[mapserver-commits] r7136 - trunk/mapserver
Sat Dec 1 17:01:58 EST 2007
Author: tomkralidis
Date: 2007-12-01 17:01:58 -0500 (Sat, 01 Dec 2007)
New Revision: 7136
   trunk/mapserver/mapgml.c
   trunk/mapserver/mapogcsos.c
   trunk/mapserver/mapowscommon.c
Fix memory allocation / freeing issues (#2412)
Modified: trunk/mapserver/mapgml.c
--- trunk/mapserver/mapgml.c	2007-12-01 21:59:39 UTC (rev 7135)
+++ trunk/mapserver/mapgml.c	2007-12-01 22:01:58 UTC (rev 7136)
@@ -1639,6 +1639,7 @@
   pszTmp = msStringConcatenate(pszTmp, msDoubleToString(y));
   psSubNode = xmlNewChild(psNode, NULL, BAD_CAST "pos", BAD_CAST pszTmp);
+  free(pszTmp);
   return psNode;
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2007-12-01 21:59:39 UTC (rev 7135)
+++ trunk/mapserver/mapogcsos.c	2007-12-01 22:01:58 UTC (rev 7136)
@@ -75,14 +75,22 @@
 static int msSOSException(mapObj *map, char *locator, char *exceptionCode) {
+  int size = 0;
+  char *errorString     = NULL;
+  char *errorMessage    = NULL;
+  char *schemasLocation = NULL;
   xmlDocPtr  psDoc      = NULL;
   xmlNodePtr psRootNode = NULL;
   xmlChar *buffer       = NULL;
-  int size = 0;
+  errorString = msGetErrorString("\n");
+  errorMessage = msEncodeHTMLEntities(errorString);
+  schemasLocation = msEncodeHTMLEntities(msOWSGetSchemasLocation(map));
   psDoc = xmlNewDoc(BAD_CAST "1.0");
-  psRootNode = msOWSCommonExceptionReport(msEncodeHTMLEntities(msOWSGetSchemasLocation(map)), pszSOSVersion, msOWSGetLanguage(map, "exception"), exceptionCode, locator, msEncodeHTMLEntities(msGetErrorString("\n")));
+  psRootNode = msOWSCommonExceptionReport(schemasLocation, pszSOSVersion, msOWSGetLanguage(map, "exception"), exceptionCode, locator, errorMessage);
   xmlDocSetRootElement(psDoc, psRootNode);
   xmlSetNs(psRootNode,  xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX));
@@ -93,6 +101,9 @@
   msIO_printf("%s", buffer);
   /*free buffer and the document */
+  free(errorString);
+  free(errorMessage);
+  free(schemasLocation);
   xmlFree(buffer);
   xmlFreeDoc(psDoc);
@@ -339,13 +350,10 @@
                 else
                   xmlNewNsProp(psNode, NULL, BAD_CAST "name", BAD_CAST lp->items[i]);
-                xmlNewNsProp(psNode,
-                             xmlNewNs(NULL, BAD_CAST "http://www.w3.org/1999/xlink",
-                                      BAD_CAST "xlink"),
-                             BAD_CAST "href", BAD_CAST pszValue);
+                //xmlNewNsProp(psNode, xmlNewNs(NULL, BAD_CAST "http://www.w3.org/1999/xlink", BAD_CAST "xlink"), BAD_CAST "href", BAD_CAST pszValue);
+                xmlNewNsProp(psNode, psNsXLink, BAD_CAST "href", BAD_CAST pszValue);
@@ -537,9 +545,8 @@
 /*      Add a databalock used for GetObservation request.               */
-void msSOSAddDataBlockDefinition(xmlNodePtr psParent, layerObj *lp)
+void msSOSAddDataBlockDefinition(xmlNsPtr psNsSwe, xmlNodePtr psParent, layerObj *lp)
-    xmlNsPtr psNsSwe = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/swe", BAD_CAST "swe");
     xmlNodePtr psNode, psRecordNode, psCompNode, psSubNode, psEncNode;
     const char *pszDefinition = NULL, *pszUom=NULL, *pszValue=NULL, *pszName=NULL;
     char szTmp[100];
