[mapserver-commits] r7875 - trunk/mapserver
Wed Aug 20 17:06:10 EDT 2008
Author: dmorissette
Date: 2008-08-20 17:06:10 -0400 (Wed, 20 Aug 2008)
New Revision: 7875
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/Makefile.in
   trunk/mapserver/configure
   trunk/mapserver/configure.in
   trunk/mapserver/maperror.c
   trunk/mapserver/mapserver.h
Added  MS_VERSION_NUM for use with #if statements in code based on
libmapserver (#2750)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-08-20 18:33:42 UTC (rev 7874)
+++ trunk/mapserver/HISTORY.TXT	2008-08-20 21:06:10 UTC (rev 7875)
@@ -12,6 +12,9 @@
 Current Version (5.3-dev, SVN trunk):
+- Added MS_VERSION_NUM for use with #if statements in code based on
+  libmapserver (#2750)
 - Fixed the configure script: failed to detect php5 on ubuntu. (#2365)
 - Fixed a memory leak associated with not deleting the lexer buffer
Modified: trunk/mapserver/Makefile.in
--- trunk/mapserver/Makefile.in	2008-08-20 18:33:42 UTC (rev 7874)
+++ trunk/mapserver/Makefile.in	2008-08-20 21:06:10 UTC (rev 7875)
@@ -369,7 +369,7 @@
 	echo -I. $(PROJ_INC) $(GD_INC) $(TTF_INC) $(TIFF_INC) $(JPEG_INC) $(SDE_INC) $(OGR_INC) $(GDAL_INC) $(GEOS_INC) >> mapscriptvars
 	echo $(EXE_LDFLAGS) >> mapscriptvars
 	echo $(STATIC_LIBS) >> mapscriptvars
-	grep '#define MS_VERSION' mapserver.h >> mapscriptvars
+	grep '#define MS_VERSION ' mapserver.h >> mapscriptvars
 mapserver-config: Makefile
 	rm -f mapserver-config
@@ -379,7 +379,7 @@
 	echo 'CONFIG_CFLAGS="$(CFLAGS)"' >> mapserver-config
 	echo 'CONFIG_DEFINES="$(DEFINES)"' >> mapserver-config
 	echo 'CONFIG_INCLUDES="$(INCLUDES)"' >> mapserver-config
-	echo 'CONFIG_VERSION="'`grep '#define MS_VERSION' mapserver.h | sed 's/\"//g' | sed 's/#define MS_VERSION //'`'"' >> mapserver-config
+	echo 'CONFIG_VERSION="'`grep '#define MS_VERSION ' mapserver.h | sed 's/\"//g' | sed 's/#define MS_VERSION //'`'"' >> mapserver-config
 	cat mapserver-config.in >> mapserver-config
 	chmod a+x mapserver-config
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2008-08-20 18:33:42 UTC (rev 7874)
+++ trunk/mapserver/configure	2008-08-20 21:06:10 UTC (rev 7875)
@@ -4967,7 +4967,7 @@
 STRINGS=$STRINGS
-MS_VERSION=`grep MS_VERSION mapserver.h | grep '#define' | cut -d\" -f2`
+MS_VERSION=`grep 'MS_VERSION ' mapserver.h | grep '#define' | cut -d\" -f2`
 { echo "$as_me:$LINENO: result: MapServer Version from mapserver.h: '$MS_VERSION'" >&5
 echo "${ECHO_T}MapServer Version from mapserver.h: '$MS_VERSION'" >&6; }
 MS_VERSION="$MS_VERSION"
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2008-08-20 18:33:42 UTC (rev 7874)
+++ trunk/mapserver/configure.in	2008-08-20 21:06:10 UTC (rev 7875)
@@ -75,7 +75,7 @@
 dnl ---------------------------------------------------------------------
 dnl Look for MapServer version in mapserver.h
 AC_MSG_RESULT([MapServer Version from mapserver.h: '$MS_VERSION'])
 AC_SUBST(MS_VERSION,    "$MS_VERSION")
Modified: trunk/mapserver/maperror.c
--- trunk/mapserver/maperror.c	2008-08-20 18:33:42 UTC (rev 7874)
+++ trunk/mapserver/maperror.c	2008-08-20 21:06:10 UTC (rev 7875)
@@ -579,25 +579,5 @@
 int msGetVersionInt()
-    static int version = 0;
-    /* Parse MS_VERSION only once */
-    if (version == 0)
-        char **tokens = NULL;
-        int n = 0;
-        tokens = msStringSplit(MS_VERSION, '.', &n);
-        if (n<3)
-            msSetError(MS_MISCERR, "Invalid version string: %s", "msGetVersionInt()", MS_VERSION);
-        else
-            version = atoi(tokens[0])*10000 + atoi(tokens[1])*100 + atoi(tokens[2]);
-        if (tokens)
-            msFreeCharArray(tokens, n);
-    return version;
+    return MS_VERSION_NUM;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2008-08-20 18:33:42 UTC (rev 7874)
+++ trunk/mapserver/mapserver.h	2008-08-20 21:06:10 UTC (rev 7875)
@@ -30,8 +30,20 @@
 #ifndef MAP_H
 #define MAP_H
-/* $Id$
+** MapServer version - to be updated for every release
+#define MS_VERSION "5.3-dev"
+#define MS_VERSION_MAJOR    5
+#define MS_VERSION_MINOR    3
+#define MS_VERSION_REV      0
+#define MS_VERSION_NUM (MS_VERSION_MAJOR*10000+MS_VERSION_MINOR*100+MS_VERSION_REV)
 ** Main includes. If a particular header was needed by several .c files then
 ** I just put it here. What the hell, it works and it's all right here. -SDL-
@@ -119,8 +131,6 @@
 /* General defines, wrapable */
-#define MS_VERSION "5.3-dev"
 #define MS_TRUE 1 /* logical control variables */
 #define MS_FALSE 0
 #define MS_ON 1
