[mapserver-commits] r7813 - trunk/mapserver/mapscript/php3
Wed Jul 16 10:11:40 EDT 2008
Author: jmckenna
Date: 2008-07-16 10:11:40 -0400 (Wed, 16 Jul 2008)
New Revision: 7813
   trunk/mapserver/mapscript/php3/README
correct queryByPoint tolerance value (#2703)
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README	2008-07-15 15:02:26 UTC (rev 7812)
+++ trunk/mapserver/mapscript/php3/README	2008-07-16 14:11:40 UTC (rev 7813)
@@ -352,7 +352,7 @@
         layer that contains a LAYER TEMPLATE value.
         Mode is MS_SINGLE or MS_MULTIPLE depending on number of results
         you want.
-        Passing buffer <=0 defaults to tolerances set in the map file
+        Passing buffer -1 defaults to tolerances set in the map file
         (in pixels) but you can use a constant buffer (specified in
         ground units) instead.
         Returns MS_SUCCESS if shapes were found or MS_FAILURE if nothing
@@ -671,7 +671,7 @@
         you want.
