[mapserver-commits] r7548 - in trunk/docs: howto references/cgi
Wed Apr 30 16:27:12 EDT 2008
Author: pramsey
Date: 2008-04-30 16:27:12 -0400 (Wed, 30 Apr 2008)
New Revision: 7548
Added:
   trunk/docs/howto/tile_mode.txt
   trunk/docs/howto/wms_server.txt
   trunk/docs/references/cgi/controls.txt
ng API (RFC 43) mode=tile, tilemode=spheremerc, tile=x y zoom (#2581)
Added: trunk/docs/howto/tile_mode.txt
--- trunk/docs/howto/tile_mode.txt	                        (rev 0)
+++ trunk/docs/howto/tile_mode.txt	2008-04-30 20:27:12 UTC (rev 7548)
@@ -0,0 +1,194 @@
+:Author: Paul Ramsey
+:Contact: pramsey(at)cleverelephant.ca
+:Last Updated: 2008/04/30
+..  The next heading encountered becomes our H2
+.. sectnum::
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+MapServer can feed tile-based map clients directly using the CGI
+"tile mode".  Tile-based map clients work by dividing the map of the world up
+into a discrete number of zoom levels, each partitioned into a number of identically
+sized "tiles".  Instead of accessing a map by requesting a bounding box, a tile
+client builds a map by accessing individual tiles.
+Configuration
+Tile requests are handled by the 'mapserv' CGI program.  In order to
+return tiles in the correct projection, Mapserver must be built with the
+--use-proj option turned on.  You can check if your version of 'mapserv' has
+projection support by running it with the '-v' option and looking
+for 'SUPPORTS=PROJ'.
+Example 1. On Unix:
+   $ ./mapserv -v
+   MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
+   OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
+   SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
+   INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
+Example 2. On Windows:
+   C:\apache\cgi-bin> mapserv -v
+Mapserver requires that each LAYER in your map file have a valid PROJECTION block
+to support reprojection.  Because the tile mode uses reprojection, you will have
+to ensure each LAYER has a valid PROJECTION block.
+Configuration checklist:
+ * Mapserver compiled with PROJ support
+ * Map file with a PROJECTION defined for every LAYER
+Utilization
+The Mapserver tile support adds three new directives to the CGI interface:
+ * *mode=tile* tells the server to generate tiles based on the other tile mode
+   parameters
+ * *tilemode=spheremerc* tells the server use the "spherical mercator" tile
+   scheme for the tiles
+ * *tile=x+y+z* tells the server what tile you want to retrieve
+About Spherical Mercator
+Spherical mercator (also called "web mercator" by some) is a world projection. All
+the major tile-based map interfaces (Google Maps, Microsoft Virtual Earth, Yahoo Maps,
+OpenLayers) use the spherical mercator system to address tiles.
+A spherical mercator set of tiles has the following properties:
+ * The data has been reprojected to mercator using a spherical
+   mercator algorithm
+ * There is one tile in top zoom level, zoom level zero
+ * Each succeeded zoom level (z) has 2^z tiles along each axis
+ * The top left tile in each zoom level is at tile coordinate 0,0
+ * The x tile coordinate increases left to right
+ * The y tile coordinate increases top to bottom
+ * Tiles are 256x256 in size
+The spherical mercator tiling scheme is currently the only one supported by the
+Mapserver tile mode.
