[mapserver-commits] r7344 - trunk/mapserver
Sun Feb 3 14:33:08 EST 2008
Author: tomkralidis
Date: 2008-02-03 14:33:08 -0500 (Sun, 03 Feb 2008)
New Revision: 7344
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcsos.c
   trunk/mapserver/mapwcs.c
   trunk/mapserver/mapwcs11.c
   trunk/mapserver/mapwfs.c
   trunk/mapserver/mapwms.c
output updateSequence if set (#2384)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-02-03 15:17:17 UTC (rev 7343)
+++ trunk/mapserver/HISTORY.TXT	2008-02-03 19:33:08 UTC (rev 7344)
@@ -13,6 +13,8 @@
 Current Version (5.1-dev, SVN trunk):
+- OWS: output Capabilities XML updateSequence if set (#2384)
 - mapwcs.c: better handling of REQUEST parameter (#2490)
 - mapwcs.c: point to correct exception schema (#2481)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2008-02-03 15:17:17 UTC (rev 7343)
+++ trunk/mapserver/mapogcsos.c	2008-02-03 19:33:08 UTC (rev 7344)
@@ -1145,7 +1145,7 @@
 /*      getCapabilities request handler.                                */
-int msSOSGetCapabilities(mapObj *map, char *pszVersion, cgiRequestObj *req) {
+int msSOSGetCapabilities(mapObj *map, sosParamsObj *sosparams, cgiRequestObj *req) {
     xmlDocPtr psDoc = NULL;       /* document pointer */
     xmlNodePtr psRootNode, psMainNode, psNode;
     xmlNodePtr psOfferingNode;
@@ -1222,8 +1222,11 @@
     /*version fixed for now*/
     xmlNewProp(psRootNode, BAD_CAST "version", BAD_CAST pszSOSVersion);
-    //xmlNewProp(psRootNode, BAD_CAST "updateSequence", BAD_CAST "1234567890");
+    value = msOWSLookupMetadata(&(map->web.metadata), "SO", "updatesequence");
+    if (value)
+      xmlNewProp(psRootNode, BAD_CAST "updateSequence", BAD_CAST value);
     /*schema fixed*/
     schemalocation = msEncodeHTMLEntities( msOWSGetSchemasLocation(map) );
     xsi_schemaLocation = strdup(pszSOSNamespaceUri);
@@ -2489,7 +2492,7 @@
     if (strcasecmp(paramsObj->pszRequest, "GetCapabilities") == 0) {
-      returnvalue = msSOSGetCapabilities(map, paramsObj->pszVersion, req);
+      returnvalue = msSOSGetCapabilities(map, paramsObj, req);
       msSOSFreeParamsObj(paramsObj);
       free(paramsObj);
       paramsObj = NULL;
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2008-02-03 15:17:17 UTC (rev 7343)
+++ trunk/mapserver/mapwcs.c	2008-02-03 19:33:08 UTC (rev 7344)
@@ -703,6 +703,7 @@
   int tmpInt = 0;
   int wcsSupportedVersions[] = {OWS_1_1_1, OWS_1_1_0, OWS_1_0_0};
   int wcsNumSupportedVersions = 3;
+  const char *updatesequence=NULL;
  /* if version is not passed/set, set it to 1.1.1, this will trigger
     msOWSNegotiateVersion to handle accordingly
@@ -742,16 +743,21 @@
     /* print common capability elements  */
     /* TODO: DocType? */
+  updatesequence = msOWSLookupMetadata(&(map->web.metadata), "CO", "updatesequence");
+  if (!updatesequence)
+    updatesequence = strdup("0");
     msOWSPrintEncodeMetadata(stdout, &(map->web.metadata), NULL, "wcs_encoding", OWS_NOERR, "<?xml version='1.0' encoding=\"%s\" standalone=\"no\" ?>\n", "ISO-8859-1");
     if(!params->section || (params->section && strcasecmp(params->section, "/")  == 0)) msIO_printf("<WCS_Capabilities\n"
                                 "   version=\"%s\" \n"
-                                "   updateSequence=\"0\" \n"
+                                "   updateSequence=\"%s\" \n"
