[mapserver-commits] r7770 - trunk/mapserver
Wed Jul 2 11:35:50 EDT 2008
Author: dmorissette
Date: 2008-07-02 11:35:49 -0400 (Wed, 02 Jul 2008)
New Revision: 7770
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/shp2img.c
Added more debug/tuning output to shp2img as well (#2673)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-07-02 14:25:45 UTC (rev 7769)
+++ trunk/mapserver/HISTORY.TXT	2008-07-02 15:35:49 UTC (rev 7770)
@@ -12,7 +12,7 @@
 Current Version (SVN trunk):
-- Added more debug/tuning output to mapserv at debug level 2 (#2673)
+- Added more debug/tuning output to mapserv and shp2img at debug level 2 (#2673)
 - maptemplate.c: removed extra line feeds from mime header output. (#2672)
Modified: trunk/mapserver/shp2img.c
--- trunk/mapserver/shp2img.c	2008-07-02 14:25:45 UTC (rev 7769)
+++ trunk/mapserver/shp2img.c	2008-07-02 15:35:49 UTC (rev 7770)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Commandline .map rendering utility, mostly for testing.
@@ -28,6 +28,7 @@
 #include "mapserver.h"
+#include "maptime.h"
 MS_CVSID("$Id$")
@@ -53,11 +54,30 @@
     if (strcmp(argv[i],"-c") == 0) { /* user specified number of draws */
       iterations = atoi(argv[i+1]);
       printf("We will draw %d times...\n", iterations);
-      break;
+      continue;
+    if(strcmp(argv[i], "-all_debug") == 0) /* global debug */
+        int debug_level = atoi(argv[++i]);
+        msSetGlobalDebugLevel(debug_level);
+        /* Send output to stderr by default */
+        if (msGetErrorFile() == NULL)
+            msSetErrorFile("stderr");
+        continue;
   for(draws=0; draws<iterations; draws++) {
+  struct mstimeval requeststarttime, requestendtime;
+  if(msGetGlobalDebugLevel() >= MS_DEBUGLEVEL_TUNING)
+      msGettimeofday(&requeststarttime, NULL);
   if(argc > 1 && strcmp(argv[1], "-v") == 0) {
     printf("%s\n", msGetVersion());
@@ -173,20 +193,18 @@
       i+=2;
-    if(strcmp(argv[i], "-all_debug") == 0) /* debug */
+        /* msSetGlobalDebugLevel() already called. Just need to force debug
+         * level in map and all layers
         map->debug = debug_level;
         for(j=0; j<map->numlayers; j++) {
             GET_LAYER(map, j)->debug = debug_level;
-        msSetGlobalDebugLevel(debug_level);
-        /* Send output to stderr by default */
-        if (msGetErrorFile() == NULL)
-            msSetErrorFile("stderr");
     if(strcmp(argv[i], "-map_debug") == 0) /* debug */
@@ -282,6 +300,14 @@
   msFreeImage(image);
   msFreeMap(map);
+  if(msGetGlobalDebugLevel() >= MS_DEBUGLEVEL_TUNING) {
+    msGettimeofday(&requestendtime, NULL);
+    msDebug("shp2img total time: %.3fs\n",
+            (requestendtime.tv_sec+requestendtime.tv_usec/1.0e6)-
+            (requeststarttime.tv_sec+requeststarttime.tv_usec/1.0e6) );
   msCleanup();
 } /*   for(draws=0; draws<iterations; draws++) { */
