[mapserver-commits] r7842 - trunk/mapserver
Fri Aug 8 14:25:17 EDT 2008
Author: dmorissette
Date: 2008-08-08 14:25:17 -0400 (Fri, 08 Aug 2008)
New Revision: 7842
   trunk/mapserver/mapswf.c
Embed each button inside its own little movie clip to make them reachable/modifiable by name from ActionScript (#2336)
Modified: trunk/mapserver/mapswf.c
--- trunk/mapserver/mapswf.c	2008-08-01 12:24:55 UTC (rev 7841)
+++ trunk/mapserver/mapswf.c	2008-08-08 18:25:17 UTC (rev 7842)
@@ -1382,6 +1382,49 @@
+/* Set the name on a SWFButton to button_<layerid>_<shapeid>.
+ * It seems that the only way to make a button reachable/modifiable by
+ * name via Action Script is to embed it in its own little clip.
+ * Setting the name directly on the button itself results in
+ * selecting/modifying the whole layer.
+ * See ticket #2336 for all the details.
+ * Returns a handle on the clip's SWFDisplayItem.
+SWFDisplayItem _msSWFAddButtonWithId(imageObj *image, SWFMovie oMainMovie,
+                                     SWFButton oButton,
+                                     int nLayerIndex, int nShapeIndex)
+    SWFMovieClip myButtonMovieClip;
+    SWFDisplayItem oDisplay;
+    myButtonMovieClip = newSWFMovieClip();
+    SWFMovieClip_add(myButtonMovieClip, oButton);
+    SWFMovieClip_nextFrame(myButtonMovieClip);
+    oDisplay = SWFMovie_add(oMainMovie, myButtonMovieClip);
+    if (oDisplay)
+#ifdef MS_TICKET_2336
+        // Force name to button214 to test with loader attached to ticket 2336
+        // (even if the loader says "button212", it really works on button214!)
+        static int test=0;
+        if (test==0)
+            sprintf(gszTmp, "button214");
+            test=1;
+        else
+#endif
+        sprintf(gszTmp, "button_%d_%d",nLayerIndex, nShapeIndex);
+        ((SWFObj *)image->img.swf)->nTmpCount++;
+        SWFDisplayItem_setName(oDisplay, gszTmp);
+    return oDisplay;
 /*                          msDrawMarkerSymbolSWF                       */
@@ -1532,10 +1575,12 @@
             oButton = BuildButtonFromGD(imgtmp, image);/* , NULL); */
             StoreButton(oButton, image);
             AddMouseActions(oButton, nLayerIndex, nShapeIndex);
-            oDisplay = SWFMovie_add(GetCurrentMovie(map, image),
-                                    oButton);
+            oDisplay = _msSWFAddButtonWithId(image,
+                                             GetCurrentMovie(map, image),
+                                             oButton,
+                                             nLayerIndex, nShapeIndex);
             SWFDisplayItem_moveTo(oDisplay, (float)x, (float)y);
+            break;
 #endif
@@ -1552,8 +1597,10 @@
-                                        oButton);
+                                                 oButton,
                 SWFDisplayItem_moveTo(oDisplay, (float)offset_x,
                                       (float)offset_y);
@@ -1580,20 +1627,16 @@
-                                        oButton);
+                                                 oButton,
                                       (float)offset_y);
                 /* gdImageDestroy(imgtmp); */
-            if (oDisplay)
-              sprintf(gszTmp, "button_%d_%d",nLayerIndex, nShapeIndex);
-                ((SWFObj *)image->img.swf)->nTmpCount++;
-                SWFDisplayItem_setName(oDisplay, gszTmp);
             break;
@@ -1628,10 +1671,11 @@
                                      nLayerIndex, nShapeIndex, image);
 		/* Ticket #2555 memory leak : need to store buttons to properly destroy them */
-		oDisplay = SWFMovie_add(GetCurrentMovie(map, image), oButton);
+                                                 oButton,
             else
@@ -1645,16 +1689,12 @@
                                            &sColorHighlightObj,
+                                                     oButton,
-            if (oDisplay)
             break;
@@ -1690,10 +1730,13 @@
                                              psFillColor,  psOutlineColor,
-                StoreButton(oButton, image);
+                StoreButton(oButton, image);
+                                                 oButton,
 /*      symbol VECTOR : not filled.                                     */
@@ -1716,16 +1759,13 @@
+                                                 oButton,
             } /* end if-then-else */
-            if (oDisplay)
             break;
         default:
             break;
@@ -2015,11 +2055,10 @@
             oButton = DrawButtonPolyline(p, &sFc, &sColorHighlightObj, nLayerIndex,
                                          nShapeIndex, width);
+                                             oButton,
         return;
@@ -2157,10 +2196,10 @@
+                                             oButton,
         return;
@@ -2208,10 +2247,10 @@
+                                                 oButton,
