[mapserver-commits] r7521 - trunk/mapserver
Tue Apr 15 11:39:10 EDT 2008
Author: Assefa
Date: 2008-04-15 11:39:09 -0400 (Tue, 15 Apr 2008)
New Revision: 7521
   trunk/mapserver/mapogcfilter.c
   trunk/mapserver/mapogcfilter.h
   trunk/mapserver/mapogcsos.c
   trunk/mapserver/mapwfs.c
Fix WFS quey usied aliased gml names (#2580)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2008-04-14 15:29:38 UTC (rev 7520)
+++ trunk/mapserver/mapogcfilter.c	2008-04-15 15:39:09 UTC (rev 7521)
@@ -1555,9 +1555,9 @@
                 /*FE 1.0 used box FE1.1 uses envelop*/
                 if (psBox)
-                  bCoordinatesValid = FTLParseGMLBox(psBox, &sBox, &pszSRS);
+                  bCoordinatesValid = FLTParseGMLBox(psBox, &sBox, &pszSRS);
                 else if ((psEnvelope = CPLGetXMLNode(psXMLNode, "Envelope")))
-                  bCoordinatesValid = FTLParseGMLEnvelope(psEnvelope, &sBox, &pszSRS);
+                  bCoordinatesValid = FLTParseGMLEnvelope(psEnvelope, &sBox, &pszSRS);
                 if (psPropertyName == NULL || !bCoordinatesValid)
                   psFilterNode->eType = FILTER_NODE_TYPE_UNDEFINED;
@@ -3737,11 +3737,11 @@
-/*                              FTLParseGMLBox                          */
+/*                              FLTParseGMLBox                          */
 /*      Parse gml box. Used for FE 1.0                                  */
-int FTLParseGMLBox(CPLXMLNode *psBox, rectObj *psBbox, char **ppszSRS)
+int FLTParseGMLBox(CPLXMLNode *psBox, rectObj *psBbox, char **ppszSRS)
     int bCoordinatesValid = 0;
     CPLXMLNode *psCoordinates = NULL, *psCoordChild=NULL;
@@ -3849,11 +3849,11 @@
     return bCoordinatesValid;
-/*                           FTLParseGMLEnvelope                        */
+/*                           FLTParseGMLEnvelope                        */
 /*      Utility function to parse a gml:Enevelop (used for SOS and FE1.1)*/
-int FTLParseGMLEnvelope(CPLXMLNode *psRoot, rectObj *psBbox, char **ppszSRS)
+int FLTParseGMLEnvelope(CPLXMLNode *psRoot, rectObj *psBbox, char **ppszSRS)
     CPLXMLNode *psChild=NULL;
     CPLXMLNode *psUpperCorner=NULL, *psLowerCorner=NULL;
@@ -3932,6 +3932,60 @@
+static void FLTReplacePropertyName(FilterEncodingNode *psFilterNode,
+                                   const char *pszOldName, char *pszNewName)
+    if (psFilterNode && pszOldName && pszNewName)
+        if (psFilterNode->eType == FILTER_NODE_TYPE_PROPERTYNAME)
+            if (psFilterNode->pszValue &&
+                strcasecmp(psFilterNode->pszValue, pszOldName) == 0)
+                msFree(psFilterNode->pszValue);
+                psFilterNode->pszValue = strdup(pszNewName);
+        if (psFilterNode->psLeftNode)
+          FLTReplacePropertyName(psFilterNode->psLeftNode, pszOldName,
+                                   pszNewName);
+        if (psFilterNode->psRightNode)
+          FLTReplacePropertyName(psFilterNode->psRightNode, pszOldName,
+                                 pszNewName);
+void FLTPreParseFilterForAlias(FilterEncodingNode *psFilterNode,
+                               mapObj *map, int i, const char *namespaces)
+    layerObj *lp=NULL;
+    char szTmp[256];
+    const char *pszFullName = NULL;
+    if (psFilterNode && map && i>=0 && i<map->numlayers)
+        lp = GET_LAYER(map, i);
+        if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS)
+            for(i=0; i<lp->numitems; i++)
+                if (!lp->items[i] || strlen(lp->items[i]) <= 0)
+                    continue;
+                sprintf(szTmp, "%s_alias", lp->items[i]);
+                pszFullName = msOWSLookupMetadata(&(lp->metadata), namespaces, szTmp);
+                if (pszFullName)
+                    FLTReplacePropertyName(psFilterNode, pszFullName,
+                                           lp->items[i]);
+            msLayerClose(lp);
 #ifdef USE_LIBXML2
 xmlNodePtr FLTGetCapabilities(xmlNsPtr psNsParent, xmlNsPtr psNsOgc, int bTemporal)
Modified: trunk/mapserver/mapogcfilter.h
--- trunk/mapserver/mapogcfilter.h	2008-04-14 15:29:38 UTC (rev 7520)
+++ trunk/mapserver/mapogcfilter.h	2008-04-15 15:39:09 UTC (rev 7521)
