[mapserver-commits] r7742 - trunk/mapserver
Wed Jun 25 01:23:00 EDT 2008
Author: sdlime
Date: 2008-06-25 01:22:59 -0400 (Wed, 25 Jun 2008)
New Revision: 7742
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maptemplate.c
Fixed a few bugs with RFC 36 implementation that prevented the mapscript mapObj method processQueryTemplate() from working.
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-06-25 00:47:33 UTC (rev 7741)
+++ trunk/mapserver/HISTORY.TXT	2008-06-25 05:22:59 UTC (rev 7742)
@@ -12,8 +12,11 @@
 Current Version (SVN trunk):
+- maptemplate.c: Fixed issues in RFC 36 implementation that prevented mapscript
+  mapObj->processQueryTemplate() method from working.
 - WMS/WFS: extend warning message (#1396)
 - WFS: Respect units for the DWhitin parameter (#2297)
 - WFS: correct OGC Contains filter  (#2306)
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2008-06-25 00:47:33 UTC (rev 7741)
+++ trunk/mapserver/maptemplate.c	2008-06-25 05:22:59 UTC (rev 7742)
@@ -1,5 +1,5 @@
- * $Id$
+ * $id: maptemplate.c 7725 2008-06-21 15:56:58Z sdlime $
  * Project:  MapServer
  * Purpose:  Various template processing functions.
@@ -228,8 +228,6 @@
     msGenerateImages(mapserv, MS_TRUE, MS_TRUE);
-  /* initialize the buffer if necessary */
   if(outputFormat) {
     const char *file = msGetOutputFormatOption( outputFormat, "FILE", NULL );
     if(!file) {
@@ -3254,8 +3252,9 @@
     /* if(resultlayer->description) outstr = msReplaceSubstring(outstr, "[cd]", resultlayer->description); // current layer description     */
-  if(processResultSetTag(mapserv, &outstr, stream) != MS_SUCCESS)
-    return(NULL);
+  if(mode != QUERY) {
+    if(processResultSetTag(mapserv, &outstr, stream) != MS_SUCCESS) return(NULL);
   if(mode == QUERY) { /* return shape and/or values  */
@@ -3502,13 +3501,13 @@
   tmpurl = processLine(ms, url, NULL, mode); /* URL templates can't handle multi-line tags, hence the NULL file pointer */
   if(!tmpurl)
-   return MS_FAILURE;
+    return MS_FAILURE;
   msRedirect(tmpurl);
   free(tmpurl);
   return MS_SUCCESS;
@@ -3528,16 +3527,6 @@
   layerObj *lp=NULL;
-  /*      mime type could be null when the function is called from        */
-  /*      mapscript (function msProcessQueryTemplate)                     */
-  /* if(!pszMimeType) {
-    msSetError(MS_WEBERR, "Mime type not specified.", "msReturnNestedTemplateQuery()");
   if(papszBuffer) {
     (*papszBuffer) = (char *)malloc(MS_TEMPLATE_BUFFER);
     (*papszBuffer)[0] = '\0';
@@ -3548,7 +3537,7 @@
   msInitShape(&(mapserv->resultshape));
-  if((mapserv->Mode == ITEMQUERY) || (mapserv->Mode == QUERY)) { /* may need to handle a URL result set */
+  if((mapserv->Mode == ITEMQUERY) || (mapserv->Mode == QUERY)) { /* may need to handle a URL result set since these modes return exactly 1 result */
     for(i=(mapserv->map->numlayers-1); i>=0; i--) {
       lp = (GET_LAYER(mapserv->map, i));
@@ -3574,9 +3563,8 @@
         status = msLayerOpen(lp);
         if(status != MS_SUCCESS) return status;
-        /* retrieve all the item names */
-        status = msLayerGetItems(lp);
+        status = msLayerGetItems(lp); /* retrieve all the item names */
         status = msLayerGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[0].tileindex, lp->resultcache->results[0].shapeindex);
@@ -3605,6 +3593,9 @@
+  ** Now we know we're making a template sandwich
   mapserv->NR = mapserv->NL = 0;
   for(i=0; i<mapserv->map->numlayers; i++) { /* compute some totals */
@@ -3617,10 +3608,12 @@
-  if(papszBuffer && pszMimeType) {
+  ** Is this step really necessary for buffered output? Legend and browse templates don't deal with mime-types
+  ** so why should this. Note that new-style templates don't buffer the mime-type either.
+  if(papszBuffer && mapserv->sendheaders) {
     sprintf(buffer, "Content-type: %s%c%c\n", pszMimeType, 10, 10);
-    /* sprintf(buffer, "<!-- %s -->\n",  msGetVersion()); */
     if(nBufferSize <= (int)(nCurrentSize + strlen(buffer) + 1)) {
       nExpandBuffer++;
       (*papszBuffer) = (char *)realloc((*papszBuffer), MS_TEMPLATE_BUFFER*nExpandBuffer);
@@ -3628,9 +3621,8 @@
     strcat((*papszBuffer), buffer);
     nCurrentSize += strlen(buffer);
-  } else if(pszMimeType) {
-      msIO_printf("Content-type: %s%c%c", pszMimeType, 10, 10); /* write MIME header */
-    /* printf("<!-- %s -->\n", msGetVersion()); */
+  } else if(mapserv->sendheaders) {
+    msIO_printf("Content-type: %s%c%c\n", pszMimeType, 10, 10);
     fflush(stdout);
@@ -3647,16 +3639,13 @@
     mapserv->NLR = lp->resultcache->numresults;
-    /* open this layer */
-    status = msLayerOpen(lp);
+    status = msLayerOpen(lp); /* open this layer */
-    /* open any necessary JOINs here */
-    if(lp->numjoins > 0) {
+    if(lp->numjoins > 0) { /* open any necessary JOINs here */
       for(k=0; k<lp->numjoins; k++) {
         status = msJoinConnect(lp, &(lp->joins[k]));
@@ -4039,7 +4028,8 @@
     if(bGenerateImages)
       msGenerateImages(mapserv, MS_TRUE, MS_FALSE);
-    msReturnTemplateQuery(mapserv, NULL, &pszBuffer );
+    mapserv->sendheaders = MS_FALSE;
+    msReturnTemplateQuery(mapserv, mapserv->map->web.queryformat, &pszBuffer);
     mapserv->map = NULL;
     mapserv->request->ParamNames = mapserv->request->ParamValues = NULL;
