[mapserver-commits] r7713 - trunk/docs/howto
Thu Jun 19 20:14:19 EDT 2008
Author: tomkralidis
Date: 2008-06-19 20:14:19 -0400 (Thu, 19 Jun 2008)
New Revision: 7713
   trunk/docs/howto/sos_server.txt
add note about large datasets
Modified: trunk/docs/howto/sos_server.txt
--- trunk/docs/howto/sos_server.txt	2008-06-20 00:08:37 UTC (rev 7712)
+++ trunk/docs/howto/sos_server.txt	2008-06-20 00:14:19 UTC (rev 7713)
@@ -620,6 +620,8 @@
 In Mapserver 5.0 SOS support has been upgraded to use a new metadata called sos_procedure_item. The value for sos_procedure_item is the field/attribue name  containing the procedure values. The use of this metadata as well as the sos_procedure is described here per type of request (refer to http://trac.osgeo.org/mapserver/ticket/2050 for more description):
+It should be noted that, for very large datasets defined only with sos_procedure_item, this may result in costly processing, because MapServer has to process attribute data.  It is advised to setup and manage datasets accordingly if dealing with large observation collections.
 GetObservation
