[mapserver-commits] r7831 - branches/branch-5-2/mapserver
Mon Jul 28 09:47:55 EDT 2008
Author: Assefa
Date: 2008-07-28 09:47:55 -0400 (Mon, 28 Jul 2008)
New Revision: 7831
   branches/branch-5-2/mapserver/HISTORY.TXT
   branches/branch-5-2/mapserver/mapogcfilter.c
   branches/branch-5-2/mapserver/mapserver.h
Support reading projection parameter for OFC filters (#2712)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT	2008-07-23 03:38:08 UTC (rev 7830)
+++ branches/branch-5-2/mapserver/HISTORY.TXT	2008-07-28 13:47:55 UTC (rev 7831)
@@ -13,6 +13,8 @@
 Current Version (SVN branch-5-2)
+- Support reading projection parameter for OFC filters (#2712)
 - Stop configure execution with an error if path to one of the -config
   scripts is invalid (#2710)
Modified: branches/branch-5-2/mapserver/mapogcfilter.c
--- branches/branch-5-2/mapserver/mapogcfilter.c	2008-07-23 03:38:08 UTC (rev 7830)
+++ branches/branch-5-2/mapserver/mapogcfilter.c	2008-07-28 13:47:55 UTC (rev 7831)
@@ -50,8 +50,9 @@
     return msOGRGeometryToShape(hGeometry, psShape, nType);
-int FLTShapeFromGMLTree(CPLXMLNode *psTree, shapeObj *psShape)
+int FLTShapeFromGMLTree(CPLXMLNode *psTree, shapeObj *psShape, char **ppszSRS)
+    char *pszSRS = NULL;
     if (psTree && psShape)
         CPLXMLNode *psNext = psTree->psNext;
@@ -66,6 +67,11 @@
             FLTogrConvertGeometry(hGeometry, psShape,
                                   OGR_G_GetGeometryType(hGeometry));
+        pszSRS = (char *)CPLGetXMLValue(psTree, "srsName", NULL);
+        if (ppszSRS && pszSRS)
+          *ppszSRS = strdup(pszSRS);
         return MS_TRUE;
@@ -110,6 +116,59 @@
     return MS_TRUE;
+int FTLParseEpsgString(char *pszEpsg, projectionObj *psProj)
+    int nStatus = MS_FALSE;
+    int nTokens = 0;
+    char **tokens = NULL;
+    int nEpsgTmp=0;
+#ifdef USE_PROJ
+    if (pszEpsg && psProj)
+        nTokens = 0;
+        tokens = msStringSplit(pszEpsg,'#', &nTokens);
+        if (tokens && nTokens == 2)
+            char szTmp[32];
+            sprintf(szTmp, "init=epsg:%s",tokens[1]);
+            msInitProjection(psProj);
+            if (msLoadProjectionString(psProj, szTmp) == 0)
+              nStatus = MS_TRUE;
+        else if (tokens &&  nTokens == 1)
+            if (tokens)
+              msFreeCharArray(tokens, nTokens);
+            nTokens = 0;
+            tokens = msStringSplit(pszEpsg,':', &nTokens);
+            nEpsgTmp = -1;
+            if (tokens &&  nTokens == 1)
+                nEpsgTmp = atoi(tokens[0]);
+            else if (tokens &&  nTokens == 2)
+                nEpsgTmp = atoi(tokens[1]);
+            if (nEpsgTmp > 0)
+                char szTmp[32];
+                sprintf(szTmp, "init=epsg:%d",nEpsgTmp);
+        if (tokens)
+#endif
+    return nStatus;
 /*                        FLTGetQueryResultsForNode                     */
@@ -123,13 +182,11 @@
                               int bOnlySpatialFilter)
     char *szExpression = NULL;
-    int bIsBBoxFilter =0, nEpsgTmp = 0, i=0;
+    int bIsBBoxFilter =0,  i=0;
     char *szEPSG = NULL;
     rectObj sQueryRect = map->extent;
     layerObj *lp = NULL;
     char *szClassItem = NULL;
-    char **tokens = NULL;
-    int nTokens = 0;
     projectionObj sProjTmp;
     int bPointQuery = 0, bShapeQuery=0;
     shapeObj *psQueryShape = NULL;
@@ -270,57 +327,23 @@
     if(szEPSG && map->projection.numargs > 0)
-#ifdef USE_PROJ
-        nTokens = 0;
-        tokens = msStringSplit(szEPSG,'#', &nTokens);
-        if (tokens && nTokens == 2)
-            char szTmp[32];
-            sprintf(szTmp, "init=epsg:%s",tokens[1]);
-            msInitProjection(&sProjTmp);
-            if (msLoadProjectionString(&sProjTmp, szTmp) == 0)
-              msProjectRect(&sProjTmp, &map->projection, &sQueryRect);
-        else if (tokens &&  nTokens == 1)
-            if (tokens)
-              msFreeCharArray(tokens, nTokens);
-            nTokens = 0;
-            tokens = msStringSplit(szEPSG,':', &nTokens);
-            nEpsgTmp = -1;
-            if (tokens &&  nTokens == 1)
-                nEpsgTmp = atoi(tokens[0]);
-            else if (tokens &&  nTokens == 2)
-                nEpsgTmp = atoi(tokens[1]);
-            if (nEpsgTmp > 0)
-                char szTmp[32];
-                sprintf(szTmp, "init=epsg:%d",nEpsgTmp);
-        if (tokens)
-#endif
+        if (FTLParseEpsgString(szEPSG, &sProjTmp))
+          msProjectRect(&sProjTmp, &map->projection, &sQueryRect);
     if (szExpression || bIsBBoxFilter ||
         (bOnlySpatialFilter && !bIsBBoxFilter && !bPointQuery && !bShapeQuery))
       status = msQueryByRect(map, lp->index, sQueryRect);
     else if (bPointQuery && psQueryShape && psQueryShape->numlines > 0
              && psQueryShape->line[0].numpoints > 0) /* && dfDistance >=0) */
+        if (psNode->pszSRS &&  map->projection.numargs > 0 &&
+            FTLParseEpsgString(psNode->pszSRS, &sProjTmp))
+           msProjectShape(&sProjTmp, &map->projection, psQueryShape);
-      if (bUseGeos)
+        if (bUseGeos)
             if ((strcasecmp(psNode->pszValue, "DWithin") == 0 ||
                  strcasecmp(psNode->pszValue, "Beyond") == 0 ) &&
@@ -365,6 +388,11 @@
     else if (bShapeQuery && psQueryShape && psQueryShape->numlines > 0
+        /*reproject shape if epsg was set*/
         if (bUseGeos)
@@ -1327,6 +1355,9 @@
         if( psFilterNode->pszValue )
             free( psFilterNode->pszValue );
+        if (psFilterNode->pszSRS)
+          free( psFilterNode->pszSRS);
         if( psFilterNode->pOther )
 #ifdef notdef
@@ -1359,9 +1390,10 @@
     psFilterNode->eType = FILTER_NODE_TYPE_UNDEFINED;
     psFilterNode->pszValue = NULL;
     psFilterNode->pOther = NULL;
+    psFilterNode->pszSRS = NULL;
     psFilterNode->psLeftNode = NULL;
     psFilterNode->psRightNode = NULL;
     return psFilterNode;
@@ -1613,8 +1645,8 @@
                 shapeObj *psShape = NULL;
                 int bPoint = 0, bLine = 0, bPolygon = 0;
                 char *pszUnits = NULL;
                 CPLXMLNode *psGMLElement = NULL, *psDistance=NULL;
@@ -1643,9 +1675,13 @@
                     pszUnits = (char *)CPLGetXMLValue(psDistance, "units", NULL);
                     psShape = (shapeObj *)malloc(sizeof(shapeObj));
                     msInitShape(psShape);
-                    if (FLTShapeFromGMLTree(psGMLElement, psShape))
+                    if (FLTShapeFromGMLTree(psGMLElement, psShape, &pszSRS))
                       /* if (FLTGML2Shape_XMLNode(psPoint, psShape)) */
+                        /*set the srs if available*/
+                        if (pszSRS)
+                          psFilterNode->pszSRS = pszSRS;
                         psFilterNode->psLeftNode = FLTCreateFilterEncodingNode();
                         /* not really using the property name anywhere ?? Is is always */
                         /* Geometry ?  */
@@ -1686,7 +1722,7 @@
                 int  bLine = 0, bPolygon = 0, bPoint=0;
                 CPLXMLNode *psGMLElement = NULL;
@@ -1712,9 +1748,13 @@
+                        if (pszSRS)
                         /* Geometry ?  */
@@ -2457,6 +2497,7 @@
                         nTokens = 0;
                         tokens = msStringSplit(szUnitStr,'#', &nTokens);
+                        msFree(szUnitStr);
                         if (tokens && nTokens >= 1)
                             if (nTokens ==1)
@@ -3759,7 +3800,7 @@
     if (psBox)
         pszSRS = (char *)CPLGetXMLValue(psBox, "srsName", NULL);
-        if (*ppszSRS)
         psCoordinates = CPLGetXMLNode(psBox, "coordinates");
Modified: branches/branch-5-2/mapserver/mapserver.h
--- branches/branch-5-2/mapserver/mapserver.h	2008-07-23 03:38:08 UTC (rev 7830)
+++ branches/branch-5-2/mapserver/mapserver.h	2008-07-28 13:47:55 UTC (rev 7831)
@@ -381,7 +381,7 @@
     FilterNodeType      eType;
     char                *pszValue;
     void                *pOther;
+    char                *pszSRS;
     struct _FilterNode  *psLeftNode;
     struct _FilterNode  *psRightNode;
 } FilterEncodingNode;
