[mapserver-commits] r7249 - in branches/branch-5-0/mapserver: . mapscript/csharp/examples mapscript/doc mapscript/swiginc
Mon Jan 7 10:43:27 EST 2008
Author: tamas
Date: 2008-01-07 10:43:27 -0500 (Mon, 07 Jan 2008)
New Revision: 7249
   branches/branch-5-0/mapserver/HISTORY.TXT
   branches/branch-5-0/mapserver/mapobject.c
   branches/branch-5-0/mapserver/mapscript/csharp/examples/drawquery.cs
   branches/branch-5-0/mapserver/mapscript/doc/mapscript.txt
   branches/branch-5-0/mapserver/mapscript/swiginc/map.i
   branches/branch-5-0/mapserver/mapscript/swiginc/rect.i
   branches/branch-5-0/mapserver/mapserver.h
Reverting r7245
Modified: branches/branch-5-0/mapserver/HISTORY.TXT
--- branches/branch-5-0/mapserver/HISTORY.TXT	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/HISTORY.TXT	2008-01-07 15:43:27 UTC (rev 7249)
@@ -12,9 +12,6 @@
 Current Version (SVN branch-5-0)
-- Implement mapObj.setCenter, mapObj.offsetExtent, mapObj.scaleExtent,
-  rectObj.getCenter at the SWIG API (#2346)
 - SLD using a single BBOX filter should generate an SQL ststement for
   oracle/postgis/ogr (#2450)
Modified: branches/branch-5-0/mapserver/mapobject.c
--- branches/branch-5-0/mapserver/mapobject.c	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/mapobject.c	2008-01-07 15:43:27 UTC (rev 7249)
@@ -256,65 +256,6 @@
-/*                           msMapOffsetExtent()                        */
-int msMapOffsetExtent( mapObj *map, double x, double y)
-	return msMapSetExtent( map,
-                        map->extent.minx + x, map->extent.miny + y,
-		                map->extent.maxx + x, map->extent.maxy + y);
-/*                           msMapScaleExtent()                         */
-int msMapScaleExtent( mapObj *map, double zoomfactor,
-					 double minscaledenom, double maxscaledenom)
-	double geo_width, geo_height, center_x, center_y, md;
-	if (zoomfactor <= 0.0) {
-		msSetError(MS_MISCERR, "The given zoomfactor is invalid", "msMapScaleExtent()");
-	geo_width = map->extent.maxx - map->extent.minx;
-    geo_height = map->extent.maxy - map->extent.miny;
-    center_x = map->extent.minx + geo_width * 0.5;
-    center_y = map->extent.miny + geo_height * 0.5;
-	geo_width *= zoomfactor;
-	if (minscaledenom > 0 || maxscaledenom > 0) {
-		/* ensure we are within the valid scale domain */
-		md = (map->width-1)/(map->resolution * msInchesPerUnit(map->units, center_y));
-		if (minscaledenom > 0 && geo_width < minscaledenom * md)
-			geo_width = minscaledenom * md;
-		if (maxscaledenom > 0 && geo_width > maxscaledenom * md)
-			geo_width = maxscaledenom * md;
-	geo_width *= 0.5;
-	geo_height = geo_width * map->height / map->width;
-                        center_x - geo_width, center_y - geo_height,
-		                center_x + geo_width, center_y + geo_height);
-/*                           msMapSetCenter()                           */
-int msMapSetCenter( mapObj *map, pointObj *center)
-	return msMapOffsetExtent(map, center->x - (map->extent.minx + map->extent.maxx) * 0.5,
-		                          center->y - (map->extent.miny + map->extent.maxy) * 0.5);
 /*                           msMapSetRotation()                         */
Modified: branches/branch-5-0/mapserver/mapscript/csharp/examples/drawquery.cs
--- branches/branch-5-0/mapserver/mapscript/csharp/examples/drawquery.cs	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/mapscript/csharp/examples/drawquery.cs	2008-01-07 15:43:27 UTC (rev 7249)
@@ -98,7 +98,6 @@
 			if (zoomToResults)
 				map.setExtent(query_bounds.minx, query_bounds.miny, query_bounds.maxx, query_bounds.maxy);
-				map.scaleExtent(1.2, 0, 0); // increasing the visible area
 				Console.WriteLine("Current map scale: 1:" + (int)map.scaledenom);
Modified: branches/branch-5-0/mapserver/mapscript/doc/mapscript.txt
--- branches/branch-5-0/mapserver/mapscript/doc/mapscript.txt	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/mapscript/doc/mapscript.txt	2008-01-07 15:43:27 UTC (rev 7249)
@@ -2116,21 +2116,6 @@
 setExtent( float minx, float miny, float miny, float maxy ) : int
     Set the map extent, returns MS_SUCCESS or MS_FAILURE.
-offsetExtent( float x, float y) : int
-    Offset the map extent based on the given distances in map coordinates,
-    returns MS_SUCCESS or MS_FAILURE.
-scaleExtent( float zoomfactor, float minscaledenom, float maxscaledenom) : int
-    Scale the map extent using the zoomfactor and ensure the extent
-    within the minscaledenom and maxscaledenom domain.
-    If minscaledenom and/or maxscaledenom is 0 then the parameter is
-    not taken into account.
-setCenter( pointObj_ center ) : int
-    Set the map center to the given map point,
 setFontSet( string filename ) : int
     Load fonts defined in *filename* into map fontset.  The existing
     fontset is cleared.  Returns MS_SUCCESS or MS_FAILURE.
Modified: branches/branch-5-0/mapserver/mapscript/swiginc/map.i
--- branches/branch-5-0/mapserver/mapscript/swiginc/map.i	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/mapscript/swiginc/map.i	2008-01-07 15:43:27 UTC (rev 7249)
@@ -80,19 +80,6 @@
 	return msMapSetExtent( self, minx, miny, maxx, maxy );
-    int offsetExtent(double x, double y) {
-	return msMapOffsetExtent( self, x, y );
-    int scaleExtent(double zoomfactor,
-					 double minscaledenom, double maxscaledenom) {
-	return msMapScaleExtent( self, zoomfactor, minscaledenom, maxscaledenom );
-    int setCenter(pointObj *center) {
-	return msMapSetCenter( self, center );
     /* recent rotation work makes setSize the only reliable
        method for changing the image size.  direct access is deprecated. */
     int setSize(int width, int height)
Modified: branches/branch-5-0/mapserver/mapscript/swiginc/rect.i
--- branches/branch-5-0/mapserver/mapscript/swiginc/rect.i	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/mapscript/swiginc/rect.i	2008-01-07 15:43:27 UTC (rev 7249)
@@ -70,21 +70,6 @@
         return MS_SUCCESS;
-    %newobject getCenter;
-    pointObj *getCenter()
-		pointObj *center;
-        center = (pointObj *)calloc(1, sizeof(pointObj));
-        if (!center) {
-            msSetError(2, "Failed to allocate memory for point", "getCenter()");
-            return NULL;
-        center->x = (self->minx + self->maxx)/2;
-        center->y = (self->miny + self->maxy)/2;
-        return center;
     %newobject toPolygon;
     shapeObj *toPolygon()
Modified: branches/branch-5-0/mapserver/mapserver.h
--- branches/branch-5-0/mapserver/mapserver.h	2008-01-05 16:29:43 UTC (rev 7248)
+++ branches/branch-5-0/mapserver/mapserver.h	2008-01-07 15:43:27 UTC (rev 7249)
@@ -1355,10 +1355,6 @@
 MS_DLL_EXPORT int msMapSetExtent(mapObj *map, double minx, double miny,
                                  double maxx, double maxy);
-MS_DLL_EXPORT int msMapOffsetExtent( mapObj *map, double x, double y);
-MS_DLL_EXPORT int msMapScaleExtent( mapObj *map, double zoomfactor,
-					 double minscaledenom, double maxscaledenom);
-MS_DLL_EXPORT int msMapSetCenter( mapObj *map, pointObj *center);
 MS_DLL_EXPORT int msMapSetRotation( mapObj *map, double rotation_angle );
 MS_DLL_EXPORT int msMapSetSize( mapObj *map, int width, int height );