@@ -121,13 +121,17 @@
 MS_DLL_EXPORT FilterEncodingNode *FLTCreateFeatureIdFilterEncoding(char *pszString);
-MS_DLL_EXPORT int FTLParseGMLEnvelope(CPLXMLNode *psRoot, rectObj *psBbox, char **ppszSRS);
-MS_DLL_EXPORT  int FTLParseGMLBox(CPLXMLNode *psBox, rectObj *psBbox, char **ppszSRS);
+MS_DLL_EXPORT int FLTParseGMLEnvelope(CPLXMLNode *psRoot, rectObj *psBbox, char **ppszSRS);
+MS_DLL_EXPORT  int FLTParseGMLBox(CPLXMLNode *psBox, rectObj *psBbox, char **ppszSRS);
 #ifdef USE_LIBXML2
 MS_DLL_EXPORT xmlNodePtr FLTGetCapabilities(xmlNsPtr psNsParent, xmlNsPtr psNsOgc, int bTemporal);
 #endif
+                               mapObj *map, int i, const char *namespaces);
 #endif
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2008-04-14 15:29:38 UTC (rev 7520)
+++ trunk/mapserver/mapogcsos.c	2008-04-15 15:39:09 UTC (rev 7521)
@@ -29,6 +29,7 @@
 #include "mapserver.h"
 MS_CVSID("$Id$")
 #if defined(USE_SOS_SVR) && defined(USE_LIBXML2)
@@ -168,57 +169,8 @@
     return MS_TRUE;
-static void msSOSReplacePropertyName(FilterEncodingNode *psFilterNode,
-                                     const char *pszOldName, char *pszNewName)
-    if (psFilterNode && pszOldName && pszNewName)
-        if (psFilterNode->eType == FILTER_NODE_TYPE_PROPERTYNAME)
-            if (psFilterNode->pszValue &&
-                strcasecmp(psFilterNode->pszValue, pszOldName) == 0)
-                msFree(psFilterNode->pszValue);
-                psFilterNode->pszValue = strdup(pszNewName);
-        if (psFilterNode->psLeftNode)
-          msSOSReplacePropertyName(psFilterNode->psLeftNode, pszOldName,
-                                   pszNewName);
-        if (psFilterNode->psRightNode)
-          msSOSReplacePropertyName(psFilterNode->psRightNode, pszOldName,
-                                   pszNewName);
-static void msSOSPreParseFilterForAlias(FilterEncodingNode *psFilterNode,
-                                        mapObj *map, int i)
-    layerObj *lp=NULL;
-    char szTmp[256];
-    const char *pszFullName = NULL;
-    if (psFilterNode && map && i>=0 && i<map->numlayers)
-        lp = GET_LAYER(map, i);
-        if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS)
-            for(i=0; i<lp->numitems; i++)
-                if (!lp->items[i] || strlen(lp->items[i]) <= 0)
-                    continue;
-                sprintf(szTmp, "%s_alias", lp->items[i]);
-                pszFullName = msOWSLookupMetadata(&(lp->metadata), "S", szTmp);
-                if (pszFullName)
-                    msSOSReplacePropertyName(psFilterNode, pszFullName,
-                                             lp->items[i]);
-            msLayerClose(lp);
 /*                        msSOSAddMetadataChildNode                     */
@@ -2069,7 +2021,7 @@
     CPLStripXMLNamespace(psRoot, "gml", 1);
-    bValid = FTLParseGMLEnvelope(psRoot, &sBbox, &pszSRS);
+    bValid = FLTParseGMLEnvelope(psRoot, &sBbox, &pszSRS);
     /*TODO we should reproject the bbox to the map projection if there is an srs defined*/
     if (!bValid) {
@@ -2096,7 +2048,7 @@
       if (lp->status == MS_ON) {
         //preparse parser so that alias for fields can be used
-        msSOSPreParseFilterForAlias(psFilterNode, map, i);
+        FLTPreParseFilterForAlias(psFilterNode, map, i, "S");
         //vaidate that the property names used are valid
         //(there is a corresponding layer attribute)
         if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS) {
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2008-04-14 15:29:38 UTC (rev 7520)
+++ trunk/mapserver/mapwfs.c	2008-04-15 15:39:09 UTC (rev 7521)
@@ -1283,6 +1283,9 @@
 	  return msWFSException(map, "filter", "InvalidParameterValue", paramsObj->pszVersion);
+        /*preparse the filter for gml aliases*/
+        FLTPreParseFilterForAlias(psNode, map, iLayerIndex, "G");
 	if( FLTApplyFilterToLayer(psNode, map, iLayerIndex, MS_FALSE) != MS_SUCCESS ) {
           msSetError(MS_WFSERR, "FLTApplyFilterToLayer() failed", "msWFSGetFeature()", pszFilter);
 	  return msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
