[mapserver-commits] r7793 - trunk/mapserver
Tue Jul 8 16:38:55 EDT 2008
Author: Assefa
Date: 2008-07-08 16:38:55 -0400 (Tue, 08 Jul 2008)
New Revision: 7793
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcfilter.c
Fix OGC simple filters on SDE layers (#2685)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-07-08 19:29:56 UTC (rev 7792)
+++ trunk/mapserver/HISTORY.TXT	2008-07-08 20:38:55 UTC (rev 7793)
@@ -13,6 +13,8 @@
 Current Version (SVN Trunk):
+- Fix OGC simple filters on SDE layers (#2685)
 - wfs11 getcapabilities: correct memory corruption (#2686)
 - Allow building against Curl 7.10.6 and older which lack CURLOPT_PROXYAUTH
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2008-07-08 19:29:56 UTC (rev 7792)
+++ trunk/mapserver/mapogcfilter.c	2008-07-08 20:38:55 UTC (rev 7793)
@@ -943,7 +943,8 @@
     bConcatWhere = 0;
     bHasAWhere = 0;
-    if (lp->connectiontype == MS_POSTGIS || lp->connectiontype ==  MS_ORACLESPATIAL)
+    if (lp->connectiontype == MS_POSTGIS || lp->connectiontype ==  MS_ORACLESPATIAL ||
+        lp->connectiontype == MS_SDE || lp->connectiontype == MS_PLUGIN)
       szExpression = FLTGetSQLExpression(psNode, lp);
     /* concatenates the WHERE clause for OGR layers. This only applies if
        the expression was empty or not of an expression string. If there
