[mapserver-commits] r7240 - in trunk/mapserver: . mapscript/php3 mapscript/swiginc
Thu Jan 3 08:53:03 EST 2008
Author: tomkralidis
Date: 2008-01-03 08:53:03 -0500 (Thu, 03 Jan 2008)
New Revision: 7240
   trunk/mapserver/mapcopy.c
   trunk/mapserver/maprasterquery.c
   trunk/mapserver/mapscript/php3/mapscript_i.c
   trunk/mapserver/mapscript/swiginc/shapefile.i
   trunk/mapserver/mapshape.c
   trunk/mapserver/mapshape.h
   trunk/mapserver/shptree.c
clean up naming conventions of Shapefile API (#599)
Modified: trunk/mapserver/mapcopy.c
--- trunk/mapserver/mapcopy.c	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/mapcopy.c	2008-01-03 13:53:03 UTC (rev 7240)
@@ -706,7 +706,7 @@
  * msCopyLayer()                                                       *
  * Copy a layerObj, using mapfile.c:initClass(), msCopyClass(),        *
- * msCopyColor(), msCopyProjection(), msSHPOpenFile(),                 *
+ * msCopyColor(), msCopyProjection(), msShapefileOpen(),                 *
  * msCreateHashTable(), msCopyHashTable(), msCopyExpression()          *
  * As it stands, we are not copying a layer's resultcache              *
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/maprasterquery.c	2008-01-03 13:53:03 UTC (rev 7240)
@@ -716,10 +716,10 @@
 /*      Open tile index if we have one.                                 */
     if(layer->tileindex) { /* we have in index file */
-        if(msSHPOpenFile(&tilefile, "rb",
+        if(msShapefileOpen(&tilefile, "rb",
                          msBuildPath3(szPath, map->mappath, map->shapepath,
                                       layer->tileindex)) == -1)
-            if(msSHPOpenFile(&tilefile, "rb", msBuildPath(szPath, map->mappath, layer->tileindex)) == -1)
+            if(msShapefileOpen(&tilefile, "rb", msBuildPath(szPath, map->mappath, layer->tileindex)) == -1)
                 return(MS_FAILURE);
         tileitemindex = msDBFGetItemIndex(tilefile.hDBF, layer->tileitem);
@@ -732,7 +732,7 @@
         if((map->projection.numargs > 0) && (layer->projection.numargs > 0))
             msProjectRect(&map->projection, &layer->projection, &searchrect); /* project the searchrect to source coords */
 #endif
-        status = msSHPWhichShapes(&tilefile, searchrect, layer->debug);
+        status = msShapefileWhichShapes(&tilefile, searchrect, layer->debug);
         if(status != MS_SUCCESS)
             numtiles = 0; /* could be MS_DONE or MS_FAILURE */
         else
@@ -842,7 +842,7 @@
     } /* next tile */
     if(layer->tileindex) /* tiling clean-up */
-        msSHPCloseFile(&tilefile);
+        msShapefileClose(&tilefile);
 /*      On failure, or empty result set, cleanup the rlinfo since we    */
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c	2008-01-03 13:53:03 UTC (rev 7240)
@@ -1030,14 +1030,14 @@
       return NULL;
     if(type == -1)
-      status = msSHPOpenFile(shapefile, "rb", filename);
+      status = msShapefileOpen(shapefile, "rb", filename);
     else if (type == -2)
-      status = msSHPOpenFile(shapefile, "rb+", filename);
+      status = msShapefileOpen(shapefile, "rb+", filename);
     else
-      status = msSHPCreateFile(shapefile, filename, type);
+      status = msShapefileCreate(shapefile, filename, type);
     if(status == -1) {
-      msSHPCloseFile(shapefile);
+      msShapefileClose(shapefile);
       free(shapefile);
       return NULL;
@@ -1046,7 +1046,7 @@
 void shapefileObj_destroy(shapefileObj *self) {
-    msSHPCloseFile(self);
+    msShapefileClose(self);
     free(self);
Modified: trunk/mapserver/mapscript/swiginc/shapefile.i
--- trunk/mapserver/mapscript/swiginc/shapefile.i	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/mapscript/swiginc/shapefile.i	2008-01-03 13:53:03 UTC (rev 7240)
@@ -42,14 +42,14 @@
             return NULL;
         if (type == -1)
         else
         if (status == -1) {
             free(shapefile);
             return NULL;
@@ -59,7 +59,7 @@
     ~shapefileObj()
         free(self);
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/mapshape.c	2008-01-03 13:53:03 UTC (rev 7240)
@@ -1326,13 +1326,13 @@
   return MS_SUCCESS;
-int msSHPOpenFile(shapefileObj *shpfile, char *mode, char *filename)
+int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename)
   int i;
   char *dbfFilename;
   if(!filename) {
-    msSetError(MS_IOERR, "No (NULL) filename provided.", "msSHPOpenFile()");
+    msSetError(MS_IOERR, "No (NULL) filename provided.", "msShapefileOpen()");
     return(-1);
@@ -1348,7 +1348,7 @@
     shpfile->hSHP = msSHPOpen( filename, mode);
   if(!shpfile->hSHP) {
-    msSetError(MS_IOERR, "(%s)", "msSHPOpenFile()", filename);
+    msSetError(MS_IOERR, "(%s)", "msShapefileOpen()", filename);
     return(-1);
@@ -1374,7 +1374,7 @@
   shpfile->hDBF = msDBFOpen(dbfFilename, "rb");
   if(!shpfile->hDBF) {
-    msSetError(MS_IOERR, "(%s)", "msSHPOpenFile()", dbfFilename);
+    msSetError(MS_IOERR, "(%s)", "msShapefileOpen()", dbfFilename);
     free(dbfFilename);
     return(-1);
@@ -1385,7 +1385,7 @@
 /* Creates a new shapefile */
-int msSHPCreateFile(shapefileObj *shpfile, char *filename, int type)
+int msShapefileCreate(shapefileObj *shpfile, char *filename, int type)
   if(type != SHP_POINT && type != SHP_MULTIPOINT && type != SHP_ARC &&
      type != SHP_POLYGON &&
@@ -1417,7 +1417,7 @@
   return(0);
-void msSHPCloseFile(shapefileObj *shpfile)
+void msShapefileClose(shapefileObj *shpfile)
   if (shpfile && shpfile->isopen == MS_TRUE) { /* Silently return if called with NULL shpfile by freeLayer() */
     if(shpfile->hSHP) msSHPClose(shpfile->hSHP);
@@ -1428,7 +1428,7 @@
 /* status array lives in the shpfile, can return MS_SUCCESS/MS_FAILURE/MS_DONE */
-int msSHPWhichShapes(shapefileObj *shpfile, rectObj rect, int debug)
+int msShapefileWhichShapes(shapefileObj *shpfile, rectObj rect, int debug)
   int i;
   rectObj shaperect;
@@ -1448,14 +1448,14 @@
   if(msRectContained(&shpfile->bounds, &rect) == MS_TRUE) {
     shpfile->status = msAllocBitArray(shpfile->numshapes);
     if(!shpfile->status) {
-      msSetError(MS_MEMERR, NULL, "msSHPWhichShapes()");
+      msSetError(MS_MEMERR, NULL, "msShapefileWhichShapes()");
       return(MS_FAILURE);
     for(i=0;i<shpfile->numshapes;i++)
       msSetBit(shpfile->status, i, 1);
   } else {
     if((filename = (char *)malloc(strlen(shpfile->source)+strlen(MS_INDEX_EXTENSION)+1)) == NULL) {
       return(MS_FAILURE);
     sprintf(filename, "%s%s", shpfile->source, MS_INDEX_EXTENSION);
@@ -1468,7 +1468,7 @@
     else { /* no index  */
         return(MS_FAILURE);
@@ -1530,8 +1530,8 @@
     /* we need tSHP->tileshpfile if we're not working with a layer */
     tSHP->tileshpfile = (shapefileObj *) malloc(sizeof(shapefileObj));
-    if(msSHPOpenFile(tSHP->tileshpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->tileindex)) == -1)
-      if(msSHPOpenFile(tSHP->tileshpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->tileindex)) == -1)
+    if(msShapefileOpen(tSHP->tileshpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->tileindex)) == -1)
+      if(msShapefileOpen(tSHP->tileshpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->tileindex)) == -1)
         return(MS_FAILURE);
@@ -1551,15 +1551,15 @@
     /* open the shapefile */
 #ifndef IGNORE_MISSING_DATA
-    if(msSHPOpenFile(tSHP->shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename)) == -1) {
-      if(msSHPOpenFile(tSHP->shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename)) == -1) {
+    if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, filename)) == -1) {
+      if(msShapefileOpen(tSHP->shpfile, "rb", msBuildPath(szPath, layer->map->mappath, filename)) == -1) {
         if( layer->debug || layer->map->debug ) msDebug( "Unable to open file %s for layer %s ... fatal error.\n", filename, layer->name );
         return(MS_FAILURE);
 #else
         if( layer->debug || layer->map->debug ) msDebug( "Unable to open file %s for layer %s ... ignoring this missing data.\n", filename, layer->name );
         continue; /* check again */
@@ -1589,7 +1589,7 @@
     return(MS_FAILURE);
-  msSHPCloseFile(tSHP->shpfile); /* close previously opened files */
+  msShapefileClose(tSHP->shpfile); /* close previously opened files */
   if(tSHP->tilelayerindex != -1) {  /* does the tileindex reference another layer */
     layerObj *tlp;
@@ -1614,29 +1614,29 @@
           return(MS_FAILURE);
 #else
 #endif
-      status = msSHPWhichShapes(tSHP->shpfile, rect, layer->debug);
+      status = msShapefileWhichShapes(tSHP->shpfile, rect, layer->debug);
       if(status == MS_DONE) {
           /* Close and continue to next tile */
           continue;
       else if(status != MS_SUCCESS) {
           return(MS_FAILURE);
@@ -1648,7 +1648,7 @@
   } else { /* or reference a shapefile directly */
-    status = msSHPWhichShapes(tSHP->tileshpfile, rect, layer->debug);
+    status = msShapefileWhichShapes(tSHP->tileshpfile, rect, layer->debug);
     if(status != MS_SUCCESS) return(status); /* could be MS_DONE or MS_FAILURE */
     /* position the source at the FIRST shapefile */
@@ -1665,29 +1665,29 @@
             return(MS_FAILURE);
 #else
 #endif
             continue;
             return(MS_FAILURE);
@@ -1728,7 +1728,7 @@
     while(i<tSHP->shpfile->numshapes && !msGetBit(tSHP->shpfile->status,i)) i++; /* next "in" shape */
     if(i == tSHP->shpfile->numshapes) { /* done with this tile, need a new one */
-      msSHPCloseFile(tSHP->shpfile); /* clean up */
+      msShapefileClose(tSHP->shpfile); /* clean up */
       /* position the source to the NEXT shapefile based on the tileindex */
@@ -1752,29 +1752,29 @@
               return(MS_FAILURE);
 #else
 #endif
-          status = msSHPWhichShapes(tSHP->shpfile, tSHP->tileshpfile->statusbounds, layer->debug);
+          status = msShapefileWhichShapes(tSHP->shpfile, tSHP->tileshpfile->statusbounds, layer->debug);
               continue;
               return(MS_FAILURE);
@@ -1804,28 +1804,28 @@
                 return(MS_FAILURE);
 #else
 #endif
               continue;
             } else if(status != MS_SUCCESS) {
               return(MS_FAILURE);
@@ -1888,7 +1888,7 @@
   if((tile < 0) || (tile >= tSHP->tileshpfile->numshapes)) return(MS_FAILURE); /* invalid tile id */
