[mapserver-commits] r7430 - trunk/mapserver
Tue Mar 4 15:27:23 EST 2008
Author: warmerdam
Date: 2008-03-04 15:27:22 -0500 (Tue, 04 Mar 2008)
New Revision: 7430
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwcs.c
Throw an exception if the WCS request does not overlap layer (#2503)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-03-04 02:20:27 UTC (rev 7429)
+++ trunk/mapserver/HISTORY.TXT	2008-03-04 20:27:22 UTC (rev 7430)
@@ -13,6 +13,8 @@
 Current Version (5.1-dev, SVN trunk):
+- Throw an exception if the WCS request does not overlap layer (#2503)
 - Acquire TLOCK_PROJ for pj_transform() calls (#2533).
 - Fixed problem with large imagemaps generating no output (#2526)
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2008-03-04 02:20:27 UTC (rev 7429)
+++ trunk/mapserver/mapwcs.c	2008-03-04 20:27:22 UTC (rev 7430)
@@ -1309,6 +1309,8 @@
   char *bandlist=NULL;
   char numbands[8]; /* should be large enough to hold the number of bands in the bandlist */
   coverageMetadataObj cm;
+  rectObj reqextent;
+  rectObj covextent;
   /* make sure all required parameters are available (at least the easy ones) */
   if(!params->crs) {
@@ -1613,6 +1615,33 @@
   map->projection.gt = map->gt;
+  // check for overlap
+  // get extent of bbox passed, and reproject
+  reqextent.minx = map->extent.minx;
+  reqextent.miny = map->extent.miny;
+  reqextent.maxx = map->extent.maxx;
+  reqextent.maxy = map->extent.maxy;
+  // reproject incoming bbox
+  msProjectRect(&map->projection, &lp->projection, &(reqextent));
+  // get extent of layer
+  covextent.minx = cm.extent.minx;
+  covextent.miny = cm.extent.miny;
+  covextent.maxx = cm.extent.maxx;
+  covextent.maxy = cm.extent.maxy;
+  if(msRectOverlap(&reqextent, &covextent) == MS_FALSE) {
+      msSetError(MS_WCSERR, "\nBBOX NATIVE    = %.15g,%.15g,%.15g,%.15g\nEXTENT NATIVE  = %.15g,%.15g,%.15g,%.15g\nBBOXLL         = %.15g,%.15g,%.15g,%.15g\nEXTENTLL       = %.15g,%.15g,%.15g,%.15g",
+                            "msWCSGetCoverage()",
+                            reqextent.minx, reqextent.miny, reqextent.maxx, reqextent.maxy,
+                            cm.extent.minx, cm.extent.miny, cm.extent.maxx, cm.extent.maxy,
+                            params->bbox.minx, params->bbox.miny, params->bbox.maxx, params->bbox.maxy,
+                            cm.llextent.minx, cm.llextent.miny, cm.llextent.maxx, cm.llextent.maxy);
+      return msWCSException(map, "NoApplicableCode", "bbox", params->version);
   /* check and make sure there is a format, and that it's valid (TODO: make sure in the layer metadata) */
   if(!params->format) {
     msSetError( MS_WCSERR,  "Missing required FORMAT parameter.", "msWCSGetCoverage()" );