+Using Google Maps
+The `Google Maps API`_ includes support for using alternative tile sets
+as overlays, or as alternate base maps. Here is an example of an
+`GTileLayerOverlay`_::
+  <!DOCTYPE html
+    PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
+    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+  <html xmlns="http://www.w3.org/1999/xhtml">
+  <head>
+    <meta http-equiv="content-type" content="text/html; charset=utf-8"/>
+    <title>Google/Mapserver Tile Example</title>
+    <script src="http://maps.google.com/maps?file=api&v=2&key=[YOUR KEY HERE]"
+            type="text/javascript"></script>
+    <script type="text/javascript">
+    function load() {
+      if (GBrowserIsCompatible()) {
+        var urlTemplate = 'http://localhost/cgi-bin/mapserv?';
+            urlTemplate += 'map=/var/map.map&';
+            urlTemplate += 'layers=layer1,layer2&';
+            urlTemplate += 'mode=tile&';
+            urlTemplate += 'tilemode=spheremerc&';
+            urlTemplate == 'tile={X}+{Y}+{Z}';
+        var myLayer = new GTileLayer(null,0,18,{
+                                     tileUrlTemplate:urlTemplate,
+                                     isPng:true,
+                                     opacity:1.0 });
+        var map = new GMap2(document.getElementById("map"));
+        map.addControl(new GLargeMapControl());
+        map.addControl(new GMapTypeControl());
+        map.setCenter(new GLatLng(35.35, -80.55), 15);
+        map.addOverlay(new GTileLayerOverlay(myLayer));
+    </script>
+  </head>
+  <body onload="load()" onunload="GUnload()">
+    <div id="map" style="width: 500px; height: 500px"></div>
+  </body>
+  </html>
+Note the format of the tileUrlTemplate: a valid URL, with {X}, {Y} and {Z} substitution
+tokens that Google Maps will replace with the tile coordinates and zoom level on the fly
+to retrieve tiles from your server.
+You can also use a Mapserver tile layer as an alternate base map::
+  <!DOCTYPE html
+  <head>
+    function load() {
+                                     isPng:true,
+                                     opacity:0.3 });
+        var myMapType = new GMapType([myLayer], new GMercatorProjection(18), 'Mapserver');
+        map.addMapType(myMapType);
+    </script>
+  </head>
+  </body>
+  </html>
+The only change from the previous example is that we don't create a GTileLayerOverlay,
+we create a GMapType, and add a map type, instead of an overlay.
+.. RST Link Section
+.. _`GTileLayerOverlay`: http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
+.. _`Google Maps API`: http://code.google.com/apis/maps/
\ No newline at end of file
Modified: trunk/docs/howto/wms_server.txt
--- trunk/docs/howto/wms_server.txt	2008-04-30 20:26:56 UTC (rev 7547)
+++ trunk/docs/howto/wms_server.txt	2008-04-30 20:27:12 UTC (rev 7548)
@@ -687,6 +687,11 @@
 - *Description:* (Optional) Fees information. Use the reserved word "none" if there
   are no fees.
+**wms_http_max_age
+- *Description:* (Optional) Sets the Cache-control HTTP header to have the specified
+  max-age.  Useful for tiled clients (e.g. OpenLayers) to improve caching behavior of
+  tiles.
 **wms_keywordlist**
 - *WMS TAG Name:* KeywordList (WMS1.1.1, sect. 7.1.4.2)
Modified: trunk/docs/references/cgi/controls.txt
--- trunk/docs/references/cgi/controls.txt	2008-04-30 20:26:56 UTC (rev 7547)
+++ trunk/docs/references/cgi/controls.txt	2008-04-30 20:27:12 UTC (rev 7548)
@@ -128,6 +128,11 @@
         all matches. Layer to be searched is defined using slayer parameter.
         The results of this search are applied to other searchable layers
         (which can be limited using the QLAYER parameter).
+    TILE
+        A created map is returned based on the values of the TILEMODE and TILE
+        parameters.  Used in tiled map components (Google Maps, Virtual Earth,
+        OpenLayers, etc).
     MAP
         The created map is returned. Used within an <img ... > tag.
@@ -215,7 +220,18 @@
 TILEINDEX [index]
     Used for index queries (in conjunction with INDEXQUERY), used with tiled
     shapefile layers.
+TILEMODE [spheremerc]
+    Used when MODE=TILE to specify the tile basis. Currently only supports
+    "spheremerc", the projection (spherical mercator, also known as "web
+    mercator") and tile layout (one tile at zoom level 0, descending by
+    powers of two from there) used by Google Maps,
+    Virtual Earth, Yahoo Maps and OpenStreetMap.
+TILE [X] [Y] [ZOOM]
+    Used when MODE=TILE to specify the tile desired, in tile coordinates.
+    Tile "0 0 1" is the top left tile at zoom level one.
 ZOOM [number]
     Zoom scaling to apply to the creation of the new map. Values greater than
     0 resulting in zooming in, 0 is a pan, and values less than zero are for
