[mapserver-commits] r7252 - in trunk/mapserver/mapscript/perl: . examples
Thu Jan 10 09:37:00 EST 2008
Author: unicoletti
Date: 2008-01-10 09:37:00 -0500 (Thu, 10 Jan 2008)
New Revision: 7252
Added:
   trunk/mapserver/mapscript/perl/examples/RFC24.pl
   trunk/mapserver/mapscript/perl/plmodule.i
#2442: implementation of RFC24, item 3.2 for perl
Added: trunk/mapserver/mapscript/perl/examples/RFC24.pl
--- trunk/mapserver/mapscript/perl/examples/RFC24.pl	                        (rev 0)
+++ trunk/mapserver/mapscript/perl/examples/RFC24.pl	2008-01-10 14:37:00 UTC (rev 7252)
@@ -0,0 +1,106 @@
+#!/usr/bin/perl
+use mapscript;
+$file=$ARGV[0];
+# utility
+sub assertNotNull {
+	my ($o, $test) = @_;
+	if ($o) {
+		print $test . "  PASSED\n";
+	} else {
+		print $test . "  FAILED\n";
+sub dumpHash {
+	my ($hashmap) = @_;
+	print "Dumping hashmap: $hashmap\n";
+	for my $k ( keys %$hashmap ) {
+		    print "\t".$k.": ".$hashmap{$k}."\n";
+# layerObj
+sub testGetLayerObj {
+	my $map = new mapscript::mapObj($file);
+	my $layer = $map->getLayer(1);
+	$map = undef;
+	assertNotNull( $layer->{map} , "testGetLayerObj");
+	#$layer->{map}->draw()->save("/tmp/map.png");
+sub testGetLayerObjByName {
+	my $layer = $map->getLayerByName("POLYGON");
+	$map = undef;
+	assertNotNull( $layer->{map} , "testGetLayerObjByName");
+sub testLayerObj {
+	my $layer = new mapscript::layerObj($map);
+	$map = undef;
+	assertNotNull( $layer->{map} , "testLayerObj");
+sub testInsertLayerObj {
+	my $layer = new mapscript::layerObj(undef);
+	my $position = $map->insertLayer($layer);
+	$map = undef;
+	assertNotNull( $position == 7 , "testInsertLayerObj position");
+	assertNotNull( $layer->{map} , "testInsertLayerObj notnull");
+# classObj
+sub testGetClassObj {
+	#dumpHash(mapscript::getPARENT_PTRS());
+	my $clazz = $layer->getClass(0);
+	#$clazz->{layer}->{map}->draw()->save("/tmp/map1.png");
+	#print "parent layer=".$clazz->{layer}."\n";
+	$map = undef; $layer=undef;
+	assertNotNull( $clazz->{layer} , "testGetClassObj");
+	#$clazz->{layer}->{map}->draw()->save("/tmp/map2.png");
+sub testClassObj {
+	my $clazz = new mapscript::classObj($layer);
+	assertNotNull( $clazz->{layer} , "testClassObj");
+sub testInsertClassObj {
+	my $clazz = new mapscript::classObj(undef);
+	my $position = $layer->insertClass($clazz);
+	assertNotNull( $position == 2 , "testInsertClassObj position");
+	assertNotNull( $clazz->{layer} , "testInsertClassObj notnull");
+if ( ! $file ) {
+	print "Usage: RFC24.pl file.map\n";
+	exit 1;
+testGetLayerObj;
+testGetLayerObjByName;
+testLayerObj;
+testInsertLayerObj;
+testGetClassObj;
+testClassObj;
+testInsertClassObj;
+$hashmap=mapscript::getPARENT_PTRS();
+assertNotNull( keys( %$hashmap )==0 , "checking that hashmap of parent ptrs is empty");
+print "No of keys:".keys( %$hashmap )."\n";
+dumpHash($hashmap);
Modified: trunk/mapserver/mapscript/perl/plmodule.i
--- trunk/mapserver/mapscript/perl/plmodule.i	2008-01-08 17:04:53 UTC (rev 7251)
+++ trunk/mapserver/mapscript/perl/plmodule.i	2008-01-10 14:37:00 UTC (rev 7252)
@@ -23,3 +23,153 @@
     msSetError(MS_MISCERR, "Error initializing MapServer/Mapscript.", "msSetup()");
+RFC-24 implementation follows
+   Modified constructor according to:
+   - cache population and sync, item 3.2
+   - reference counter since Perl does not obey %newobject
+%allowexception;
+%exception layer {
+	/* Accessing layer */
+	$action;
+	MS_REFCNT_INCR(result);
+%exception map {
+	/* Accessing map */
+	$action;
+%feature("shadow") layerObj(mapObj *map)
+sub new {
+        my $pkg = shift;
+        my $self = mapscriptc::new_layerObj(@_);
+        bless $self, $pkg if defined($self);
+        if (defined($_[0])) {
+                # parent reference
+                mapscript::RFC24_ADD_PARENT_REF( tied(%$self), $_[0]);
+        return $self;
+%feature("shadow") getLayer(int i)
+sub getLayer {
+        my $layer = mapscriptc::mapObj_getLayer(@_);
+        if (defined($layer)) {
+                #print "l=$layer,m=$_[0]\n";
+                mapscript::RFC24_ADD_PARENT_REF( tied(%$layer) , $_[0]);
+        return $layer;
+%feature("shadow") getLayerByName(char* name)
+sub getLayerByName {
+        my $layer = mapscriptc::mapObj_getLayerByName(@_);
+        return $layer;
+%feature("shadow") insertLayer
+sub insertLayer {
+        my $idx = mapscriptc::mapObj_insertLayer(@_);
+        my $layer=$_[1];
+        mapscript::RFC24_ADD_PARENT_REF(tied(%$layer), $_[0]);
+        return $idx;
+%feature("shadow") ~layerObj()
+sub DESTROY {
+        return unless $_[0]->isa('HASH');
+        my $self = tied(%{$_[0]});
+        return unless defined $self;
+        delete $ITERATORS{$self};
+        mapscriptc::delete_layerObj($self);
+        # remove parent reference
+        mapscript::RFC24_DEL_PARENT_REF($self);
+%feature("shadow") classObj(layerObj *layer)
+sub new {
+        my $pkg = shift;
+        my $self = mapscriptc::new_classObj(@_);
+        return $self;
+%feature("shadow") getClass(int i)
+sub getClass {
+        my $clazz = mapscriptc::layerObj_getClass(@_);
+        if (defined($clazz)) {
+                mapscript::RFC24_ADD_PARENT_REF( tied(%$clazz) , $_[0]);
+        return $clazz;
+%feature("shadow") insertClass
+sub insertClass {
+        my $idx = mapscriptc::layerObj_insertClass(@_);
+        my $clazz=$_[1];
+        mapscript::RFC24_ADD_PARENT_REF(tied(%$clazz), $_[0]);
+        return $idx;
+%feature("shadow") ~classObj()
+sub DESTROY {
+        mapscriptc::delete_classObj($self);
+%perlcode %{
+        %PARENT_PTRS=();
+        sub RFC24_ADD_PARENT_REF {
+                my ($child, $parent)=@_;
+                $PARENT_PTRS{ $$child }=$parent;
+        sub RFC24_DEL_PARENT_REF {
+                my ($child)=@_;
+                delete $PARENT_PTRS{ $$child };
+        # USE THIS function only for debugging!
+        sub getPARENT_PTRS {
+                return \%PARENT_PTRS;
