[mapserver-commits] r8235 - in trunk/docs: howto mapscript
    svn at osgeo.org
    svn at osgeo.org
    Wed Dec 10 13:59:02 EST 2008
Author: hobu
Date: 2008-12-10 13:59:02 -0500 (Wed, 10 Dec 2008)
New Revision: 8235
Removed:
   trunk/docs/howto/oracle_spatial_howto.txt
   trunk/docs/mapscript/introduction.txt
   trunk/docs/mapscript/mapfile.txt
   trunk/docs/mapscript/mapscript.txt
   trunk/docs/mapscript/querying.txt
 delete old OCI howto, now incorporated into main docs
Deleted: trunk/docs/howto/oracle_spatial_howto.txt
--- trunk/docs/howto/oracle_spatial_howto.txt	2008-12-10 05:28:59 UTC (rev 8234)
+++ trunk/docs/howto/oracle_spatial_howto.txt	2008-12-10 18:59:02 UTC (rev 8235)
@@ -1,178 +0,0 @@
-<p> Oracle Spatial is a spatial cartridge for the Oracle database. Remember
-that all Oracle databases come with Locator, which has less features than
-Oracle Spatial. The differences between Locator and Spatial can be found in
-the <a href="http://www.orafaq.com/faqsdo.htm">Oracle Spatial FAQ</a>. </p>
-<H4>What MapServer 4.4 or new currently supports with Oracle Spatial:</H4>
-<ul> <li>mode=map <li>query modes: query, nquery, itemnquery <li>mapscript
-query functions such as querybyattributes <li>OGC:WMS, GetCapabilities,
-GetMap, GetFeatureInfo, DescribeLayer <li>OGC:WFS, GetCapabilities,
-DescribeFeatureType, GetFeature </ul>
-<H4>Binaries</H4> <p> Mapserver Windows binaries with Oracle spatial support
-can be downloaded from the mapserver download site. But you need Oracle client
-software in the server on which you are running mapserver. Oracle client
-software can be obtained for development purposes from the Oracle website, but
-you need to register, which by the way is free. The most recent version is
-Oracle Database 10g Release 1 Client. The ORACLE TECHNOLOGY NETWORK
-DEVELOPMENT LICENSE AGREEMENT applies to this software. The instant client
-will be satisfactory, you can download the instant client from <a
-href="http://www.oracle.com/technology/software/tech/oci/instantclient/index.html">this
-location</a>. Make sure though your Mapserver is compiled against the same
-version as your Oracle client, for compiling you need a full client install,
-not just the instant client. </p>
-<H4>Setting environment variables</H4> <p> The native support for Oracle
-Spatial requires setting some environent variables. These variables tell the
-MapServer where the Oracle client binaries, libs and tnsnames.ora information
-can be found. It's related with access to Oracle files and you should check
-these enviroment variables!. The more important enviroments is: </p> <ul>
-<li>ORACLE_HOME - "oracle client home directory" <li>ORACLE_SID - "default
-database sid from tnsnames.ora" <li>TNS_ADMIN - "folder where the tnsnames.ora
-exist" </ul>
-<p> An example for the Apache httpd.conf file: </p>
-<ul> <li>SetEnv TNS_ADMIN "f:/oracle/ora92/network/admin" <li>SetEnv PATH
-"f:/oracle/ora92/bin" </ul>
-<H5>Note</H5> If you receive errormessage like "Error: .". It's relate that
-Mapserver can't access or locate the ORACLE_HOME. </p>
-<H4>Two options for using Oracle Spatial with Mapserver</H4> Oracle Spatial
-layers in mapserver can be used through 2 interfaces: <ul> <li>The native
-built-in support through maporaclespatial.c <li>OGR, but watch out: OGR is not
-compiled with Oracle Spatial support so it won't work without compiling in OCI
-(Oracle client) yourself. This requires both recompiling GDAL/OGR as well as
-recompiling Mapserver itself against the new GDAL/OGR !!!! </ul>
-<H4>Mapfile syntax for native Oracle Spatial support</H4> The DATA statement
-for a LAYER of CONNECTIONTYPE oraclespatial can now have 4 options. This
-change is backwards compatible, i.e. the old ways of specifying DATA still
-work. The new options are an extension to the old DATA statements, as they
-needed to include identification of the primary key to be used for the query
-modes (UNIQUE).
-<H5>The following options are valid DATA statements:</H5> <pre> "[geom_column]
-FROM [table]| [( SELECT [...] FROM [table]|[Spatial Operator] [WHERE
-condition] )] [USING [UNIQUE column] | [SRID #srid] | [FUNCTION] | [VERSION
-#version] ]" </pre>
-<h5>Example 1</h5> The most simple DATA statement, in this case you only need
-to define one geometry column and one table. This option assumes you do not
-have an SRID defined. <pre> LAYER .. CONNECTIONTYPE oraclespatial DATA
-"MYGEOMETRY FROM MYTABLE" .. END </pre>
-<h5>Example 2</h5> It's composed of the first option plus the USING UNIQUE
-parameter. These new features are necessary when you want to use any query
-function. When it is used you must pass a numeric column type. This option
-assumes you do not have an SRID defined.
-<pre> LAYER .. CONNECTIONTYPE oraclespatial DATA "MYGEOMETRY FROM MYTABLE
-USING UNIQUE MYTABLE_ID" .. END </pre>
-<h5>Exmaple 3</h5> This option is an extension to the first option. In this
-mode you must define the USING SRID parameter when the SRID value in your data
-is different from NULL. <pre> LAYER .. CONNECTIONTYPE oraclespatial DATA
-"MYGEOMETRY FROM MYTABLE USING SRID 90112" .. END </pre>
-<h5>Example 4</h5> This option is a combination of examples 2 and 3. <pre>
-LAYER .. CONNECTIONTYPE oraclespatial DATA "MYGEOMETRY FROM MYTABLE USING
-UNIQUE MYTABLE_ID SRID 90112" .. END </pre>
-<h4>Using subselects in the DATA statement</h4> It is possible to define the
-source of the date as a subselect and not only as a table. As source of data,
-used in FROM token, you can define any SQL, table, function, or operator that
-returns a SDO_GEOMETRY. For example: <pre> DATA "[geom_column] FROM (SELECT
-[columns] FROM [table]|[Spatial function])" </pre> <p> If the LAYER definition
-contains a CLASSITEM, LABELITEM or FILTER, it is necessary that the fields
-used are returned by the query. When you define CLASSITEM you can use an
-expression without any problems. </p>
-<h4>Additional keywords - [FUNCTION]</h4> You can add three keywords to the
-DATA statement for [FUNCTION] option that influence the query which will be
-executed in Oracle:
-<H5>USING FILTER</H5> Example: <pre> "[geom_column] FROM [table]|([Subselect])
-USING FILTER" </pre> <p> Using this keyword triggers Mapserver to use the
-Oracle Spatial SDO_FILTER operator. This operator executes only the Oracle
-Spatial primary filter over your query data. In the Oracle User guide they
-explain: The primary filter compares geometric approximations, it returns a
-superset of exact result. The primary filter therefore should be as efficient
-(that is, selective yet fast) as possible. This operator uses the spatial
-index, so you need to define your spatial index correctly to retrieve an exact
-result. If the result of the query is not exact you can try the next option.
-</p>
-<H5>USING RELATE</H5> Example: <pre> "[geom_column] FROM [table]|([Subselect])
-USING RELATE" </pre> <p> Using this keyword triggers Mapserver to use the
-Oracle Spatial SDO_RELATE operator. This operator applies the primary and
-secondary Oracle Spatial filters. It's performance can be slightly slow but
-the result is extremely correct. You can use this mode when you want a perfect
-result or when you can't readjust the spatial index. </p>
-<H5>USING GEOMRELATE</H5> Example: <pre> "[geom_column] FROM
-[table]|([Subselect]) USING GEOMRELATE" </pre> <p> Using this keyword triggers
-Mapserver to use the geometry function SDO_GEOM.RELATE, a function that
-searches the relations between geometries. SDO_GEOM.RELATE does not use the
-spatial index and your performance is more slow than operators but it's very
-accurate. You can use this mode when you can't use the spatial index or when
-it doesn't exist. </p>
-<H5>USING NONE</H5> Example: <pre> "[geom_column] FROM [table]|([Subselect])
-USING NONE" </pre> <p> Using this keyword triggers Mapserver to don't use any
-geometry function or spatial operator. So, the internal SQL don't retrict,
-bases in the extent, the data from source. All the data from source will be
-returned for Mapserver. The NONE token is very useful when the source of the
-data don't contains any spatial index. It's usually occur when the source is a
-function like SDO_BUFFER, SDO_XOR, SDO_INTERSECTION...... So this mode is
-recomended when you can't use the spatial index or when it doesn't exist. </p>
-<h4>Additional keywords - [VERSION]</h4> You can define what version of
-database you are using to improve the internal sql. This is very useful when
-using geodetic SRIDs and Mapserver functions that retrieve the extent from
-data.
