[mapserver-commits] r7458 - trunk/mapserver
Mon Mar 17 16:00:24 EDT 2008
Author: dmorissette
Date: 2008-03-17 16:00:23 -0400 (Mon, 17 Mar 2008)
New Revision: 7458
   trunk/mapserver/README.CONFIGURE
Added note about --with-fribidi-config (#956)
Modified: trunk/mapserver/README.CONFIGURE
--- trunk/mapserver/README.CONFIGURE	2008-03-17 18:44:51 UTC (rev 7457)
+++ trunk/mapserver/README.CONFIGURE	2008-03-17 20:00:23 UTC (rev 7458)
@@ -114,6 +114,8 @@
                           OGR required).
   --with-curl-config=PATH Specify path to curl-config.
   --with-xml2-config=PATH Specify path to xml2-config.
+  --with-fribidi-config[=ARG] Include FriBidi Support (ARG=yes/path to
+                          fribidi-config)
   --with-fastcgi=path     Enable FastCGI, point to installed tree.
   --with-httpd            Specify path to 'httpd' executable.
   --with-warnings[=flags] Enable strict warnings (or user defined warnings)
@@ -596,10 +598,29 @@
   script is located.
   e.g.
      ./configure .... --with-xml2-config=/usr/local/bin/xml2-config
+FriBidi Support:
+                          fribidi-config)
+- The FriBidi library (http://fribidi.freedesktop.org/wiki/) is used
+  by MapServer to support labels flowing from right to left, such as
+  Arabic or Hebrew.
+- Support for the FriBidi library is optional and is not included by
+  default.
 Miscellaneous flags:
