[mapserver-commits] r7335 - trunk/mapserver
Wed Jan 30 19:34:35 EST 2008
Author: tomkralidis
Date: 2008-01-30 19:34:35 -0500 (Wed, 30 Jan 2008)
New Revision: 7335
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwcs.c
better handling of REQUEST parameter (#2490)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-01-31 00:11:25 UTC (rev 7334)
+++ trunk/mapserver/HISTORY.TXT	2008-01-31 00:34:35 UTC (rev 7335)
@@ -13,6 +13,8 @@
 Current Version (5.1-dev, SVN trunk):
+- mapwcs.c: better handling of REQUEST parameter (#2490)
 - mapwcs.c: point to correct exception schema (#2481)
 - mapows.c: add version negotiation (#996)
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2008-01-31 00:11:25 UTC (rev 7334)
+++ trunk/mapserver/mapwcs.c	2008-01-31 00:34:35 UTC (rev 7335)
@@ -1652,6 +1652,17 @@
   ** ok, it's a WCS request, check what we can at a global level and then dispatch to the various request handlers
+  /* check for existence of REQUEST parameter */
+  if (!params->request) {
+    msSetError(MS_WCSERR, "Missing REQUEST parameter", "msWCSDispatch()");
+    msWCSException(map, params->request, "MissingParameterValue", "request");
+    msWCSFreeParams(params); /* clean up */
+    free(params);
+    params = NULL;
+    return MS_FAILURE;
   /* if either DescribeCoverage or GetCoverage, and version not passed
      then return an exception */
   if (((strcasecmp(params->request, "DescribeCoverage") == 0) ||
@@ -1694,6 +1705,14 @@
     return msWCSDescribeCoverage(map, params);
   else if(strcasecmp(params->request, "GetCoverage") == 0)
     return msWCSGetCoverage(map, request, params);
+  else {
+    msSetError(MS_WCSERR, "Invalid REQUEST parameter \"%s\"", "msWCSDispatch()", params->request);
+    msWCSException(map, params->request, "InvalidParameterValue", "request");
+    free(params);
+    params = NULL;
   return MS_DONE; /* not a WCS request, let MapServer take it */
 #else
