[mapserver-commits] r7718 - trunk/mapserver
Fri Jun 20 08:31:29 EDT 2008
Author: tomkralidis
Date: 2008-06-20 08:31:29 -0400 (Fri, 20 Jun 2008)
New Revision: 7718
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapows.c
   trunk/mapserver/mapows.h
   trunk/mapserver/mapwfs.c
   trunk/mapserver/mapwms.c
WFS: project LatLongBoundingBox if required (#2579)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-20 02:42:51 UTC (rev 7717)
+++ trunk/mapserver/HISTORY.TXT	2008-06-20 12:31:29 UTC (rev 7718)
@@ -12,6 +12,8 @@
 Current Version (SVN trunk):
+- WFS: project LatLongBoundingBox if required (#2579)
 - SOS: generate error for some invalid filters (#2604)
 - SLD: Use style's width paramater when generating sld (#1192)
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c	2008-06-20 02:42:51 UTC (rev 7717)
+++ trunk/mapserver/mapows.c	2008-06-20 12:31:29 UTC (rev 7718)
@@ -1169,22 +1169,29 @@
 void msOWSPrintLatLonBoundingBox(FILE *stream, const char *tabspace,
                                  rectObj *extent, projectionObj *srcproj,
-                                 int nService)
+                                 projectionObj *wfsproj, int nService)
   const char *pszTag = "LatLonBoundingBox";  /* The default for WMS */
-  rectObj ll_ext;
+  rectObj ext;
-  ll_ext = *extent;
+  ext = *extent;
-  if (srcproj->numargs > 0 && !pj_is_latlong(srcproj->proj)) {
-    msProjectRect(srcproj, NULL, &ll_ext);
+  if (nService == OWS_WMS) { /* always project to lat long */
+    if (srcproj->numargs > 0 && !pj_is_latlong(srcproj->proj)) {
+      msProjectRect(srcproj, NULL, &ext);
-  if (nService == OWS_WFS)
+  if (nService == OWS_WFS) {
       pszTag = "LatLongBoundingBox";
+      if (wfsproj) {
+          if (msProjectionsDiffer(srcproj, wfsproj) == MS_TRUE)
+              msProjectRect(srcproj, wfsproj, &ext);
   msIO_fprintf(stream, "%s<%s minx=\"%g\" miny=\"%g\" maxx=\"%g\" maxy=\"%g\" />\n",
-         tabspace, pszTag, ll_ext.minx, ll_ext.miny, ll_ext.maxx, ll_ext.maxy);
+         tabspace, pszTag, ext.minx, ext.miny, ext.maxx, ext.maxy);
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2008-06-20 02:42:51 UTC (rev 7717)
+++ trunk/mapserver/mapows.h	2008-06-20 12:31:29 UTC (rev 7718)
@@ -265,7 +265,7 @@
                               const char *default_value);
-                                 int nService);
+                                 projectionObj *wfsproj, int nService);
 void msOWSPrintBoundingBox(FILE *stream, const char *tabspace,
                            rectObj *extent,
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2008-06-20 02:42:51 UTC (rev 7717)
+++ trunk/mapserver/mapwfs.c	2008-06-20 12:31:29 UTC (rev 7718)
@@ -205,6 +205,9 @@
 int msWFSDumpLayer(mapObj *map, layerObj *lp)
    rectObj ext;
+   const char *pszWfsSrs = NULL;
+   projectionObj poWfs;
+   int result = 0;
    msIO_printf("    <FeatureType>\n");
@@ -242,31 +245,35 @@
    if (msOWSGetEPSGProj(&(map->projection),&(map->web.metadata),"FO",MS_TRUE) != NULL)
        /* Map has a SRS.  Use it for all layers. */
-       msOWSPrintEncodeParam(stdout, "(at least one of) MAP.PROJECTION, LAYER.PROJECTION or wfs_srs metadata",
-                  msOWSGetEPSGProj(&(map->projection),&(map->web.metadata),"FO",MS_TRUE),
-                  OWS_WARN, "        <SRS>%s</SRS>\n", NULL);
+       pszWfsSrs = msOWSGetEPSGProj(&(map->projection),&(map->web.metadata), "FO", MS_TRUE);
    else
        /* Map has no SRS.  Use layer SRS or produce a warning. */
-                  msOWSGetEPSGProj(&(lp->projection), &(lp->metadata), "FO", MS_TRUE),
+   msOWSPrintEncodeParam(stdout, "(at least one of) MAP.PROJECTION, LAYER.PROJECTION or wfs_srs metadata",
+                  pszWfsSrs, OWS_WARN, "        <SRS>%s</SRS>\n", NULL);
    /* If layer has no proj set then use map->proj for bounding box. */
    if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS)
+       msInitProjection(&poWfs);
+       if (pszWfsSrs != NULL)
+           result = msLoadProjectionString(&(poWfs), (char *)pszWfsSrs);
        if(lp->projection.numargs > 0)
            msOWSPrintLatLonBoundingBox(stdout, "        ", &(ext),
-                                       &(lp->projection), OWS_WFS);
+                                       &(lp->projection), &(poWfs), OWS_WFS);
        else
-                                       &(map->projection), OWS_WFS);
+                                       &(map->projection), &(poWfs), OWS_WFS);
+       msFreeProjection(&poWfs);
    else
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2008-06-20 02:42:51 UTC (rev 7717)
+++ trunk/mapserver/mapwms.c	2008-06-20 12:31:29 UTC (rev 7718)
@@ -1212,14 +1212,14 @@
-                                       &(lp->projection), OWS_WMS);
+                                       &(lp->projection), NULL, OWS_WMS);
            msOWSPrintBoundingBox( stdout,"        ", &(ext), &(lp->projection),
                                   &(lp->metadata), "MO" );
        else
-                                       &(map->projection), OWS_WMS);
+                                       &(map->projection), NULL, OWS_WMS);
            msOWSPrintBoundingBox(stdout,"        ", &(ext), &(map->projection),
                                   &(map->web.metadata), "MO" );
@@ -1907,7 +1907,7 @@
                             OWS_WARN, "    <SRS>%s</SRS>\n", "");
   msOWSPrintLatLonBoundingBox(stdout, "    ", &(map->extent),
   msOWSPrintBoundingBox( stdout, "    ", &(map->extent), &(map->projection),
