[mapserver-commits] r7491 - in trunk/mapserver: . rfc
Tue Apr 1 17:34:40 EDT 2008
Author: jlacroix
Date: 2008-04-01 17:34:39 -0400 (Tue, 01 Apr 2008)
New Revision: 7491
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/cgiutil.c
   trunk/mapserver/cgiutil.h
   trunk/mapserver/maphttp.c
   trunk/mapserver/mapows.h
   trunk/mapserver/mapserv.c
   trunk/mapserver/mapwfslayer.c
   trunk/mapserver/mapwmslayer.c
   trunk/mapserver/rfc/ms-rfc-42.txt
RFC-42 HTTP Cookie Forward Initial Revision (#2566)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/HISTORY.TXT	2008-04-01 21:34:39 UTC (rev 7491)
@@ -13,6 +13,8 @@
 Current Version (5.1-dev, SVN trunk):
+- RFC-42 HTTP Cookie Forwarding (#2566)
 - Fixed handling of encrypted connection strings in postgis driver (#2563)
 - mapagg.cpp: AGG: add opacity at the style level (#1155)
Modified: trunk/mapserver/cgiutil.c
--- trunk/mapserver/cgiutil.c	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/cgiutil.c	2008-04-01 21:34:39 UTC (rev 7491)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  cgiRequestObj and CGI parameter parsing.
@@ -202,7 +202,8 @@
   /* check for any available cookies */
   s = getenv("HTTP_COOKIE");
-  if(s != NULL) {
+  if(s != NULL) {
+    request->httpcookiedata = strdup(s);
     for(x=0;s[0] != '\0';x++) {
       if(m >= MS_MAX_CGI_PARAMS) {
         msIO_printf("Too many name/value pairs, aborting.\n");
@@ -396,6 +397,7 @@
   request->type = -1;
   request->contenttype = NULL;
   request->postrequest = NULL;
+  request->httpcookiedata = NULL;
   return request;
@@ -409,8 +411,10 @@
   request->type = -1;
   msFree(request->contenttype);
   msFree(request->postrequest);
+  msFree(request->httpcookiedata);
   msFree(request);
Modified: trunk/mapserver/cgiutil.h
--- trunk/mapserver/cgiutil.h	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/cgiutil.h	2008-04-01 21:34:39 UTC (rev 7491)
@@ -63,6 +63,8 @@
   char *contenttype;
   char *postrequest;
+  char *httpcookiedata;
 } cgiRequestObj;
Modified: trunk/mapserver/maphttp.c
--- trunk/mapserver/maphttp.c	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/maphttp.c	2008-04-01 21:34:39 UTC (rev 7491)
@@ -136,6 +136,7 @@
         pasReqInfo[i].pszContentType = NULL;
         pasReqInfo[i].pszErrBuf = NULL;
         pasReqInfo[i].pszUserAgent = NULL;
+        pasReqInfo[i].pszHTTPCookieData = NULL;
         pasReqInfo[i].debug = MS_FALSE;
@@ -183,6 +184,10 @@
             free(pasReqInfo[i].pszUserAgent);
+        if (pasReqInfo[i].pszHTTPCookieData)
+            free(pasReqInfo[i].pszHTTPCookieData);
         pasReqInfo[i].curl_handle = NULL;
@@ -405,6 +410,29 @@
             curl_easy_setopt(http_handle, CURLOPT_HTTPHEADER, headers);
             /* curl_slist_free_all(headers); */ /* free the header list */
+        /* Added by RFC-42 HTTP Cookie Forwarding */
+        if(pasReqInfo[i].pszHTTPCookieData != NULL)
+            /* Check if there's no end of line in the Cookie string */
+            /* This could break the HTTP Header */
+            int nPos;
+            for(nPos=0; nPos<strlen(pasReqInfo[i].pszHTTPCookieData); nPos++)
+                if(pasReqInfo[i].pszHTTPCookieData[nPos] == '\n')
+                    msSetError(MS_HTTPERR, "Can't open output file %s.",
+                       "msHTTPExecuteRequests()", pasReqInfo[i].pszOutputFile);
+                    return(MS_FAILURE);
+            // Set the Curl option to send Cookie
+            curl_easy_setopt(http_handle, CURLOPT_COOKIE,
+                             pasReqInfo[i].pszHTTPCookieData);
         /* Add to multi handle */
         curl_multi_add_handle(multi_handle, http_handle);
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/mapows.h	2008-04-01 21:34:39 UTC (rev 7491)
@@ -35,6 +35,7 @@
     char    *pszPostRequest;    /* post request content (NULL for GET) */
     char    *pszPostContentType;/* post request MIME type */
     char    *pszUserAgent;      /* User-Agent, auto-generated if not set */
+    char    *pszHTTPCookieData; /* HTTP Cookie data */
     /* For debugging/profiling */
     int         debug;         /* Debug mode?  MS_TRUE/MS_FALSE */
@@ -96,6 +97,7 @@
   char        *onlineresource;
   hashTableObj *params;
   int          numparams;
 } wmsParamsObj;
 int msHTTPInit(void);
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/mapserv.c	2008-04-01 21:34:39 UTC (rev 7491)
@@ -1148,6 +1148,21 @@
 #endif
+     * RFC-42 HTTP Cookie Forwarding
+     * Here we set the http_cookie_data metadata to handle the
+     * HTTP Cookie Forwarding. The content of this metadata is the cookie
+     * content. In the future, this metadata will probably be replaced
+     * by an object that is part of the mapObject that would contain
+     * information on the application status (such as cookie).
