MapProxy.
Thanks
..Tom
On Fri, Nov 24, 2023 at 4:02 AM Johannes Weskamm via MapProxy-dev <
mapproxy-dev at lists.osgeo.org> wrote:
> Hi,
> So here are my first findings on the topic of OGC API and pygeoapi.
> You can already publish cached WMS that come from MapProxy through
> pygeoapi via OGC API Map (
> https://docs.pygeoapi.io/en/stable/data-publishing/ogcapi-maps.html).
> I think that is a bit inefficient, as OGC API Tiles could potentially
> access the tiles directly as they have been stored in the chosen MapProxy
> backend (mbtiles, files, ...).
> So in order to avoid the image assembling and rescaling in mapproxy (and
> do it in the client instead, which may not perform better, maybe even
> worse), support for those tile backends need to be implemented in pygeoapi.
> Currently the only provider for OGC API Tiles in pygeoapi seems to be the
> MVT-Provider, which obviously does not work with mapproxy. So a provider /
> reader like mbtiles, xyz structures or similar for non vector data needs to
> be implemented. Some things do exists in pygeoapi which should help to get
> on the train quickly.
> I think that an implementation in pygeoapi would solve your needs most
> efficient.
> Afterwards we could provide documentation and examples how to use MapProxy
> and pygeoapi together to be OGC-API comaptible.
> My 2 cents,
> Greetings,
> Johannes
> Am 22.11.23 um 16:18 schrieb Johannes Weskamm:
> Hi,
> This sounds very good in my opinion! Having OGC API Support in MapProxy
> would be a really nice feature and enable MapProxy to catch up with the
> future of OGC Standards.
> In general, Pull Request are always welcome and the features you mentioned
> sound interesting, so i see no obvious reasons that would block your
> contributions.
> Some bigger goals, like OGC API Support, would need some discussion before
> starting with development. Before reinventing the wheel one should examine
> what pygeoapi has to offer.
> The current documentation (
> https://docs.pygeoapi.io/en/stable/data-publishing/ogcapi-tiles.html)
> even mentions MapProxy as a possible data source, but the examples are
> lacking, so i am not sure if support already exists or needs to be done.
> But even if its still missing, i guess it would be the more elegant way to
> use pygeoapi together with mapproxy or implement and extend the relevant
> classes, as the main thing is already done in pygeoapi and updated
> regularly.
> I may find some time in the upcoming weeks to shed some more light on that.
> I am also interested what other people think about that.
> Greetings,
> Johannes
> Am 13.11.23 um 09:52 schrieb Alistair Everett via MapProxy-dev:
> Hi all,
> At the Norwegian Meteorological Institute we're considering using MapProxy
> to provide model and other map based data to some of our frontend services.
> I'm aware we've been somewhat involved with MapProxy before and used it for
> some of our services, unfortunately most of those involved aren't working
> here anymore so we're looking at building from scratch and modernising our
> services. First with a new WMS offering, but we would also like to be able
> to provide OGC API endpoints in the future.
> There are a couple of features which we would be interested in having in
> MapProxy, particularly related to dimensions - for example, other forms of
> caching (S3 and mbtiles), seeding, and potentially reading available
> dimensions from WMS sources. I know some of these features are available as
> standard but I believe they currently don't necessarily work with
> dimensions. As part of this project I'm hoping that we will have some
> developer time to put into this, so I'm interested in hearing what the
> community thinks of this, how it might fit in with any roadmap the MapProxy
> community might already have, and if you are open to us submitting our own
> MRs for these features?
> I'm also interested in what the community thinks of OGC-API endpoints, do
> you see this as something which MapProxy would like to offer, if the
> resources were available to develop it? Or do you see this as something
> which would rather be offered through other packages, for example pygeoapi
> with MapProxy providing a tile cache in the background?
> Interested to hear your thoughts,
> Kind regards,
> Alistair
> *Dr Alistair Everett*
> Senioringeniør / Senior Software Engineer
> Avdeling for Geoutvikling
> *Phone:* +47 939 68 985
> *Email:* alistair.everett at met.no <alistaire at met.no>
> *Meteorologisk Institutt*,
> Henrik Mohns plass 1,
> 0313 Oslo
> MapProxy-dev mailing listMapProxy-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapproxy-dev
> Dipl.-Geogr. Johannes Weskamm
>   — Anwendungsentwickler —
>   terrestris GmbH & Co. KG
>   Kölnstraße 99
>   53111 Bonn
>   Tel: +49 (0)228 / 96 28 99 -51
>   Fax: +49 (0)228 / 96 28 99 -57
>   Email: weskamm at terrestris.de
>   Web: https://www.terrestris.de
>   Amtsgericht Bonn, HRA 6835
>   Komplementärin: terrestris Verwaltungsgesellschaft mbH
>   vertreten durch: Torsten Brassat, Marc Jansen
>   Informationen über Ihre gespeicherten Daten finden Sie auf
>   unserer Homepage unter folgendem Link:
>   https://www.terrestris.de/datenschutzerklaerung/
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20231124/03ae32e6/attachment-0001.htm>
More information about the MapProxy-dev mailing list
