[mapserver-commits] r7640 - in trunk/msautotest/wxs: . expected
Mon Jun 2 20:52:50 EDT 2008
Author: tomkralidis
Date: 2008-06-02 20:52:49 -0400 (Mon, 02 Jun 2008)
New Revision: 7640
Added:
   trunk/msautotest/wxs/expected/wcs_getcov_exception_bands.xml
   trunk/msautotest/wxs/wcs_simple.map
- add test for handle PARAMETER values correctly (#2509)
Added: trunk/msautotest/wxs/expected/wcs_getcov_exception_bands.xml
--- trunk/msautotest/wxs/expected/wcs_getcov_exception_bands.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wcs_getcov_exception_bands.xml	2008-06-03 00:52:49 UTC (rev 7640)
@@ -0,0 +1,8 @@
+Content-type: application/vnd.ogc.se_xml
+<?xml version='1.0' encoding="ISO-8859-1" ?>
+<ServiceExceptionReport version="1.2.0"
+xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengeospatial.net/wcs/1.0.0/OGC-exception.xsd">
+  <ServiceException code="InvalidParameterValue" locator="bands">msWCSGetCoverage(): WCS server error. Error specifying &quot;bands&quot; parameter value(s).
+  </ServiceException>
+</ServiceExceptionReport>
Modified: trunk/msautotest/wxs/wcs_simple.map
--- trunk/msautotest/wxs/wcs_simple.map	2008-06-03 00:49:41 UTC (rev 7639)
+++ trunk/msautotest/wxs/wcs_simple.map	2008-06-03 00:52:49 UTC (rev 7640)
@@ -59,6 +59,9 @@
 # GetCoverage to AAIGRID 1.0
 # RUN_PARMS: wcs_getcov_grd_10.dat [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&RESX=30&RESY=30&FORMAT=AAIGRID&BBOX=0,0,400,300&COVERAGE=grey&CRS=EPSG:32611" > [RESULT]
+# GetCoverage exception (invalid bands value)
+# RUN_PARMS: wcs_getcov_exception_bands.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&RESX=30&RESY=30&FORMAT=AAIGRID&BBOX=0,0,400,300&COVERAGE=grey&CRS=EPSG:32611&bands=FOO" > [RESULT]
 # GetCoverage to AAIGRID 1.1 (normal CRS)
 # RUN_PARMS: wcs_getcov_grd_11.dat [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.1.0&REQUEST=GetCoverage&FORMAT=AAIGRID&BOUNDINGBOX=0,0,400,300,urn:ogc:def:crs:EPSG::32611&IDENTIFIER=grey&GridCS=urn:ogc:def:crs:OGC::imageCRS&GridType=urn:ogc:def:method:WCS:1.1:2dGridIn2dCrs&GridOrigin=0,295&GridOffsets=30,-30" > [RESULT]
