[mapserver-commits] r7537 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Apr 27 02:33:51 EDT 2008
Author: pramsey
Date: 2008-04-27 02:33:50 -0400 (Sun, 27 Apr 2008)
New Revision: 7537
trunk/mapserver/mapbits.c
Simpler and slightly less efficient msGetNextBit, hopefully without bad end conditions this time.
Modified: trunk/mapserver/mapbits.c
--- trunk/mapserver/mapbits.c 2008-04-27 05:58:41 UTC (rev 7536)
+++ trunk/mapserver/mapbits.c 2008-04-27 06:33:50 UTC (rev 7537)
@@ -60,42 +60,28 @@
** If hits end of bitmap without finding set bit, will return -1.
-int msGetNextBit(char *array, int index, int size) {
+int msGetNextBit(char *array, int i, int size) {
- char *ptr;
- int i = 0;
- ptr = array;
- ptr += index / CHAR_BIT;
- /* Check the starting byte for set bits, if necessary. */
- if(*ptr) {
- /* a bit in this byte is set, figure out which one */
- for( i = index; i < index + CHAR_BIT - (index % CHAR_BIT); i++ ) {
- if ( msGetBit( array, i ) )
+ while(i < size) {
+ if( (i % CHAR_BIT) || *(array + (i/CHAR_BIT)) ) {
+ /* There is something in this byte */
+ if( msGetBit( array, i ) ) {
return i;
+ else {
+ i++;
- /* scroll forwards bytewise to the next byte with a bit set */
- do {
- ptr++;
- } while( ((CHAR_BIT * (ptr - array)) < size) && *ptr == 0 ) ;
- /* check the first non-zero byte for the location of the set bit */
- if( *ptr ) {
- for( i = CHAR_BIT * (ptr - array); i < CHAR_BIT * (ptr - array) + CHAR_BIT; i++ ) {
- return i;
+ else {
+ /* Nothing in this byte, move on */
+ i += CHAR_BIT;
- /* got to the last byte with no hits! */
+ /* Got to the last byte with no hits! */
return -1;
void msSetBit(char *array, int index, int value)
array += index / CHAR_BIT;
More information about the mapserver-commits