@@ -646,10 +653,10 @@
 /*      Assuming that the layer is opened and msLayerGetItems is        */
 /*      called on it.                                                   */
-void msSOSAddMemberNode(xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNodePtr psParent, mapObj *map, layerObj *lp,
+void msSOSAddMemberNode(xmlNsPtr psNsGml, xmlNsPtr psNsOm, xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNodePtr psParent, mapObj *map, layerObj *lp,
                         int iFeatureId)
-    xmlNodePtr psObsNode, psNode, psSubNode, psLayerNode;
+    xmlNodePtr psObsNode, psNode, psSubNode, psLayerNode = NULL;
     const char *pszEpsg = NULL, *pszValue = NULL;
     int status,i,j;
     shapeObj sShape;
@@ -661,9 +668,6 @@
     char *pszValueShape = NULL;
     const char *pszFeatureId  = NULL;
-    xmlNsPtr psNsGml = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/gml", BAD_CAST "gml");
-    xmlNsPtr psNsOm = xmlNewNs(NULL, BAD_CAST pszOMNamespaceUri, BAD_CAST pszOMNamespacePrefix);
     if (psParent)
         msInitShape(&sShape);
@@ -672,7 +676,6 @@
                                  lp->resultcache->results[iFeatureId].tileindex,
                                  lp->resultcache->results[iFeatureId].shapeindex);
         if(status != MS_SUCCESS) {
-          xmlFreeNs(psNsGml);
           xmlFreeNs(psNsOm);
           return;
@@ -735,9 +738,8 @@
                     pszTmp = msStringConcatenate(pszTmp, pszValueShape);
                         psNode =  xmlNewChild(psObsNode, NULL, BAD_CAST "procedure", NULL);
-                                              BAD_CAST "xlink"), BAD_CAST "href", BAD_CAST pszTmp);
+                        //xmlNewNsProp(psNode, xmlNewNs(NULL, BAD_CAST "http://www.w3.org/1999/xlink", BAD_CAST "xlink"), BAD_CAST "href", BAD_CAST pszTmp);
+                        xmlNewNsProp(psNode, psNsXLink, BAD_CAST "href", BAD_CAST pszTmp);
                         msFree(pszTmp);
                         pszTmp = NULL;
                         msFree(pszValueShape);
@@ -754,9 +756,8 @@
             pszTmp = msStringConcatenate(pszTmp, (char *)pszValue);
             msFree(pszTmp);
             pszTmp = NULL;
@@ -970,8 +971,6 @@
     return pszFinalValue;
@@ -980,7 +979,7 @@
 /*      Add a member node used gor getObservation request using         */
 /*      Observation as the result format.                               */
-xmlNodePtr msSOSAddMemberNodeObservation(xmlNodePtr psParent, mapObj *map,
+xmlNodePtr msSOSAddMemberNodeObservation(xmlNsPtr psNsGml, xmlNsPtr psNsSos, xmlNsPtr psNsSwe, xmlNsPtr psNsXLink, xmlNodePtr psParent, mapObj *map,
                                          layerObj *lp, const char *pszProcedure)
     char *pszTmp = NULL;
@@ -988,12 +987,6 @@
     layerObj *lpfirst;
     const char *value = NULL;
-    //xmlNsPtr psNsOm = xmlNewNs(NULL, BAD_CAST pszOMNamespaceUri, BAD_CAST pszOMNamespacePrefix);
-    xmlNsPtr psNsSos = xmlNewNs(NULL, BAD_CAST pszSOSNamespaceUri, BAD_CAST pszSOSNamespacePrefix);
-    xmlNsPtr psNsXLink = xmlNewNs(NULL, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
     /*always featch the first layer that has the same offering id and observered propery.
