[mapserver-commits] r7711 - trunk/mapserver
Thu Jun 19 20:05:43 EDT 2008
Author: tomkralidis
Date: 2008-06-19 20:05:43 -0400 (Thu, 19 Jun 2008)
New Revision: 7711
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcsos.c
support invalid procedure in GetObservation (#2561)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-19 18:42:10 UTC (rev 7710)
+++ trunk/mapserver/HISTORY.TXT	2008-06-20 00:05:43 UTC (rev 7711)
@@ -17,6 +17,8 @@
 Version 5.2.0-beta2 (2008-06-18):
+- mapogcsos.c: support invalid procedure in GetObservation (#2561)
 - Fixed possible buffer overrun with Oracle Spatial driver (#2572)
 - mapogcsos.c: support srsName in GetObservation (#2414)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2008-06-19 18:42:10 UTC (rev 7710)
+++ trunk/mapserver/mapogcsos.c	2008-06-20 00:05:43 UTC (rev 7711)
@@ -689,6 +689,7 @@
                         pszTime = msStringConcatenate(pszTime, sShape.values[i]);
                         psNode = xmlNewChild(psObsNode, psNsOm, BAD_CAST "samplingTime", NULL);
                         psSubNode = xmlAddChild(psNode, msGML3TimeInstant(psNsGml, pszTime));
+                        msFree(pszTime);
                     break;
@@ -1519,7 +1520,7 @@
                                      msSetError(MS_SOSERR, "procedure_item %s could not be found on the layer %s",
                                     "msSOSGetCapabilities()", value, lpTmp->name);
-                                     return msSOSException(map, "procedure_item", "InvalidValue");
+                                     return msSOSException(map, "mapserv", "NoApplicableCode");
                                  /*for each selected feature, grab the value of the prodedire_item*/
@@ -1575,16 +1576,15 @@
                              else
-                                 msSetError(MS_SOSERR, "procedure_item %s could not be found on the layer %s",
-                                            "msSOSGetCapabilities()", value, lpTmp->name);
+                                 msSetError(MS_SOSERR, "Invalid procedure %s", "msSOSGetCapabilities()", value);
+                                 return msSOSException(map, "procedure", "InvalidParameterValue");
                          else
                               msSetError(MS_SOSERR, "Mandatory metadata procedure_item could not be found on the layer %s",
                                             "msSOSGetCapabilities()", GET_LAYER(map,j)->name);
-                                 return msSOSException(map, "procedure_item", "MissingValue");
@@ -1769,6 +1769,8 @@
   int nDiffrentProc = 0;
   SOSProcedureNode *paDiffrentProc = NULL;
   char *pszProcedureValue = NULL;
+  int iItemPosition, status;
+  shapeObj sShape;
   sBbox = map->extent;
@@ -1888,13 +1890,80 @@
             if (tokens1)
               msFreeCharArray(tokens1, n1);
+            if (bLayerFound == 0) {
+              msSetError(MS_SOSERR, "Procedure %s not found.", "msSOSGetObservation()", sosparams->pszProcedure);
+              msFreeCharArray(tokens, n);
-          /* if there is a procedure_item defined on the layer, we will
-             use it to set the filter parameter of the layer*/
+          /* if there is a procedure_item defined on the layer, we will */
+          /* use it to set the filter parameter of the layer */
           if ((GET_LAYER(map, i)->status == MS_ON) && (pszProcedureItem =  msOWSLookupMetadata(&(GET_LAYER(map, i)->metadata), "S", "procedure_item"))) {
             lp = GET_LAYER(map, i);
+/* HACK BEGIN */
+            if (msOWSLookupMetadata(&(GET_LAYER(map,i)->metadata), "S", "procedure") == NULL) {
+              /* if sos_procedure_item is used, and sos_procedure is not, it means that */
+              /* the procedure or sensor) need to be extracted from the data. Thus we */
+              /* need to query the layer and get the values from each feature */
+              if (lp->template == NULL)
+                lp->template = strdup("ttt");
+              msQueryByRect(map, i, map->extent);
+              /*check if the attribute specified in the procedure_item is available */
+              /*on the layer*/
+              iItemPosition = -1;
+              if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS && lp->resultcache && lp->resultcache->numresults > 0) {
+                for(k=0; k<lp->numitems; k++) {
+                  if (strcasecmp(lp->items[k], pszProcedureItem) == 0) {
+                    iItemPosition = k;
+                    break;
+                if (iItemPosition == -1) {
+                  msSetError(MS_SOSERR, "sos_procedure_item %s could not be found on the layer %s",
+                  "msSOSGetCapabilities()", pszProcedureItem, lp->name);
+                /*for each selected feature, grab the value of the procedure_item*/
+                bLayerFound = 0;
+                for(k=0; k<lp->resultcache->numresults; k++) {
+                  msInitShape(&sShape);
+                  status = msLayerGetShape(lp, &sShape, lp->resultcache->results[k].tileindex, lp->resultcache->results[k].shapeindex);
+                  if(status != MS_SUCCESS)
+                    continue;
+                  if (sShape.values[iItemPosition]) {
+                    tokens = msStringSplit(sosparams->pszProcedure, ',', &n);
+                    for (j=0; j<n; j++) {
+                      if (strcasecmp(sShape.values[iItemPosition], tokens[j]) == 0) { /* found */
+                        bLayerFound = 1;
+                        break;
+                  if (bLayerFound)
+                    break;
+                msLayerClose(lp);
+                 msSetError(MS_SOSERR, "Invalid procedure value %s", "msSOSGetCapabilities()", sosparams->pszProcedure);
+/* HACK END */
             pszBuffer = NULL;
             if (&lp->filter) {
               if (lp->filter.string && strlen(lp->filter.string) > 0)
@@ -2244,10 +2313,6 @@
-       //msSetError(MS_SOSERR, "%f %f %f %f", "msSOSGetCapabilities()", envelope.minx, envelope.miny, envelope.maxx, envelope.maxy);
-       //return msSOSException(map, "offering_extent", "InvalidParameterValue");
-       //psNode = xmlAddChild(psRootNode, msGML3BoundedBy(psNsGml, atof(tokens[0]), atof(tokens[1]), atof(tokens[2]), atof(tokens[3]), pszTmp2));
        psNode = xmlAddChild(psRootNode, msGML3BoundedBy(psNsGml, envelope.minx, envelope.miny, envelope.maxx, envelope.maxy, pszTmp2));
@@ -2558,7 +2623,7 @@
                 else {
                   msSetError(MS_SOSERR, "Missing mandatory metadata sos_describesensor_url on layer %s", "msSOSDescribeSensor()", lp->name);
-                  return msSOSException(map, "sos_describesensor_url", "MissingValue");
