[mapserver-commits] r7811 - trunk/mapserver
Tue Jul 15 01:03:28 EDT 2008
Author: sdlime
Date: 2008-07-15 01:03:28 -0400 (Tue, 15 Jul 2008)
New Revision: 7811
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapfile.c
Fixed a bug that prevented using named symbols via URL configuration. (#2700)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-07-10 02:26:21 UTC (rev 7810)
+++ trunk/mapserver/HISTORY.TXT	2008-07-15 05:03:28 UTC (rev 7811)
@@ -12,6 +12,8 @@
 Current Version (SVN trunk)
+- mapfile.c: Fixed a bug that prevented using named symbols via URL configuration. (#2700)
 Version 5.2.0-rc1 (2008-07-09):
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2008-07-10 02:26:21 UTC (rev 7810)
+++ trunk/mapserver/mapfile.c	2008-07-15 05:03:28 UTC (rev 7811)
@@ -4374,11 +4374,11 @@
 	  for(k=0; k<GET_LAYER(map, i)->class[j]->numstyles; k++) {
             if(GET_LAYER(map, i)->class[j]->styles[k]->symbolname) {
               if((GET_LAYER(map, i)->class[j]->styles[k]->symbol =  msGetSymbolIndex(&(map->symbolset), GET_LAYER(map, i)->class[j]->styles[k]->symbolname, MS_TRUE)) == -1) {
-                msSetError(MS_MISCERR, "Undefined overlay symbol \"%s\" in class %d, style %d of layer %s.", "msLoadMap()", GET_LAYER(map, i)->class[j]->styles[k]->symbolname, j, k, GET_LAYER(map, i)->name);
+                msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class %d, style %d of layer %s.", "msLoadMap()", GET_LAYER(map, i)->class[j]->styles[k]->symbolname, j, k, GET_LAYER(map, i)->name);
                 return MS_FAILURE;
@@ -4766,10 +4766,10 @@
       if(msyylex() == CLASS) {
         if((s = getSymbol(2, MS_NUMBER, MS_STRING)) == -1) return MS_FAILURE;
-	      if(s == MS_STRING)
+        if(s == MS_STRING)
           j = msGetClassIndex(GET_LAYER(map, i), msyytext);
         else
-	        j = (int) msyynumber;
+          j = (int) msyynumber;
         if(j>=GET_LAYER(map, i)->numclasses || j<0) {
           msSetError(MS_MISCERR, "Class to be modified not valid.", "msUpdateMapFromURL()");
@@ -4784,13 +4784,26 @@
             return MS_FAILURE;
-          return msUpdateStyleFromString((GET_LAYER(map, i))->class[j]->styles[k], string, MS_TRUE);
+          if(msUpdateStyleFromString((GET_LAYER(map, i))->class[j]->styles[k], string, MS_TRUE) != MS_SUCCESS) return MS_FAILURE;
         } else {
-          return msUpdateClassFromString((GET_LAYER(map, i))->class[j], string, MS_TRUE);
+          if(msUpdateClassFromString((GET_LAYER(map, i))->class[j], string, MS_TRUE) != MS_SUCCESS) return MS_FAILURE;
       } else {
-        return msUpdateLayerFromString((GET_LAYER(map, i)), string, MS_TRUE);
+        if(msUpdateLayerFromString((GET_LAYER(map, i)), string, MS_TRUE) != MS_SUCCESS) return MS_FAILURE;
+      /* make sure any symbol names for this layer have been resolved (bug #2700) */
+      for(j=0; j<GET_LAYER(map, i)->numclasses; j++) {
+	for(k=0; k<GET_LAYER(map, i)->class[j]->numstyles; k++) {
+          if(GET_LAYER(map, i)->class[j]->styles[k]->symbolname && GET_LAYER(map, i)->class[j]->styles[k]->symbol == 0) {
+            if((GET_LAYER(map, i)->class[j]->styles[k]->symbol =  msGetSymbolIndex(&(map->symbolset), GET_LAYER(map, i)->class[j]->styles[k]->symbolname, MS_TRUE)) == -1) {
+              msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class %d, style %d of layer %s.", "msUpdateMapFromURL()", GET_LAYER(map, i)->class[j]->styles[k]->symbolname, j, k, GET_LAYER(map, i)->name);
+              return MS_FAILURE;
       break;
     case(LEGEND):
       return msUpdateLegendFromString(&(map->legend), string, MS_TRUE);