   if(tile != tSHP->tileshpfile->lastshape) { /* correct tile is not currenly open so open the correct tile */
-    msSHPCloseFile(tSHP->shpfile); /* close current tile */
+    msShapefileClose(tSHP->shpfile); /* close current tile */
     if(!layer->data) /* assume whole filename is in attribute field */
       filename = (char*) msDBFReadStringAttribute(tSHP->tileshpfile->hDBF, tile, layer->tileitemindex);
@@ -1899,8 +1899,8 @@
     /* open the shapefile, since a specific tile was request an error should be generated if that tile does not exist */
     if(strlen(filename) == 0) return(MS_FAILURE);
         return(MS_FAILURE);
@@ -1926,7 +1926,7 @@
   tSHP = layer->layerinfo;
   if(tSHP) {
     free(tSHP->shpfile);
@@ -1936,7 +1936,7 @@
       tlp = (GET_LAYER(layer->map, tSHP->tilelayerindex));
       msLayerClose(tlp);
     } else {
-      msSHPCloseFile(tSHP->tileshpfile);
+      msShapefileClose(tSHP->tileshpfile);
       free(tSHP->tileshpfile);
@@ -2095,8 +2095,8 @@
   layer->layerinfo = shpfile;
-  if(msSHPOpenFile(shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data)) == -1) {
-    if(msSHPOpenFile(shpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->data)) == -1) {
+  if(msShapefileOpen(shpfile, "rb", msBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data)) == -1) {
+    if(msShapefileOpen(shpfile, "rb", msBuildPath(szPath, layer->map->mappath, layer->data)) == -1) {
       layer->layerinfo = NULL;
       free(shpfile);
       return MS_FAILURE;
@@ -2127,7 +2127,7 @@
     return MS_FAILURE;
-  status = msSHPWhichShapes(shpfile, rect, layer->debug);
+  status = msShapefileWhichShapes(shpfile, rect, layer->debug);
     return status;
@@ -2225,7 +2225,7 @@
   shpfile = layer->layerinfo;
   if(!shpfile) return MS_SUCCESS; /* nothing to do */
-  msSHPCloseFile(shpfile);
+  msShapefileClose(shpfile);
   free(layer->layerinfo);
Modified: trunk/mapserver/mapshape.h
--- trunk/mapserver/mapshape.h	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/mapshape.h	2008-01-03 13:53:03 UTC (rev 7240)
@@ -176,10 +176,10 @@
 /* shapefileObj function prototypes  */
-MS_DLL_EXPORT int msSHPOpenFile(shapefileObj *shpfile, char *mode, char *filename);
-MS_DLL_EXPORT int msSHPCreateFile(shapefileObj *shpfile, char *filename, int type);
-MS_DLL_EXPORT void msSHPCloseFile(shapefileObj *shpfile);
-MS_DLL_EXPORT int msSHPWhichShapes(shapefileObj *shpfile, rectObj rect, int debug);
+MS_DLL_EXPORT int msShapefileOpen(shapefileObj *shpfile, char *mode, char *filename);
+MS_DLL_EXPORT int msShapefileCreate(shapefileObj *shpfile, char *filename, int type);
+MS_DLL_EXPORT void msShapefileClose(shapefileObj *shpfile);
+MS_DLL_EXPORT int msShapefileWhichShapes(shapefileObj *shpfile, rectObj rect, int debug);
 /* SHP/SHX function prototypes */
 MS_DLL_EXPORT SHPHandle msSHPOpen( const char * pszShapeFile, const char * pszAccess );
Modified: trunk/mapserver/shptree.c
--- trunk/mapserver/shptree.c	2008-01-03 13:48:36 UTC (rev 7239)
+++ trunk/mapserver/shptree.c	2008-01-03 13:53:03 UTC (rev 7240)
@@ -123,7 +123,7 @@
       byte_order = MS_NEW_MSB_ORDER;
-  if(msSHPOpenFile(&shapefile, "rb", argv[1]) == -1) {
+  if(msShapefileOpen(&shapefile, "rb", argv[1]) == -1) {
     fprintf(stdout, "Error opening shapefile %s.\n", argv[1]);
     exit(0);
@@ -148,7 +148,7 @@
   ** Clean things up
-  msSHPCloseFile(&shapefile);
+  msShapefileClose(&shapefile);
   return(0);
