[mapserver-announce] 7.6.3 released - includes important security fix
Steve Lime sdlime at gmail.com
Fri Apr 30 15:55:10 PDT 2021
The MapServer team is pleased (kinda) to announce the 7.6.3 security
and maintenance release.
Importantly, this release addresses a flaw, discovered by project
developers, in MapServer CGI mapfile loading that makes it possible to
bypass security controls (ticket #6313). This flaw makes it difficult
to easily limit where MapServer can load a mapfile from and affects
versions 4.10 and later. This is a critical issue and all users are
encouraged to update as soon as possible.
What does this mean for you?
   1. If you've not used MS_MAP_PATTERN or MS_MAP_NO_PATH as part of
securing your installation then this doesn't have much impact since
you're not using the controls. That said, this is a critical
configuration step and you should upgrade and make use of those
controls to limit where mapfiles can be accessed.
   2. If you've relied on MS_MAP_PATTERN exclusively, you should
upgrade and be in good shape. However, it's a great time to review and
test MS_MAP_PATTERN.
   3. If you've relied on MS_MAP_NO_PATH primarily (like me), you
should upgrade and set a value for MS_MAP_PATTERN.
We are simultaneously releasing versions 7.0.8, 7.2.3 and 7.4.5 as
well. Updates to binary distributions will follow ASAP.
For the list of additional changes see the Changelog at
https://mapserver.org/development/changelog/changelog-7-6.html
Or head to Download at https://mapserver.org/download.html
For those wanting searchable offline documentation, the updated PDF is
available at https://download.osgeo.org/mapserver/docs/MapServer.pdf
The MapServer Team
URL: <http://lists.osgeo.org/pipermail/mapserver-announce/attachments/20210430/6b61111e/attachment.html>
More information about the mapserver-announce mailing list
