[mapserver-commits] r7539 - branches/branch-5-0/mapserver
Sun Apr 27 16:03:19 EDT 2008
Author: pramsey
Date: 2008-04-27 16:03:19 -0400 (Sun, 27 Apr 2008)
New Revision: 7539
   branches/branch-5-0/mapserver/HISTORY.TXT
   branches/branch-5-0/mapserver/mappostgis.c
Fixed overlapping transaction behavior, which causes fcgi failures. (#2497) Patch from David Fuhry.
Modified: branches/branch-5-0/mapserver/HISTORY.TXT
--- branches/branch-5-0/mapserver/HISTORY.TXT	2008-04-27 07:14:40 UTC (rev 7538)
+++ branches/branch-5-0/mapserver/HISTORY.TXT	2008-04-27 20:03:19 UTC (rev 7539)
@@ -13,6 +13,9 @@
 Current Version (future 5.0.3, svn branch-5-0)
+- mappostgis.c: Fixed overlapping transactions causing core
+  dump in fcgi (#2497)
 - mapagg.cpp: Fixed rendering of non filled vector symbols (#2585)
 - Fixed handling of encrypted connection strings in postgis driver (#2563)
Modified: branches/branch-5-0/mapserver/mappostgis.c
--- branches/branch-5-0/mapserver/mappostgis.c	2008-04-27 07:14:40 UTC (rev 7538)
+++ branches/branch-5-0/mapserver/mappostgis.c	2008-04-27 20:03:19 UTC (rev 7539)
@@ -165,6 +165,78 @@
     PQfinish((PGconn*) conn_handle);
+/* takes a connection and ensures that it is in a valid transactional state */
+/* performing PQreset(), ROLLBACK, and/or BEGIN on it as necessary */
+int msPOSTGISSanitizeConnection(PGconn *conn)
+    int conn_bad = 0;
+    if (PQstatus(conn) == CONNECTION_BAD)
+        msDebug("Warning: resetting bad database connection due to PQstatus(conn) == CONNECTION_BAD in msPOSTGISSanitizeConnection()\n");
+        conn_bad = 1;
+    else if (PQtransactionStatus(conn) == PQTRANS_UNKNOWN)
+	msDebug("Warning: resetting bad database connection due to PQtransactionStatus(conn) == PQTRANS_UNKNOWN in msPOSTGISSanitizeConnection()\n");
+        conn_bad = 1;
+    // if connection is in bad, PQreset() it
+    if (conn_bad)
+        PQreset(conn);
+            msSetError(MS_QUERYERR, "Database connection status is CONNECTION_BAD even after attempt to PQreset() it: %s", "msPOSTGISSanitizeConnection()", PQerrorMessage(conn));
+            return MS_FAILURE;
+            msSetError(MS_QUERYERR, "Database connection transaction status is PQTRANS_UNKNOWN even after attempt to PQreset() it: %s", "msPOSTGISSanitizeConnection()", PQerrorMessage(conn));
+    if (PQtransactionStatus(conn) == PQTRANS_ACTIVE) // no connection should have an active async call
+        msSetError(MS_QUERYERR, "Refusing to sanitize a database connection with a pending asynchronous query (transaction status of PQTRANS_ACTIVE).", "msPOSTGISSanitizeConnection()");
+    if (PQtransactionStatus(conn) == PQTRANS_INERROR) // idle, in a failed transaction block
+        PGresult *rb_res = PQexec(conn, "ROLLBACK");
+        if (!rb_res || PQresultStatus(rb_res) != PGRES_COMMAND_OK) {
+            msSetError(MS_QUERYERR, "Error executing POSTGIS ROLLBACK statement: %s", "msPOSTGISSanitizeConnection()", PQerrorMessage(conn));
+            if(rb_res) {
+                PQclear(rb_res);
+        PQclear(rb_res);
+    if (PQtransactionStatus(conn) == PQTRANS_IDLE) // idle, but not in a transaction block
+        PGresult *beg_res = PQexec(conn, "BEGIN");
+        if (!beg_res || PQresultStatus(beg_res) != PGRES_COMMAND_OK) {
+            msSetError(MS_QUERYERR, "Error executing POSTGIS BEGIN statement: %s", "msPOSTGISSanitizeConnection()", PQerrorMessage(conn));
+            if(beg_res) {
+                PQclear(beg_res);
+        PQclear(beg_res);
+    return MS_SUCCESS;
 /*static int gBYTE_ORDER = 0;*/
 /* open up a connection to the postgresql database using the connection string in layer->connection */
@@ -248,6 +320,12 @@
             return MS_FAILURE;
+        /* start a transaction, since it's required by all subsequent (DECLARE CURSOR) queries */
+        if (msPOSTGISSanitizeConnection(layerinfo->conn) != MS_SUCCESS)
         msConnPoolRegister(layer, layerinfo->conn, msPOSTGISCloseConnection);
         PQsetNoticeProcessor(layerinfo->conn, postresql_NOTICE_HANDLER, (void *) layer);
@@ -345,10 +423,6 @@
     size_t      length;
     char        *pos_from, *pos_ftab, *pos_space, *pos_paren;
-    char        *tmp2 = 0;
-    char        *error_message = 0;
-    char        *postgresql_error;
     layerinfo =  getPostGISLayerInfo(layer);
     /* Set the urid name */
@@ -484,28 +558,6 @@
     free(f_table_name);
     free(columns_wanted);
-    /* start transaction required by cursor */
-    result = PQexec(layerinfo->conn, "BEGIN");
-    if(!result || PQresultStatus(result) != PGRES_COMMAND_OK) {
-        msSetError(MS_QUERYERR, "Error executing POSTGIS BEGIN statement.", "prepare_database()");
-        if(result) {
-            PQclear(result);
-		if(layerinfo->query_result) {
-			PQclear(layerinfo->query_result);
-        layerinfo->query_result = NULL;
-        PQreset(layerinfo->conn);
-        free(query_string_0_6);
-        return MS_FAILURE;     /* totally screwed */
-    PQclear(result);
     /* set enable_seqscan=off not required (already done) */
     if(layer->debug) {
@@ -513,65 +565,25 @@
     result = PQexec(layerinfo->conn, query_string_0_6);
-    if(result && PQresultStatus(result) == PGRES_COMMAND_OK)
+    if(!result || PQresultStatus(result) != PGRES_COMMAND_OK)
-        *sql_results = result;
-        *query_string = (char *) malloc(strlen(query_string_0_6) + 1);
-        strcpy(*query_string, query_string_0_6);
+        msSetError(MS_QUERYERR, "Error declaring cursor: %s\nWith query string: %s\n", "prepare_database()", PQerrorMessage(layerinfo->conn), query_string_0_6);
-        return MS_SUCCESS;
-    /* Save PostgreSQL Error Message */
-    postgresql_error = PQerrorMessage(layerinfo->conn);
-    error_message = (char *) malloc(strlen(postgresql_error) + 1);
-    strcpy(error_message, postgresql_error);
-    /* okay, that command didnt work.  Its probably a 0.5 database */
-    /* We have to everything again, after performing a rollback. */
-    if(result) {
-        PQclear(result);
-    result = PQexec(layerinfo->conn, "rollback" );
-    if(result) {
-        PQclear(result);
-    result = PQexec(layerinfo->conn, "begin" );
-        msSetError(MS_QUERYERR, "Couldnt recover from a bad query: \n'%s'\n", "prepare_database()", query_string_0_6);
-        if(result) {
-            PQclear(result);
+        if (result)
+	    PQclear(result);
-        free(error_message);
+    *sql_results = result;
-    PQclear(result);
+    *query_string = (char *) malloc(strlen(query_string_0_6) + 1);
+    strcpy(*query_string, query_string_0_6);
-    /* TODO Rename tmp2 to something meaningful */
-    tmp2 = (char *) malloc(149 + strlen(query_string_0_6) + strlen(error_message) + 1);
-    sprintf(tmp2, "Error executing POSTGIS DECLARE (the actual query) statement: '%s' \n\nPostgresql reports the error as '%s'\n\nMore Help:\n\n", query_string_0_6, error_message);
-    msSetError(MS_QUERYERR, DATA_ERROR_MESSAGE, "prepare_database()", tmp2, "check your .map file");
-    free(tmp2);
@@ -641,7 +653,7 @@
+        msPOSTGISSanitizeConnection(layerinfo->conn);
         return MS_FAILURE;
@@ -1200,21 +1212,6 @@
     free(geom_column_name);
     free(table_name);
-    query_result = PQexec(layerinfo->conn, "BEGIN");
-    if(!query_result || PQresultStatus(query_result) != PGRES_COMMAND_OK) {
-        msSetError(MS_QUERYERR, "Error executing POSTGIS  BEGIN   statement.", "msPOSTGISLayerGetShape()");
-        if(query_result) {
-            PQclear(query_result);
-        free(query_str);
     query_result = PQexec(layerinfo->conn, query_str);
@@ -1223,7 +1220,7 @@
         if(query_result) {
         free(query_str);
@@ -1239,7 +1236,7 @@
         if(query_result) {
         free(query_str);
@@ -1310,21 +1307,22 @@
             query_result = PQexec(layerinfo->conn, "CLOSE mycursor2");
-            query_result = PQexec(layerinfo->conn, "ROLLBACK");
+            if(!query_result || PQresultStatus(query_result) !=  PGRES_COMMAND_OK)
+                msFreeShape(shape);
+                if (query_result)
-                msFreeShape(shape);
+                msSetError(MS_QUERYERR, "Error executing POSTGIS CLOSE statement on query (which returned one or more tuples).", "msPOSTGISLayerGetShape()");
                 return MS_FAILURE;
@@ -1338,19 +1336,21 @@
+        if (!query_result || PQresultStatus(query_result) != PGRES_COMMAND_OK)
+            if (query_result)
+              PQclear(query_result);
+            msSetError(MS_QUERYERR, "Error executing POSTGIS CLOSE statement on query (which returned zero tuples).", "msPOSTGISLayerGetShape()");
             return MS_FAILURE;
