[mapserver-commits] r7409 - trunk/mapserver
Wed Feb 27 09:25:21 EST 2008
Author: tomkralidis
Date: 2008-02-27 09:25:21 -0500 (Wed, 27 Feb 2008)
New Revision: 7409
   trunk/mapserver/mapwcs.c
undoing change committed in r7407
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2008-02-27 14:15:49 UTC (rev 7408)
+++ trunk/mapserver/mapwcs.c	2008-02-27 14:25:21 UTC (rev 7409)
@@ -1309,8 +1309,6 @@
   char *bandlist=NULL;
   char numbands[8]; /* should be large enough to hold the number of bands in the bandlist */
   coverageMetadataObj cm;
-  rectObj reqextent;
-  rectObj covextent;
   /* make sure all required parameters are available (at least the easy ones) */
   if(!params->crs) {
@@ -1615,33 +1613,6 @@
   map->projection.gt = map->gt;
-  // check for overlap
-  // get extent of bbox passed, and reproject
-  reqextent.minx = params->bbox.minx;
-  reqextent.miny = params->bbox.miny;
-  reqextent.maxx = params->bbox.maxx;
-  reqextent.maxy = params->bbox.maxy;
-  // reproject incoming bbox
-  msProjectRect(&map->projection, &lp->projection, &(reqextent));
-  // get extent of layer
-  covextent.minx = cm.extent.minx;
-  covextent.miny = cm.extent.miny;
-  covextent.maxx = cm.extent.maxx;
-  covextent.maxy = cm.extent.maxy;
-  if(msRectOverlap(&reqextent, &covextent) == MS_FALSE) {
-      msSetError(MS_WCSERR, "\nBBOX NATIVE    = %.15g,%.15g,%.15g,%.15g\nEXTENT NATIVE  = %.15g,%.15g,%.15g,%.15g\nBBOXLL         = %.15g,%.15g,%.15g,%.15g\nEXTENTLL       = %.15g,%.15g,%.15g,%.15g",
-                            "msWCSGetCoverage()",
-                            reqextent.minx, reqextent.miny, reqextent.maxx, reqextent.maxy,
-                            cm.extent.minx, cm.extent.miny, cm.extent.maxx, cm.extent.maxy,
-                            params->bbox.minx, params->bbox.miny, params->bbox.maxx, params->bbox.maxy,
-                            cm.llextent.minx, cm.llextent.miny, cm.llextent.maxx, cm.llextent.maxy);
-      return msWCSException(map, "NoApplicableCode", "bbox", params->version);
   /* check and make sure there is a format, and that it's valid (TODO: make sure in the layer metadata) */
   if(!params->format) {
     msSetError( MS_WCSERR,  "Missing required FORMAT parameter.", "msWCSGetCoverage()" );