-<H5>USING VERSION 8i</H5> Example: <pre> "[geom_column] FROM
-[table]|([Subselect]) USING VERSION 8i" </pre> <p> This indicates Mapserver to
-use a internal SQL that it's compatible with Oracle 8i version. </p>
-<H5>USING VERSION 9i</H5> Example: <pre> "[geom_column] FROM
-[table]|([Subselect]) USING VERSION 9i" </pre> <p> The second indicates
-Mapserver to use 9i version, is recommended to use this parameter if you are
-using 9i version because the internal SQL will use specific spatial functions
-that is need to retrieve data correctly from 9i Oracle Spatial versions. </p>
-<H5>USING VERSION 10g</H5> Example: <pre> "[geom_column] FROM
-[table]|([Subselect]) USING VERSION 10g" </pre> <p> This indicates Mapserver
-to use a internal SQL that it's compatible with Oracle 8i version. </p>
-<h4>More information</h4> <ul> <li>You can define any PROJECTION to your LAYER
-without problem, can be used for data with or without an SRID in Oracle.
-<li>The native support for Oracle Spatial supports the defaults definition for
-SDO_GEOMETRY in database, the Oracle Spatial SDO package. <li>Information
-about the primary and secondary Oracle Spatial filters can be found in the
-Oracle Spatial User Guide (the "Query Model" section). Information about the
-SDO_FILTER and SDO_RELATE operators can be found in the "Spatial Operators"
-section, and information about the SDO_GEOM.RELATE function can be found in
-the "Geometry Function" section of the Oracle Spatial User Guide. </ul>
-<h4>Example of a LAYER</h4> <pre> LAYER NAME kwadranten TYPE POLYGON
-CONNECTIONTYPE oraclespatial CONNECTION "user/pwd" DATA "GEOMETRIE FROM
-KWADRANTEN USING SRID 90112" DUMP TRUE CLASS STYLE OUTLINECOLOR 0 0 0 COLOR 0
-128 128 END END END </pre>
-<p> You can specifie the SID for your database, the SID alias needs to be
-supplied in the tnsnames.ora file of the Oracle client, e.g. </p>
-<p> Example for tnsnames.ora: </p> <pre> MYDB = (DESCRIPTION = (ADDRESS_LIST =
-(ADDRESS = (PROTOCOL = TCP)(HOST = server_ip)(PORT = 1521)) ) (CONNECT_DATA =
-(SERVICE_NAME = DB1) ) ) </pre>
-<p> So after this you can define you layer connection as: </p> <pre>
-CONNECTION "user/pwd at MYDB" </pre>
-<p> <h4>Mapfile syntax for OGR Oracle Spatial support</h4> Syntax for your MAP
-file: </p> <pre> CONNECTION "OCI:user/pwd at service" CONNECTIONTYPE OGR DATA
-"Tablename" </pre> <p> Make sure you set the wms_extent METADATA for the
-LAYER, as otherwise the "Getcapabilities" request takes a lot of time. </p>
\ No newline at end of file
Modified: trunk/docs/mapscript/introduction.txt
--- trunk/docs/mapscript/introduction.txt	2008-12-10 05:28:59 UTC (rev 8234)
+++ trunk/docs/mapscript/introduction.txt	2008-12-10 18:59:02 UTC (rev 8235)
@@ -1,5 +1,7 @@
+.. _mapscript_introduction:
- MapScript Introduction
+ Introduction
 This is language agnostic documentation for the MapScript interface to
Modified: trunk/docs/mapscript/mapfile.txt
--- trunk/docs/mapscript/mapfile.txt	2008-12-10 05:28:59 UTC (rev 8234)
+++ trunk/docs/mapscript/mapfile.txt	2008-12-10 18:59:02 UTC (rev 8235)
@@ -4,7 +4,7 @@
     pair: MapScript; mapfile
- Mapscript Mapfile HOWTO
+ Mapfile Manipulation
 :Author: Sean Gillies
Modified: trunk/docs/mapscript/mapscript.txt
--- trunk/docs/mapscript/mapscript.txt	2008-12-10 05:28:59 UTC (rev 8234)
+++ trunk/docs/mapscript/mapscript.txt	2008-12-10 18:59:02 UTC (rev 8235)
@@ -1,7 +1,7 @@
 .. _swig:
- SWIG Mapscript API Reference
+ SWIG MapScript API Reference
Modified: trunk/docs/mapscript/querying.txt
--- trunk/docs/mapscript/querying.txt	2008-12-10 05:28:59 UTC (rev 8234)
+++ trunk/docs/mapscript/querying.txt	2008-12-10 18:59:02 UTC (rev 8235)
@@ -1,7 +1,7 @@
 .. _querying:
- MapScript Query HowTo
+ Querying
More information about the mapserver-commits