                                 "   xmlns=\"http://www.opengis.net/wcs\" \n"
                                 "   xmlns:xlink=\"http://www.w3.org/1999/xlink\" \n"
                                 "   xmlns:gml=\"http://www.opengis.net/gml\" \n"
                                 "   xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"\n"
-                                "   xsi:schemaLocation=\"http://www.opengis.net/wcs %s/wcs/%s/wcsCapabilities.xsd\">\n", params->version, msOWSGetSchemasLocation(map), params->version);
+                                "   xsi:schemaLocation=\"http://www.opengis.net/wcs %s/wcs/%s/wcsCapabilities.xsd\">\n", params->version, updatesequence, msOWSGetSchemasLocation(map), params->version);
     /* print the various capability sections */
     if(!params->section || strcasecmp(params->section, "/WCS_Capabilities/Service") == 0)
Modified: trunk/mapserver/mapwcs11.c
--- trunk/mapserver/mapwcs11.c	2008-02-03 15:17:17 UTC (rev 7343)
+++ trunk/mapserver/mapwcs11.c	2008-02-03 19:33:08 UTC (rev 7344)
@@ -304,6 +304,7 @@
     xmlNodePtr psTmpNode;
     char *identifier_list = NULL, *format_list = NULL;
     xmlNsPtr psOwsNs, psXLinkNs;
     char *script_url=NULL, *script_url_encoded=NULL;
@@ -354,6 +355,11 @@
     xmlNewProp(psRootNode, BAD_CAST "version", BAD_CAST params->version );
+    if (updatesequence)
+      xmlNewProp(psRootNode, BAD_CAST "updateSequence", BAD_CAST updatesequence);
 /*      Service metadata.                                               */
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2008-02-03 15:17:17 UTC (rev 7343)
+++ trunk/mapserver/mapwfs.c	2008-02-03 19:33:08 UTC (rev 7344)
@@ -288,6 +288,7 @@
 int msWFSGetCapabilities(mapObj *map, const char *wmtver, cgiRequestObj *req)
   char *script_url=NULL, *script_url_encoded;
   int i;
   /* Decide which version we're going to return... only 1.0.0 for now */
@@ -300,6 +301,12 @@
       return msWFSException(map, wmtver);
+  updatesequence = msOWSLookupMetadata(&(map->web.metadata), "FO", "updatesequence");
   msIO_printf("Content-type: text/xml%c%c",10,10);
   msOWSPrintEncodeMetadata(stdout, &(map->web.metadata), "FO", "encoding", OWS_NOERR,
@@ -308,12 +315,12 @@
   msIO_printf("<WFS_Capabilities \n"
          "   xmlns=\"http://www.opengis.net/wfs\" \n"
          "   xmlns:ogc=\"http://www.opengis.net/ogc\" \n"
          "   xsi:schemaLocation=\"http://www.opengis.net/wfs %s/wfs/%s/WFS-capabilities.xsd\">\n",
-         wmtver,
+         wmtver, updatesequence,
          msOWSGetSchemasLocation(map), wmtver);
   /* Report MapServer Version Information */
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2008-02-03 15:17:17 UTC (rev 7343)
+++ trunk/mapserver/mapwms.c	2008-02-03 19:33:08 UTC (rev 7344)
@@ -1602,6 +1602,7 @@
   const char *pszMimeType=NULL;
   char szVersionBuf[OWS_VERSION_MAXLEN];
   char *schemalocation = NULL;
@@ -1662,9 +1663,16 @@
   msIO_printf(" ]>  <!-- end of DOCTYPE declaration -->\n\n");
-  msIO_printf("<WMT_MS_Capabilities version=\"%s\">\n",
+  msIO_printf("<WMT_MS_Capabilities version=\"%s\"",
          msOWSGetVersionString(nVersion, szVersionBuf));
+  updatesequence = msOWSLookupMetadata(&(map->web.metadata), "MO", "updatesequence");
+    msIO_printf(" updateSequence=\"%s\"",updatesequence);
+  msIO_printf(">\n",updatesequence);
   msIO_printf("\n<!-- %s -->\n\n", msGetVersion());
