[mapserver-commits] r7474 - trunk/docs/references/mapfile
Thu Mar 20 15:36:53 EDT 2008
Author: jmckenna
Date: 2008-03-20 15:36:53 -0400 (Thu, 20 Mar 2008)
New Revision: 7474
   trunk/docs/references/mapfile/web.txt
add browseformat, legendformat, and queryformat parameters
Modified: trunk/docs/references/mapfile/web.txt
--- trunk/docs/references/mapfile/web.txt	2008-03-20 17:45:46 UTC (rev 7473)
+++ trunk/docs/references/mapfile/web.txt	2008-03-20 19:36:53 UTC (rev 7474)
@@ -1,3 +1,11 @@
+BROWSEFORMAT [mime-type]
+    (add to MapServer 4.8.0) Format of the interface output, using MapServer CGI.  The default value is "text/html".
+    Example:
+        BROWSEFORMAT "text/plain"
 EMPTY [url]
     URL to forward users to if a query fails. If not defined the value for
     ERROR is used.
@@ -22,6 +30,14 @@
     Base URL for IMAGEPATH. This is the URL that will take the web browser
     to IMAGEPATH to get the images.
+LEGENDFORMAT [mime-type]
+    (add to MapServer 4.8.0) Format of the legend output, using MapServer CGI.
+    The default value is "text/html".  Example:
+        LEGENDFORMAT "text/plain"
 LOG [filename]
     File to log MapServer activity in. Must be writable by the user the web
     server is running as.
@@ -64,6 +80,15 @@
 .. _`OUTPUTFORMAT`: /docs/reference/mapfile/outputformat
+QUERYFORMAT [mime-type]
+    (add to MapServer 4.8.0) Format of the query output.  This works for mode=query (using query templates
+    in CGI mode), but not for mode=browse.  The default value is "text/html".
+    Example:
+        QUERYFORMAT "text/plain"
 TEMPLATE [filename|url]
     Template file or URL to use in presenting the results to the user in an
     interactive mode (i.e. map generates map and so on ... )
\ No newline at end of file