+    if( msObj->request->httpcookiedata != NULL &&
+        msOWSLookupMetadata(&(msObj->Map->web.metadata), "OMF", "http_cookie"))
+        msInsertHashTable( &(msObj->Map->web.metadata), "http_cookie_data",
+                           msObj->request->httpcookiedata );
     ** Start by calling the WMS/WFS/WCS Dispatchers.  If they fail then we'll
     ** process this as a regular MapServer request.
Modified: trunk/mapserver/mapwfslayer.c
--- trunk/mapserver/mapwfslayer.c	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/mapwfslayer.c	2008-04-01 21:34:39 UTC (rev 7491)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Purpose:  Implementation of WFS CONNECTIONTYPE - client to WFS servers
@@ -517,6 +517,7 @@
     char *pszHashFileName = NULL;
     int bPostRequest = 0;
     wfsParamsObj *psParams = NULL;
+    char *pszHTTPCookieData = NULL;
     if (lp->connectiontype != MS_WFS || lp->connection == NULL)
@@ -576,6 +577,44 @@
         nTimeout = atoi(pszTmp);
+ * Check to see if there's a HTTP Cookie to forward
+ * If Cookie differ between the two connection, it's NOT OK to merge
+ * the connection
+    if ((pszTmp = msOWSLookupMetadata(&(lp->metadata),
+                                      "MO", "http_cookie")) != NULL)
+        if(strcasecmp(pszTmp, "forward") == 0)
+            pszTmp= msLookupHashTable(&(map->web.metadata),"http_cookie_data");
+            if(pszTmp != NULL)
+                pszHTTPCookieData = strdup(pszTmp);
+        else
+    else if ((pszTmp = msOWSLookupMetadata(&(map->web.metadata),
+        else
  * If nLayerId == -1 then we need to figure it
@@ -624,6 +663,8 @@
         msOWSBuildURLFilename(map->web.imagepath,
                               pszHashFileName,".tmp.gml");
     free(pszHashFileName);
+    pasReqInfo[(*numRequests)].pszHTTPCookieData = pszHTTPCookieData;
+    pszHTTPCookieData = NULL;
     pasReqInfo[(*numRequests)].nStatus = 0;
     pasReqInfo[(*numRequests)].nTimeout = nTimeout;
     pasReqInfo[(*numRequests)].bbox = bbox;
Modified: trunk/mapserver/mapwmslayer.c
--- trunk/mapserver/mapwmslayer.c	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/mapwmslayer.c	2008-04-01 21:34:39 UTC (rev 7491)
@@ -49,6 +49,7 @@
     wmsparams->onlineresource = NULL;
     wmsparams->params = msCreateHashTable();
     wmsparams->numparams=0;
+    wmsparams->httpcookiedata = NULL;
     return MS_SUCCESS;
@@ -66,6 +67,8 @@
     msFreeHashTable(wmsparams->params);
     wmsparams->params = NULL;
+    msFree(wmsparams->httpcookiedata);
@@ -762,7 +765,7 @@
                              httpRequestObj *pasReqInfo, int *numRequests)
 #ifdef USE_WMS_LYR
-    char *pszURL = NULL;
+    char *pszURL = NULL, *pszHTTPCookieData = NULL;
     const char *pszTmp;
     rectObj bbox;
     int nTimeout, bOkToMerge, bForceSeparateRequest;
@@ -885,6 +888,56 @@
+ * the connection
+        else
+        else
+    if(bOkToMerge && pszHTTPCookieData != sThisWMSParams.httpcookiedata)
+        if(pszHTTPCookieData == NULL || sThisWMSParams.httpcookiedata == NULL)
+            bOkToMerge = MS_FALSE;
+        if(strcmp(pszHTTPCookieData, sThisWMSParams.httpcookiedata) != 0)
     if (bOkToMerge)
         /* Merge both requests into sThisWMSParams
@@ -956,6 +1009,8 @@
                        "msPrepareWMSLayerRequest()");
             return MS_FAILURE;
         pasReqInfo[(*numRequests)].pszOutputFile =msTmpFile(map->mappath,
                                                             map->web.imagepath,
                                                             "img.tmp");
Modified: trunk/mapserver/rfc/ms-rfc-42.txt
--- trunk/mapserver/rfc/ms-rfc-42.txt	2008-04-01 18:45:53 UTC (rev 7490)
+++ trunk/mapserver/rfc/ms-rfc-42.txt	2008-04-01 21:34:39 UTC (rev 7491)
@@ -118,13 +118,13 @@
 Bug ID
-None Yet.
+http://trac.osgeo.org/mapserver/ticket/2566
 Voting History
-None Yet.
+Adopted on 2008/04/01 with +1 from FrankW, DanielM, TomK and AssefaY, and +0 from JeffM and PericlesN.