      This allows to only define all the attributes and componenets on the first layer if the user
     wants to present several mapserver layers as the same offering.*/
@@ -1039,8 +1032,8 @@
              pszTmp = msStringConcatenate(pszTmp, "urn:ogc:def:procedure:");
              pszTmp = msStringConcatenate(pszTmp, (char *)pszProcedure);
-             xmlNewNsProp(psNode, xmlNewNs(NULL, BAD_CAST "http://www.w3.org/1999/xlink",
              msFree(pszTmp);
              pszTmp = NULL;
@@ -1058,7 +1051,7 @@
          /* result definition*/
          psNode = xmlNewChild(psObsNode, NULL, BAD_CAST "resultDefinition", NULL);
-         msSOSAddDataBlockDefinition(psNode, lpfirst);
+         msSOSAddDataBlockDefinition(psNsSwe, psNode, lpfirst);
@@ -1138,7 +1131,7 @@
+    free(psRoot);
     return pszReturn;
@@ -1518,7 +1511,6 @@
                                    if (papsProcedures[k] != NULL)
                                      msFree(papsProcedures[k]);
                                  msFree(papsProcedures);
                                  msLayerClose(lpTmp);
@@ -1668,6 +1660,9 @@
      xmlFreeNs(psNsOgc);
      xmlFreeNs(psNsSwe);
+     free(script_url);
+     free(script_url_encoded);
      free(xsi_schemaLocation);
      free(schemalocation);
@@ -1733,6 +1728,7 @@
   xmlNsPtr psNsOm = NULL;
   xmlNsPtr psNsSwe = NULL;
   xmlNsPtr psNsXLink = NULL;
+  xmlNsPtr psNsSos = NULL;
   char *pszBuffer = NULL;
   const char *pszProcedureItem = NULL;
   int bSpatialDB = 0;
@@ -1749,6 +1745,7 @@
   sBbox = map->extent;
+  psNsSos = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/sos/1.0", BAD_CAST "sos");
@@ -2010,6 +2007,8 @@
           msLayerClose(lp);
         FLTApplyFilterToLayer(psFilterNode, map, i, MS_FALSE);
+        msFree(psFilterNode);
@@ -2140,7 +2139,7 @@
     xmlNewNsProp(psRootNode, psNsGml, BAD_CAST "id", BAD_CAST sosparams->pszOffering);
     /*schema fixed*/
-    schemalocation = msEncodeHTMLEntities( msOWSGetSchemasLocation(map) );
+    schemalocation = msEncodeHTMLEntities(msOWSGetSchemasLocation(map));
     /*TODO : review this*/
     xsi_schemaLocation = strdup("http://www.opengis.net/om ");
     xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, schemalocation);
@@ -2230,7 +2229,7 @@
                     for(j=0; j<GET_LAYER(map, i)->resultcache->numresults; j++)
-                        msSOSAddMemberNode(psNsSwe, psNsXLink, psRootNode, map, (GET_LAYER(map, i)), j);
+                        msSOSAddMemberNode(psNsGml, psNsOm, psNsSwe, psNsXLink, psRootNode, map, (GET_LAYER(map, i)), j);
                         if (j == n1-1)
                           break;
@@ -2242,7 +2241,7 @@
                     if (msOWSLookupMetadata(&(GET_LAYER(map, i)->metadata), "S", "procedure_item") == NULL)
                         pszProcedure = msOWSLookupMetadata(&(lp->metadata), "S", "procedure");
-                        psObservationNode = msSOSAddMemberNodeObservation(psRootNode, map, (GET_LAYER(map, i)),
+                        psObservationNode = msSOSAddMemberNodeObservation(psNsGml, psNsSos, psNsSwe, psNsXLink, psRootNode, map, (GET_LAYER(map, i)),
        pszProcedure);
                         /*add a result node*/
                         psResultNode = xmlNewChild(psObservationNode, NULL, BAD_CAST "result", NULL);
@@ -2302,7 +2301,7 @@
        *nDiffrentProc);
                                 paDiffrentProc[nDiffrentProc-1].pszProcedure = strdup(pszProcedureValue);
        pszProcedureValue);
                                 msFree(pszProcedureValue);
@@ -2334,6 +2333,9 @@
      context = msIO_getHandler(stdout);
      xmlDocDumpFormatMemoryEnc(psDoc, &buffer, &size, "ISO-8859-1", 1);
      msIO_contextWrite(context, buffer, size);
+     free(schemalocation);
+     free(xsi_schemaLocation);
+     xmlFreeNs(psNsSos);
      xmlFreeNs(psNsGml);
      xmlFreeNs(psNsOm);
      xmlFreeNs(psNsSwe);
@@ -2501,6 +2503,9 @@
   if (paramsObj->pszService && strcasecmp(paramsObj->pszService, "SOS") == 0) { /* this is an SOS request */
     if (!paramsObj->pszRequest) {
       msSetError(MS_SOSERR, "Missing REQUEST Parameter", "msSOSDispatch()");
+      msSOSFreeParamsObj(paramsObj);
+      free(paramsObj);
+      paramsObj = NULL;
       return msSOSException(map, "request", "MissingParameterValue");
@@ -2516,11 +2521,17 @@
       /* check version */
       if (!paramsObj->pszVersion) {
         msSetError(MS_SOSERR, "Missing VERSION parameter", "msSOSDispatch()");
+        free(paramsObj);
+        paramsObj = NULL;
         return msSOSException(map, "version", "MissingParameterValue");
       if (msOWSParseVersionString(paramsObj->pszVersion) != OWS_1_0_0) {
         msSetError(MS_SOSERR, "VERSION %s not supported.  Supported versions are: %s.", "msSOSDispatch()", paramsObj->pszVersion, pszSOSVersion);
+        free(paramsObj);
+        paramsObj = NULL;
         return msSOSException(map, "version", "InvalidParameterValue");
@@ -2537,6 +2548,9 @@
     else {
       msSetError(MS_SOSERR, "Invalid REQUEST parameter: %s", "msSOSDispatch()", paramsObj->pszRequest);
+      free(paramsObj);
+      paramsObj = NULL;
       return msSOSException(map, "request", "InvalidParameterValue");
@@ -2759,6 +2773,8 @@
 void msSOSFreeParamsObj(sosParamsObj *sosparams) {
   if (sosparams) {
+    if (sosparams->pszService)
+      free(sosparams->pszService);
     if (sosparams->pszVersion)
       free(sosparams->pszVersion);
     if (sosparams->pszUpdateSequence)
Modified: trunk/mapserver/mapowscommon.c
--- trunk/mapserver/mapowscommon.c	2007-12-01 21:59:39 UTC (rev 7135)
+++ trunk/mapserver/mapowscommon.c	2007-12-01 22:01:58 UTC (rev 7136)
@@ -426,13 +426,15 @@
   xmlNodePtr   psMainNode  = NULL;
   xmlNodePtr   psNode      = NULL;
-  psNsOws = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX);
+  //psNsOws = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX);
+  //psNsOws = xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/ows", BAD_CAST "ows");
-  psRootNode = xmlNewNode(psNsOws, BAD_CAST "ExceptionReport");
+  //psRootNode = xmlNewNode(psNsOws, BAD_CAST "ExceptionReport");
+  psRootNode = xmlNewNode(NULL, BAD_CAST "ExceptionReport");
   psNsXsi = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX);
-  xmlSetNs(psRootNode,  psNsOws);
+  //xmlSetNs(psRootNode, psNsOws);
   /* add attributes to root element */
   xmlNewProp(psRootNode, BAD_CAST "version", BAD_CAST version);
@@ -463,7 +465,8 @@
     psNode = xmlNewChild(psMainNode, NULL, BAD_CAST "ExceptionText", BAD_CAST ExceptionText);
-  xmlFreeNs(psNsOws);
+  //xmlFreeNs(psNsOws);
   return psRootNode;
